Espritmodel.com Heli Air
Old Aug 20, 2004, 02:08 PM
rgteel
Tulsa, Oklahoma
Joined May 2003
AVA-E power suggestions
I am purchasing an AVA-E and am looking for suggestions
for a 7 cell set up. (Motor, Prop and cell type).
Thanks for taking the time to respond!
Randy
rgteel is offline Find More Posts by rgteel
Old Aug 20, 2004, 03:10 PM
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
Randy
I personally think the money no object best 7 cell set up out there is the Plettenberg 7 cell F5B motor + 7:1 gearbox (HP 220/15/A1 P6 7:1), 16x13 prop and 7xgp2200 SCHR.
Second best choice hacker b50 6S + 5.2 with either the gp2200 or 3300 and up to an 18 inch prop. This combo can potentially be more efficient at over 100 amps than the Petti but will be heavier, which might not matter much on a 3 meter glider.
Equal 2nd best choice, Electronic motors Elios 56 + reisenauer 5:1 micro light + 17x13 prop.
There's probably a Kontronic motor that would do the same job and for all I know an Aveox as well.
In 7 cell setups the weight counts more, which is why the GP2200 batteries will be such a big help, letting you get over 100 amps without adding much weight over cp1700 or faup 1960.
best
dave
davidleitch is offline Find More Posts by davidleitch
Old Aug 21, 2004, 08:06 AM
New York
Joined Feb 2002
David, I'm also considering motor selection for an electric AVA on order. I've got a Hacker B40-8L+4.4:1 sitting on the shelf, used to power a 2.5 meter Silent Dream on 7 cells with a CAM 14x9.5 prop. Was hoping to use this motor perhaps on 8 cells (new 2,200 GP NiMH cells--same size as CP1,700s) and a different prop. Don't need rocket ship performance, just a good strong launch to altitude.
Your thoughts?
TIA,
Steve
SteveR is offline Find More Posts by SteveR
Old Aug 21, 2004, 09:55 AM
Tragic case
Sydney Australia
Joined Feb 2002
Steve
I am no expert on power systems. The 8L will likely get the plane up there pretty well on 8 cells if you it at around 60-70 amps.It really all depends on how fast you want to climb.
The 2200 cells are great. Where are you getting yours from?
dave
Old Aug 21, 2004, 11:47 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
As Dave said, it all depends on how you want to fly, and how quickly you want to climb.
Choose a power system that gets you at least 50W/lb for slow, easy, sport-like climbs. 100W/lb for good performance, 1000' or so - the limits most non competitive pilots usually fly at - in 30-45 seconds. 200W/lb for hotliner/insane speeds, and more for F5B stuff.
..a
Old Aug 21, 2004, 05:11 PM
New York
Joined Feb 2002
Thanks guys, at least I can start with this Hacker knowing it's in the ballpark, hate to keep buying a different motor for every plane. I'll be ordering an 8-cell pack of GP-2200 NiMH cells from Diversity (Steve Belknap). His quality and service are outstanding.
Steve
Old Aug 21, 2004, 05:38 PM
pocket rocket's Avatar
patagonia,az
Joined Oct 2002
the B40 will be very good, this is from my experience with similar motor in a Art Hobby High Aspect, which is similar size to Ava.
use a large diameter prop to get good thrust.
Philip
pocket rocket is offline Find More Posts by pocket rocket
Old Aug 22, 2004, 08:17 PM
Ray Lowinski's Avatar
Napoleon, Ohio
Joined Dec 1996
I have an AVA-E fuse and Aquilla wing hanging around and maybe I'll just have to get the tail feathers done this winter and give it a go.
Ray
Ray Lowinski is offline Find More Posts by Ray Lowinski
Old Aug 23, 2004, 12:17 PM
Boyko Sasha's Avatar
Kiev
Joined Jan 2004
Hi ,
In Ukraine we fly with Kontronik Fun 480-55 / 5,2:1 , with propeller aero-naut cam carbon 15x10 , 7 x Sanyo 2400 or Sanyo 4/5.
And at all model is cool.
- Sasha
Boyko Sasha is offline Find More Posts by Boyko Sasha
AVA-E Power Suggestions rgteel High Performance 1 Aug 20, 2004 10:53 AM
Good Source for E-Power Old Timers StructuresGuy Electric Plane Talk 4 Sep 10, 2001 10:25 AM
E-Power time traveller rc capo Electric Plane Talk 0 May 21, 2001 07:49 AM
Power Suggestions for three engined Italian Bomber R101 Scale Electric Planes 3 Apr 28, 2001 07:31 AM
