Old Aug 18, 2004, 10:25 AM
EddieNewYork is offline
Find More Posts by EddieNewYork
EddieNewYork's Avatar
Los Angeles, CA
Joined Apr 2004
What do you keep your Lipos in?
My first Lipo battery will be coming to my house soon, and I'm a little nervous. I would like to know what you guys put them in when your not using them?
EddieNewYork is offline Find More Posts by EddieNewYork
Old Aug 18, 2004, 10:32 AM
wattman is offline
Find More Posts by wattman
wattman's Avatar
Evansville Dress Reg., Indiana, United States
Joined Jun 2004
Well after all I have read posted , reference's these lipos.........I now use a metal ammo can that seals with a gasket and 4 latches , maybe not the best , but the best I have handy , I feel better about the storage now .
wattman is offline Find More Posts by wattman
Old Aug 18, 2004, 11:11 AM
rmasonjr is offline
Find More Posts by rmasonjr
<burp>
rmasonjr's Avatar
Brookhaven, Mississippi, United States
Joined Mar 2002
I use a clay flower pot...
rmasonjr is offline Find More Posts by rmasonjr
Old Aug 18, 2004, 11:19 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
I keep them in soup cups while charging and store them in a portable metal parts drawer 24 inch long and 3 x 5 inches high and wide, old parts bin for $2
hall woo is offline Find More Posts by hall woo
Old Aug 18, 2004, 11:32 AM
Los Angeles, CA
Joined Apr 2004
Good variety so far... Thanks
Old Aug 18, 2004, 12:11 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Sentry fire safe from walmart $17.00, to charge them and a Brinks security box to transport. Do a search and you will find these two very popular.
POWER
power is offline Find More Posts by power
Old Aug 18, 2004, 12:13 PM
Andy McCowan is offline
Find More Posts by Andy McCowan
Mmmm.
Andy McCowan's Avatar
Selkirk, Scotland.
Joined Jun 2001
I use a Sentry Firesafe, seems to be a popular choice this side of the Atlantic, it is just slightly larger than your average transmitter case. I am sure there must be similar products on sale in the US.
Andy McCowan is offline Find More Posts by Andy McCowan
Old Aug 18, 2004, 12:14 PM
Mmmm.
Selkirk, Scotland.
Joined Jun 2001
Oops, seems Power types faster than me!
Old Aug 18, 2004, 12:30 PM
Los Angeles, CA
Joined Apr 2004
Thanks you guys, Is this a good one to buy for charging, carrying, and storing?
Also, does this mean if it the battery explodes inside of it, nothing will happen on the outside, as longs as it's closed and locked?
My main concern is... I'm worried about when I'm not home, should I just leave this safe in the fireplace when I go out?
Old Aug 18, 2004, 12:53 PM
Wiseguy is offline
Find More Posts by Wiseguy
Unsafe at any speed
Wiseguy's Avatar
United States, OR, Hillsboro
Joined Jun 2003
I have a pretty similar fire safe to the one you just mentioned...it's heavy, but it does the job alright and my roomates aren't worried that I'm going to burn our dorm down while we're out.
And if a battery goes while it's in the safe, you're probably fine. There won't be open flames spewing out of it (in all liklihood) and I haven't heard of any cases of li-poly's going up in smoke after they had just been sitting around minding their own business for a while. Every instance of an explosion I've heard of has been either during or right after charging or discharching. If you fly your plane and go home with it, by the time you're back if it hasn't already blown up I'd be confident that it's not going to (as long as you don't short it out at some point afterwards)
If you've got the thing in a safe, you should be fine. Maybe if you want to play it safe don't leave the safe near some candles and curtains, but I'd say leaving it in a fireplace is a little extreme. On a table or on a floor somewhere should be perfectly alright in that safe.
Wiseguy is offline Find More Posts by Wiseguy
Old Aug 18, 2004, 02:50 PM
T_Hartigan is offline
Find More Posts by T_Hartigan
T_Hartigan's Avatar
Oak Harbor, Oh
Joined Jun 2001
I charge mine in an old safe that the lock was removed from. I run the cord through the hole. The safe is about 12" cube inside. I believe it has a 1 or 2 hr fire rating.
I live in the country, so I fly in my backyard, but will have to get something if I want to travel with them. I don't think I will ever field charge.
Tim
T_Hartigan is offline Find More Posts by T_Hartigan
Old Aug 18, 2004, 03:35 PM
samcrismon is offline
Find More Posts by samcrismon
Apache Junction, AZ
Joined Mar 2004
I use a tin baking dish from my wife's kitchen. So far, she has not missed it.
samcrismon is offline Find More Posts by samcrismon
Old Aug 18, 2004, 03:47 PM
SharksTooth is offline
Find More Posts by SharksTooth
Aerobatic Extremist
SharksTooth's Avatar
United States of America For Which We Stand!
Joined Jan 2004
An ammo can. If it'll contain 1000 7.62 rounds, it'll contain a Li-Po. It also have a seal on the lid, and a locking latch that cannot open unless the user opens it. I charge them outside, and store them in my shop in the ammo can away from flammables. If you want to be sure packs are totally isolated. Put sheetrock dividers inside the ammo box. Sheetrock will not burn...ok, well except for the paper surface, but the rock cannot burn through and will protect the other battery. I use a 7.62mm ammo can, but you can find bigger ones if needed. A 50,60, or 46 caliber would be much bigger. You can find these at flea markets and mililtaryt surplus supply houses. Hope this helps you.
SharksTooth is offline Find More Posts by SharksTooth
Old Aug 18, 2004, 04:03 PM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
Charge:
Home charge: I charge in a small fire safe from Walmart (heavy bugger) in my basement work shop. Smoke detector active and a fire extinguisher handy.
Have only charged in the field once so far -- and that was during a fun fly (more flying than normal) ...
Storage:
I Store in my plastic caddy that I take to/from the field. As we know these cells don't spontaneously start to burn, so I store them the same way I do the NiMh/Nicd batteries....
rclark is offline Find More Posts by rclark
Old Aug 18, 2004, 04:46 PM
kmarchng is offline
Find More Posts by kmarchng
Corvallis Oregon
Joined Mar 2003
I charge in my gas barbecue on the patio (it's off of course :-). I figure that it's pretty fire proof.
Storage is in a waterproof ammo can on the same patio.
Keith
kmarchng is offline Find More Posts by kmarchng
Discussion What do you store your LiPo batteries in? dougaustin Batteries and Chargers 5 Aug 30, 2006 03:27 PM
What do you keep in your car? bubbahotep Foamies (Kits) 6 Oct 22, 2005 07:14 AM
Where do you keep your LiPos ? raymcm Batteries and Chargers 23 Jul 08, 2005 07:22 PM
what is the farthest you had your CG in a zagi thor4944 Foamies (Kits) 2 Feb 12, 2003 08:21 PM
Can some one explain the C in charge rate? And what do you charge your He-cell at? rspiegel Batteries and Chargers 10 Jan 08, 2003 09:50 AM
