Old Aug 18, 2004, 08:21 PM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
50+ AMP Power Supplies
Hey guys,
One of my club fields has AC Power.....but I'm killing my 25 amp Radio Shack power supply.
When charging two 8S3P packs at 6 amps each....I'm exceeding the current capabilities. I will soon need to charge 10S packs at 6 amps each....plus some smaller packs at the same time...
Anyone have a good suggestion for an easily portable 50 amp power supply? I need something that's less than 10 lbs ....smaller the footprint the better...
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Aug 18, 2004, 09:34 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I would suggest two of the 25A units, one per charger. That's what I have (although I rarely push my chargers as hard as you are). It will be FAR cheaper and smaller than a 50A PSU..
..a
Old Aug 18, 2004, 09:45 PM
MV_FLYER is offline
Find More Posts by MV_FLYER
Nebraska
Joined Jul 2003
If money is not an issue, go to www.trcelectronics.com and look at the Cosel 600 (or higher) watt PBA series power supplies. These are small, powerful switching supplies. I use the PBA600F-12 supply to charge 5S3P LiPos with two Astro 109 chargers.
Mike M
MV_FLYER is offline Find More Posts by MV_FLYER
Old Aug 18, 2004, 09:46 PM
Fayetteville, GA
Joined Oct 2000
Yeah...that's an option....but not as convenient as carrying one unit to the field with one bus bar...
Old Aug 18, 2004, 11:31 PM
Xlogic is offline
Find More Posts by Xlogic
Conyers, GA
Joined Nov 2001
Hi Jeff,
I've had some good success using 2 of these pc power supplies http://www.newegg.com/app/ViewProduc...148-007&depa=0
in parallel, they are 34a on the +12 volt side ( 2 in parallel should be good for 68a). I'm just charging 3s3p 6000mah but it kept tripping off my charger and I would have to start my car at the field to charge. Its cheap and light and has its own cooling fan built in.
Xlogic is offline Find More Posts by Xlogic
Old Aug 20, 2004, 05:41 PM
4cyclic is offline
Find More Posts by 4cyclic
United States, VT, Alburgh
Joined Jan 2004
You can try an IOTA power supply. I have an 55a and a 90a continuous 12 power supply. Great units and very light. You could charge 3 complete ION packs with the 90a unit.
J.L.
4cyclic is offline Find More Posts by 4cyclic
Old Aug 20, 2004, 06:03 PM
Fayetteville, GA
Joined Oct 2000
XL...
Got a link?
Old Aug 21, 2004, 09:11 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Jeff, get a real 13.8V power supply:
www.astroncorp.com
or
www.ict-power.com
or
http://www.mfjenterprises.com/index.php
Are you looking for a switcher or linear supply? If you can deal with the weight of linear supply look no further than Astron. The Astron will last a lifetime.
Here are some reviews the eHam.com
http://www.eham.net/reviews/products...7a2f4e7f53128c
Ohmic is offline Find More Posts by Ohmic
Old Aug 21, 2004, 09:16 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Search google for MAAS/Manson SPS9600 (60A unit)
Lightweight (5.8kg/14pounds)
I got its littlebrother SPS9400 (variable 3..15V/stabilized 13.8V/40A max) which can be had for 160-200Euro.
Weight is 7pounds.
Haldor is offline Find More Posts by Haldor
Discussion 12V chargers & power supplies earthcrawler Batteries and Chargers 2 Feb 22, 2007 09:02 PM
Yippee! New Product posted on JustGoFly - Digital Power Recorder 50 amp + VIDEO JustGoFly Vendor Talk 0 Jun 22, 2005 09:00 PM
GWS EDF-50 Power Supplies? David A Ramsey Electric Ducted Fan Jet Talk 3 May 03, 2003 07:07 AM
Schulze Chargers & Regulated Power Supplies GBR2 Power Systems 5 Jan 02, 2002 09:42 AM
