Old Aug 17, 2004, 06:40 PM
LexTalionis is offline
Find More Posts by LexTalionis
Bubble Head SSN 762
LexTalionis's Avatar
Austin Bergstrom, Texas, United States
Joined Apr 2004
Question
Got a 12VDC 13A OP Server Power Supply, but only 5VDC OP?
Hey Everyone,
I have just aquired a 12VDC 13A O/P Server Power Supply to supply power to my DC field charger. I can only find + 5VDC O/P on the molex connectors. I'm assuming that something needs to be switch inside the P/S via a short across two of the molex connections?
Any ideas?
Lex
LexTalionis is offline Find More Posts by LexTalionis
Old Aug 17, 2004, 06:48 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Check the threads on PC power supply. There is a sticky also
hall woo is offline Find More Posts by hall woo
Old Aug 17, 2004, 07:24 PM
Bubble Head SSN 762
Joined Apr 2004
Will do thanks...here's a picture of the molex-type connectors:
I think it's an ATX style P/S (NO EXTERNAL SWITCH). It came out of a server that had hot-swappable power supplies, so the moles connected to a back-plane. P-1 connector has the following:
yellow: 1 wire
purple: 1 wire
white: 1 wire
grey: 1 wire
red: 5 wires
black: 7 wires
P-2 connector has:
yellow: 2 wires
red: 3 wires
black: 6 wires
I found this PAGE detail info on how to turn on the P/S but I can seem to translate the procedure to this P/S. Sounds like I need to jumper +5V (which I've found on several nodes) to "Power Good" which he says is normally orange, but I don't have orange. I tried to jumper +5V and the purple wire, but the P/S didn't seem to turn on and made a high pitch whine sound.
When I power the supply with 115VAC nothing happens...no fan...nothing.
Old Aug 17, 2004, 07:54 PM
tallflyer is online now
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
help
cAN YOU TAKE A PICTURE OF THE POWER SUPPLY ITSELF S I CAN SEE THE WRITING ON THE CASE..
THIS WILL TELL ME WHAT i NEED TO HELP YOU!
tHANKS!
tallflyer is online now Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Old Aug 17, 2004, 08:48 PM
Bubble Head SSN 762
Joined Apr 2004
Okay...here you go...thanks!
For Sale 120vac to 12vdc 40amp output PYRAMID POWER SUPPLY drakelgd Aircraft - Electric - Helis (FS/W) 1 Jul 11, 2005 05:12 PM
For Sale 120vac to 12vdc 40amp output PYRAMID POWER SUPPLY drakelgd Aircraft - Electric - Airplanes (FS/W) 0 Jul 09, 2005 08:01 PM
found an intresting power supply but it has to much wires? eran_k Batteries and Chargers 2 Jan 30, 2005 03:24 PM
Server Power Supply theoxx DIY Electronics 2 Jan 10, 2005 03:04 PM
Got a new 2.5amp wall Power Supply, Need Help! Suntzu Batteries and Chargers 24 Dec 15, 2004 04:51 PM
