Closed Thread
This thread is privately moderated by jefferyj, who may elect to delete unwanted replies.
Old Aug 17, 2004, 06:25 PM
jefferyj's Avatar
Inwood West Virginia
Joined Apr 2003
Trader Rating: 25
FS - Nitro Evader ST RTR !!!NEW!!!
This is a Brand New Nitro Evader it has never been ran.
This is the 1/10 scale glow powered, radio controlled, rear wheel drive
Duratrax Nitro Evader off-road ready-to-run stadium truck.
FEATURES: Chassis:
7076 T-6 blue anodized aluminum, 0.12" (3mm) thick
Drive: Rear wheel drive
Drive Type: Gear driven
Engine: .18 (3.0cc) two stroke Duratrax pull-start with two needle rotary carb, heavy duty connecting rod, and dual ball bearings
Exhaust: Tuned pipe with header
Radio: Two channel AM pistol grip with trims, adjustable steering rate, battery LED, charge jack for optional NiCd batteries, two standard servos, and BEC receiver
Fuel Tank: 2.5oz (75cc), flip top cap
Clutch: Two-shoe
Transmission: Single-speed
Ball Bearings: Fully equipped, 16 total
Shocks: Four oil-filled, Rapid Tune aluminum body with coil-over springs, adjustable spring tension
Gearbox: Sealed
Differentials: Adjustable, ball type and conserve power
Brakes: Single disk, composite material
Front Tires: 2.2" (55mm) inner diameter, 2" (51mm) wide multi ribbed XTR-M2 rubber compound
Rear Tires: 2.2 (55mm) inner diameter, 2" (51mm) wide M2 bowtie tread
Wheels: White 1-piece plastic, dish style 2.4" (61mm) outer diameter 2" (51mm) wide
Body: Highly detailed pre-painted and trimmed stadium truck with decals, color scheme varies between radio channels
Suspension: Fully adjustable with multiple shock mounting positions
Camber Tie Rods: Adjustable
Steering Tie Rods: Adjustable
Steering: Bell-crank
Servo Saver: Included
INCLUDES:
One Duratrax Nitro Evader ready-to-run stadium truck with oil filled
shocks, .18 (3.0cc) pull-start engine, 2ch pistol grip AM radio
system, trimmed and pre-painted body, foam tire inserts, 15 tooth
32 pitch clutch bell, 60 tooth 32 pitch spur gear, instructions,
decals, air filter, glow plug, 8oz (250cc) fuel bottle, C size glow
starter and engine start-up video
$200.00 plus $10.00 Shipping
If you want pictures please send me your email and i will send you them
Paypal Only
Jeff
jefferyj is offline Find More Posts by jefferyj
Old Aug 19, 2004, 05:25 PM
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
Trader Rating: 148
Message removed by JohnM....
JohnM is offline Find More Posts by JohnM
Closed Thread
DuraTrax Nitro Evader ST RTR!! opinions?? radcast2 Nitro and Glow Power Cars 2 Jun 01, 2005 10:06 PM
Fs Duratrax Evader St Rtr miller_87 Cars - Cars and Parts (FS/W) 9 Jul 01, 2004 04:42 PM
FS/FT Evader ST RTR Buzzard Cars - Cars and Parts (FS/W) 7 Jun 12, 2004 10:47 AM
Evader ST rtr new gulio Cars - Cars and Parts (FS/W) 5 Aug 05, 2003 11:17 AM
Evader ST rtr new gulio Cars - Cars and Parts (FS/W) 7 Jun 20, 2003 09:26 PM
