Old Jan 31, 2002, 07:53 AM
Jon Andrews is offline
Find More Posts by Jon Andrews
Loveland, OH, USA
Joined Dec 1996
Brushless setup for use in BOTH logo10 & eLMH
I currently have an eLMH with a brushed setup. I am considering upgrading i the next 6 months to a logo 10/brushless. With this in mind I would like to know if there is a brushless setup that is suited to the logo that COULD be used on the eLMH initially. Obviously the size and weight of the two helis are quite different and the eLMH setup would be compromise, but is it possible?
My main objective is not to spend ~$300 on a motor/controller and then buy a logo and have to buy another brushless set-up. Iguess one other alternative is to buy a correctly sized motor for the eLMH and a controller that could be used for either this motor or the logo10 motor. I would then only have to buy/upgrade the motor and not the controller.
Anyone have ideas on this?
Jon.
Jon Andrews is offline Find More Posts by Jon Andrews
Old Jan 31, 2002, 08:30 AM
Motormike is offline
Find More Posts by Motormike
Deutschland, Baden-Württemberg, Ebersbach an der Fils
Joined Dec 2001
Hmmmmm,.....
if you would fly in the E-LMH with 10 batteries, there could be a chance....the motor would be a bit oversized for the LMH....whats the possible gearing rates in a ELMH? Or is it the Corona LMH? Do you want to fly with 10, 12 or 14 batteries in the Logo10?
Motormike is offline Find More Posts by Motormike
Old Jan 31, 2002, 11:21 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Or even 12 CP-1300's on the LMH which is about the same weight as 7 2400's. The problem is you need a 5mm shaft motor for the Logo and the LMH pinions that are easily available are I think - 32 pitch with an 1/8" hole. You can get 32 pitch gears with a 5mm hole from www.stockdriveproducts.com but they are somewhat expensive. I happen to have a few I could be talked in to selling in the range of 18-24 teeth, I may even have a 16 tooth but I'd need to look.
Chris True is offline Find More Posts by Chris True
Old Jan 31, 2002, 01:57 PM
JIMJAM is offline
Find More Posts by JIMJAM
JIMJAM's Avatar
Columbia, South Carolina, United States
Joined Feb 2000
I think you have 2 choices. Stay with brush motors, save up and just live with it or get a 10102Y/ D35H brushless setup and do it right. Enjoy the heli and maybe sell it and stand a better chance of getting some of your money back. I suggest that if you do go brushless and get your LMH right, KEEP IT. Alot of us have our Ecos,Voyagers,Logos as our primary high tech,fiddle alot,money eating rockets. But also a LMH/Corona as our low stress,kick up some dust,chop some flowers,built like a brick heli.
JIMJAM is offline Find More Posts by JIMJAM
Hacker Brushless motor for use in Eco 8 and Voyager E Malc C Electric Heli Talk 12 Dec 29, 2003 11:06 AM
Need a brushless setup for up to 12 Amp Niggo Power Systems 5 Nov 07, 2003 02:16 PM
WTB: Flying Wing and Brushless setup for GWS in San Jose, CA DerrickT Aircraft - Electric - Airplanes (FS/W) 1 Jun 14, 2003 12:26 AM
Can I use this brushless setup for a Logo 10? AndrewsJr Electric Heli Talk 5 Aug 21, 2002 06:43 PM
Mega/Jeti Brushless Setup for Logo10/eLMH AndrewsJr Electric Heli Talk 4 Feb 01, 2002 07:19 PM
