Go Back   RC Groups > Aircraft - General > Composites Fabrication
Old Aug 20, 2004, 02:34 AM   #1
making it up as i go.
annihilator's Avatar
what material would mill well enough to make a mold?
allright guys, Im exploring the costs involved in finding a block/sheet/anything that can be stacked, glued whatever to CNC mill out a mold. Ive thought of wood, (cheap, but finish wouldnt be great at ALL!), metal is really expensive (find me a cheap place guys please!) and havent found and chunks of plastic!
im looking for enough to make about a 4 foot wing with a 1.5 inch maximum thickness. do you think if i sanded and waxed the wood you think that would work? anyone have experience with this?
thanks
annihilator is offline Find More Posts by annihilator   Reply With Quote
Old Aug 20, 2004, 10:27 AM   #2
1nk
kill your foamie!
1nk's Avatar
You can use tooling foam, it machines real easily. I'm not sure how much it cost, probably expensive, not sure?
I've seen a guy machine a block of balsa wood into a wing once and just finished with varnish, man that was a strong wing.
1nk is offline Find More Posts by 1nk   Reply With Quote
Old Aug 20, 2004, 12:55 PM   #3
Ward Hagaman's Avatar
Just curious, but why 1.5 thick? I used 1/2" cast aluminum tooling plate for a 60" RG-15, and it is pretty thin, but works fine. Still not cheap, but considering the machining time the material cost is a small part of the total cost of the mold (in my opinion.)
Ward Hagaman is offline Find More Posts by Ward Hagaman   Reply With Quote
Old Aug 20, 2004, 05:52 PM   #4
how much would that aluminum block cost? im not worried about machine time, its free for me
Old Aug 20, 2004, 09:44 PM   #5
Dieselized User
gkamysz's Avatar
If machine time is free go for aluminum. A good price for aluminum is $2US per pound. But that is basically for off-cuts. Plan on spending $3.50-4.00 per pound minimum for anything large enough to make wing mold out of. Aluminum weighs .1Lb per cubic inch so it's easy to figure 55"x2"x8" would weigh 88Lb and cost $308 at $3.50 per Lb. If you need to ship it that could be substantial so check for local suppliers.
Greg
gkamysz is offline Find More Posts by gkamysz   Reply With Quote
Old Aug 21, 2004, 12:19 AM   #6
Try this site for a modeling plastic:
http://www.nfgsales.com/modeling.htm
Don
dharban is offline Find More Posts by dharban   Reply With Quote
Old Aug 21, 2004, 10:08 PM   #7
Aethertek's Avatar
Acrylic Plexiglass machines like butter.
Aethertek is offline Find More Posts by Aethertek   Reply With Quote
Old Aug 22, 2004, 03:36 AM   #8
3D toolpath program
If we're on the subject, is there a free 3d toolpath program that you know of?
erazz is offline Find More Posts by erazz   Reply With Quote
Old Aug 22, 2004, 11:08 PM   #9
man that modeling plastic sounds perfect. i sent them an email to find out how much it is.....any ideas on the price range? thinking about the 350 or 450 series.
Old Aug 23, 2004, 02:43 AM   #10
Florrain's Avatar
If you go for tooling foam, you have to decide if you are ready to do some finishing work including painting after the machining or if you want a material that can be polished coming out of the mill.
Renshape and Cibatool have both kind of tooling foam they are usually color-coded. Of course the price of the polishable material is very high compared to the more porous type.
A good tip if you have to paint the master is to mill a +-2mm deep groove all around the plug to acomodate for paint filets.
If you use the expensive material this is of course not necessary.
Francois
Florrain is offline Find More Posts by Florrain   Reply With Quote
Old Aug 23, 2004, 10:58 AM   #11
Florrain, you make a good point--milling a plug and pulling a epoxy mold from the male form is an option. I imagine that a cnc router might be happier cutting Renshape than Aluminum. Are there any other applications when it would be better to go that way instead of cutting the mold directly?
Old Aug 23, 2004, 11:12 AM   #12
yea guys i just priced some ren shape and its way out of my price range. for a 2x16x60 piece of the 350 series it would be 261.42!!!!!!!!!!! and thats the cheapest kind oh well its was worth a shot. im thinking that the male plug might be the way to go. it would still be quicker than making a plug by hand.
Old Aug 23, 2004, 11:17 AM   #13
Florrain's Avatar
Hello
The idea behind milling a male plug is that you can pull multiple molds from it.
The way this usually happens in Europe is that some talented model designer creates a successfull design that a friend with CNC machine is willing to mill for a good price and then they pull a few molds from it.
When the model starts to give some good results, interrest quickly develops and it becomes possible to rent the plugs and recover some of the money involved in the designing, milling and moldmaking work.
Typically a plug for an F5D modell can be rented for +-400€ and for an F3B glider it's more around 1500€ wich might seem expensive but is still far less than if you have to have the plugs milled by a professional.
Francois
Old Aug 23, 2004, 12:04 PM   #14
You can mill molds from MDF, which is very cheap and can be glued to the required thickness using pva.
The molds will need sealing with epoxy and then polishing but this doesn't take anytime.
The molds will not last as long as those made from aluminium but when you consider the cost is around 4% it is well worth it.
Joe
devmonkey is offline Find More Posts by devmonkey   Reply With Quote
Old Aug 23, 2004, 01:15 PM   #15
1nk
kill your foamie!
1nk's Avatar
What about machining 60 PSI Blue DOW refrigeration foam? That stuff is almost like a tooling foam, I just wonder how you can finish it, probably have to glass and vac bag the plug before you can even splash parts off it.
Discussion What plane would do well with this equipments Cambo Electric Plane Talk 2 Apr 25, 2007 06:50 PM
Got a HiMaxx 2025-5300 what heli would use this well? Matt Chester Micro Helis 2 Jun 23, 2005 09:47 AM
What craft would be good match for Astro 05-G ? Jim Noel Sport Planes 14 Mar 01, 2005 10:59 AM
how do you make a mold buckeyes1997 Electric Sailplanes 31 Mar 01, 2002 01:12 PM
What planes would you suggest for an Aveox 1010/DF wallyh Electric Plane Talk 1 Nov 18, 2001 07:44 PM
Bored? Want to fight?
Join the RCGroups clan!
