Old Jan 31, 2002, 11:46 AM
Coyoteair is offline
Find More Posts by Coyoteair
Qaz52
Coyoteair's Avatar
Joined Oct 2001
A Question About Slow Charging New NiMH Batteries?
As the formula goes or as I understand it...
Capacity X 1.6 / Charger ma = hours needed to slow charge a new NiMH battery...
Also given that you charge any battery at no more than C/10. Using these formulas you could easily slow charge a small 720ma battery for almost 24 hours...
Two questions...
1. Where do you find a charger that will charge at such low ma as 10, 25 or even 50 ma?
2. What about voltage? What's going to be the difference in slow charging a battery at 4 .5 volts of 9.5 volts?
Thanks for your input and advise...
Coyoteair is offline Find More Posts by Coyoteair
Old Jan 31, 2002, 12:02 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Hi,
I and several others that post use a Digipulse from Radical RC it will charge 6 batteries at a time at 10 to 150 ma in 10 ma increments after setting charge is automatic and shuts off in 16 hours and goes to trickle. I don't even use my field charger anymore as it was too hard on my batteries and caused some battery problems. I keep several packs of each type and just take a bunch with me to the field and don't worry about field charging anymore. The charge sets the charge rate for the number of cells and will do 1 to 8 cell packs. You can do larger packs but you have to run them through 2 cycles.... Works for me!
boomer
boomerace is offline Find More Posts by boomerace
Charging New NiMH batteries mahonetd Batteries and Chargers 5 Aug 25, 2004 08:44 PM
Slow charging new NiMH packs dstout Parkflyers 7 Aug 19, 2003 03:11 PM
Slow charging new batteries rayb VOA Flyers of West Chester Ohio 2 Jul 31, 2003 09:00 PM
Slow Charging New Small Battery Packs E-Challenged Scratchbuilt Indoor and Micro Models 9 Apr 24, 2002 11:25 AM
Slow charging new Nimh's. rob barham Parkflyers 2 Feb 11, 2002 07:45 AM
