Old Aug 17, 2004, 12:11 PM
ultralightbackpacker@ihatespamyahoo.com
Guest
n/a Posts
Help with lubing Gearbox/transmission etc
I have finished building a Savage SS. I have never built a car/truck
before and need some help on where to Grease/lube.
The transmission has been lubed a with the grease that came with it.
Am I supopsed to lube the main spur gear that attaches to the engine?
Anything else I should lube? Many thanks!
Old Aug 17, 2004, 08:11 PM
Mark Stevens
Mark Stevens
Guest
n/a Posts
Re: Help with lubing Gearbox/transmission etc
<ultralightbackpacker@ihatespamyahoo.com> wrote in message
news:7lc4i0ps1j6m1slcs0ojtu36kf90cn2bo7@4ax.com...
In short lube any moving parts that encounter friction...except the clutch
of course, it won't do any harm.
Regards..........Mark.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.737 / Virus Database: 491 - Release Date: 11/08/2004
Old Aug 17, 2004, 10:11 PM
mike
mike
Guest
n/a Posts
YOu don't lube the spur gear or the clutch bell - the lube would just
attract tons of dirt and cause premature wear.
Old Aug 18, 2004, 08:11 AM
Justin Mahn
Justin Mahn
Guest
n/a Posts
Uhh .. . NO!
Do not lube any gears that are not sealed in a gearbox. They will only
fling dirty grease all over your chassis and attract dirt.
Any gears that are sealed, like the inside of the diffs and tranny, you can
lube with good results.
Justin Mahn
remove Panties to e-mail
"Mark Stevens" <nospam@anywhere.com> wrote in message
news:cfu8th$lvk$1@news6.svr.pol.co.uk...
Old Aug 18, 2004, 06:11 PM
Bobby Shaftoe
Bobby Shaftoe
Guest
n/a Posts
You might want to avoid the brake too...
Hope that helps,
Bobby
Old Aug 18, 2004, 10:11 PM
Justin Mahn
Justin Mahn
Guest
n/a Posts
Justin Mahn
"Bobby Shaftoe" <NObobbySPAMsPLEASE@softhome.net> wrote in message
news:a9RUc.1779$CT4.665@newsfe3-gui.ntli.net...
clutch
wiseass. :-D
> Hope that helps,
> Bobby
Old Aug 19, 2004, 10:11 AM
Liam
Liam
Guest
n/a Posts
Hi,
The diffs need lubing with the gunk that comes with the kit but the centre
transmission / gearbox is designed to run dry - if you grease it the gear
change gets all messed up etc.
Cheers
Liam
Old Aug 19, 2004, 08:11 PM
Mark Stevens
Mark Stevens
Guest
n/a Posts
I think not lubing the brake is common sense which is why I did not mention
it, I also mentioned about not lubing the clutch. All cars pick up dirt and
muck elsewhere regardless of running (remember the exhaust does this very
well all over the chassis unless you have a dedicated exhaust tailpipe which
is fitted onto my Nephews car, simple mod but helps keep the car cleaner
that it normally is and looks great...!!!!
This car is normally cleaned after every session anyway so dirt and gunk is
not a problem in this case. ( I have a very keen and enthusiastic 15 yr old
Nephew who owns this car and knows the importance of looking after it, he is
the envy of his mates as his car is very relaible and runs consistent every
time....usually starting at first pull on the pullstart)....and how does he
know...??? ............from me............. 28 years in the Hobby, 24 of
those in R/C... and 20 of those flying Helicopters and there you lube
everything except the clutch....!!!!!
The point I was trying to make (with common sense of course) is any thing
that needs free movement, then lube it...(with the obvious exceptions I have
mentioned above).
Good simple after care after a days session will keep your model going well
for years.....as many of my models will show..I have 3 now aged 20 yrs plus
and still working.....another 2 will be 20 next year....!!!!
Regards..............Mark.
Version: 6.0.740 / Virus Database: 494 - Release Date: 16/08/2004
Question Need help with Cobri gearbox selection Microangelo Power Systems 4 Aug 01, 2006 11:38 AM
help with Olympus gearbox Glo4U Power Systems 1 Dec 11, 2005 08:32 AM
Need Help with Coverings, Irons, Blowers etc. pjm21b The Builders Workshop 1 Jan 24, 2005 04:13 AM
help with MPJet Gearbox! splatman Power Systems 2 Jul 14, 2004 09:44 PM
Help with MPJet gearbox 8060 (3.8:1 planetary for s400) Zhack Power Systems 6 Jan 25, 2003 08:48 AM
