Old Aug 19, 2004, 09:08 PM
rcmarty is offline
Find More Posts by rcmarty
Penticton, B.C.
Joined Jun 2004
Shogun tail servo ? Anything as good or better than hs50 ?
Just had the hs50 quit on me. Total time about 10 mins (including setup time)
Is there a better option out there ? The hs50 specs are nice but no bearing supported output. Combine that with hitec failure rate.
Thanks , martin
rcmarty is offline Find More Posts by rcmarty
Old Aug 19, 2004, 09:54 PM
mdttb is offline
Find More Posts by mdttb
mdttb's Avatar
United States, CA, Stanton
Joined Jan 2004
Thanks , martin
I'm looking for something better then the HS50s too, if you find someting let me know.
I've heard great things about Hitec's customer support and tech department. So far I haven't had a issue with a transmitter or a servo failing cept for my dog getting a hold of one and chewing it up.
I went back to using a HS55 on the tail for one of my Shoguns, only reason I have a HS50 on the other one is it's the only servo I have. I'll be looking for a couple of replacements for the HS50 may as well buy two or 3.
mdttb is offline Find More Posts by mdttb
Old Aug 19, 2004, 10:56 PM
azaparov is offline
Find More Posts by azaparov
Joined Jul 2004
I had 3 hitec hs50 quit within 10 minutes. All with dead motor.
Looks like pretty bad servo. GWS pico servo works well for more than 30 flights already.
Thanks , martin
azaparov is offline Find More Posts by azaparov
Old Aug 19, 2004, 11:24 PM
Art Newland is online now
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
the HS-56's have been great in my Shogun, I have them all the way around.
Art Newland is online now Find More Posts by Art Newland
Old Aug 19, 2004, 11:25 PM
rcmarty is offline
Penticton, B.C.
Joined Jun 2004
acording to the gws card (i have 2 pico's right here)
the pico F clocks in at .09 seconds (4.8v)
Standard pico is 12
hs-50 's are .09 (same) at 4.8v
hs-50 weighs - 6.1 grams
pico f weighs - 5.4 grams
If you want a BB output you have to get into the naro (next bigger) line.
check out this link. Doesn't list all the servo's but there are some.
Pico + f has a bearing but is 6.2oz ( 0.1 heavier than hs50) but slower at .12
BUT is claimed to be .10 on 6 volts. Anyone know what the voltage out of ECS is ? I'm using the CC esc's in both brushless and brushed.
Maby this is another option.
Myself i'd like to see a bearing.
Martin
Old Aug 19, 2004, 11:32 PM
rcmarty is offline
Penticton, B.C.
Joined Jun 2004
art :
The 56's are nice as they have the bearing in them. I also hear the carbonate gear doesn't have alot of play in them, and wear well.
The 56's clock in at .12 sec and .10 at 6.0 volts , at 11.2 grams.
Do you have this servo boom mounted ? How are you working your CG ?
Martin
Old Aug 20, 2004, 12:12 AM
dankers is offline
Find More Posts by dankers
OpenPilot
dankers's Avatar
Melbourne, Australia
Joined Apr 2004
The hs-50 is very overrated, it's too big for the stock location, comes complete with slop and is expensive.
The best servo for the Zoom tail in my opinion has to be:
GWS Naro+f hp BB - .10 @ 4.8V with 1.7 kg of tourqe with no slop. I dumped my hs-50 for one of these and they also fit in the frame. Tail is ROCK solid running 75% on a gy240. If I had known what I know now, I would have put these servos on collective and cyclic as well.
dankers is offline Find More Posts by dankers
Old Aug 20, 2004, 12:31 AM
Goge is offline
Find More Posts by Goge
Happy happy, joy joy!
Goge's Avatar
Portland, Oregon, USA
Joined Jun 2001
I like my Cirrus 5.4
Seems fast enough, is slimmer and doesn't rub the main gear, but needs a little mounting TLC as the holes don't match up perfectly. Appear to be bulletproof so far.
I've had good luck with HS-50s so far, but 55's are not my favorites in the world. Seems that, for me, the pots go out regularly. Just my $.02
-Todd
Goge is offline Find More Posts by Goge
Old Aug 20, 2004, 01:24 AM
LoopZilla is offline
Find More Posts by LoopZilla
Day by day...
LoopZilla's Avatar
Melbourne, FL
Joined Feb 2004
I am using a Cirrus CS-10 BB, having changed from my HS-50. I had a tail wag the would not go away until I went to the Cirrus. It is a super fast little servo, faster than the HS-50.
Dimensions: .90 x .37 x .610.
Weights19oz (5.5g)
Speed: 0.06 sec/60 deg
Torque: 7 oz/in (0.5
Ball Bearing
LoopZilla is offline Find More Posts by LoopZilla
Old Aug 20, 2004, 02:03 AM
me3 is offline
me3
Find More Posts by me3
me3
Joined Apr 2004
I have used:
gws pico+
hs50
jr371
the pico plus suked, the hs 50 is good (mine centres well?) and the jr is almost as good as the hs50 in terms of speed and also seems to have better resolution. had them all laying around so I checked. I use a jr410t hh gyro, and the response from it is WAY sharper than the futaba (I have also tried gy240) so the poor old gws pico had no hope with its slower response times. There is no discerable difference between the jr and hitec in flight (also the same size wieght etc)
me3 is offline Find More Posts by me3
Old Aug 20, 2004, 08:56 AM
monts is offline
Find More Posts by monts
San Diego
Joined Mar 2002
Would a digital servo serve in this application, or is that overkill?
monts is offline Find More Posts by monts
Old Aug 20, 2004, 09:07 AM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
I used to run 401 and hs50 on my Hornet 2's... When I bought 2 shoguns I used 401s and hs56's. The tail holds BETTER on the shogun than it did on my Hornet 2. The HS56 HB is ROCK solid on my Shoguns. I replaced the stock drive wire with a homemade carbon fiber pushrod and mp jet clevises. The HS56 is a great servo.
Brendin
Xnaron is offline Find More Posts by Xnaron
Old Aug 20, 2004, 11:41 AM
ozoneone is offline
Find More Posts by ozoneone
King of The Moon
ozoneone's Avatar
NYC
Joined Jun 2003
I shouldn't say this because after everyone finds out they'll all be on backorder!
Expert SL-110. I have one on the HII and one on the Shogun. Great little servo.
HS55's & 56's are fine, but the 50's are hit and miss.
http://www.rcmicroflight.com/dec99/m..._roundup03.asp
ozoneone is offline Find More Posts by ozoneone
Old Aug 20, 2004, 11:53 AM
thewz is offline
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Doesn't your GYRO have to be compatible with a digital to use it I know the GY401 isIm not sure about the GY240.
I just found out that the answer is a resounding NO...you can use a digital anywhere a standard is used but it will use more power.
thewz is offline Find More Posts by thewz
Old Aug 20, 2004, 12:02 PM
thewz is offline
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Here is a link about digital servos from Futaba....pretty good.
www.futaba-rc.com/servos/digitalservos.pdf
Jaguar by Larry Hargrave - Does anyone know anything about it, Good or Bad? jimbailey Slope 15 Nov 26, 2012 12:44 PM
Shogun tail servo rplourdejr Mini Helis 4 Oct 20, 2005 12:59 PM
Equal or Better than the SX-3?? Merkaba Foamies (Kits) 5 May 27, 2005 01:47 PM
FS: Brand New CNC Shogun tail servo mount EddieNewYork Aircraft - Electric - Helis (FS/W) 2 Feb 21, 2005 06:19 PM
tail servo for corona-metal or nylon gear? RabelRouse Electric Heli Talk 3 Jul 16, 2004 07:15 PM
