Old Jun 25, 2001, 11:38 PM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Difference between 6v and 7.2v speed 400 engines???
Can someone tell me the difference between these two engines? Which one is faster? Which one is more powerful, which one is cheaper, etc... I see a lot of people replacing 7.2v versions with 6v versions...
Jay
soholingo is offline Find More Posts by soholingo
Old Jun 26, 2001, 12:17 AM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
They cost about the same. They both put out about the same amount of power using the number of cells that they are intended for.
The 7.2 volt will put out about the same amount of power under 7.2 volts as the 6V version will put out using 6 volts.
HOWEVER, a 6V version will put out more power than the 7.2V version using the SAME voltage. But it also can not handle as much voltage as the 7.2V without burning up.
Basically, the 6V is limited to 8 cells or under, and the 7.2V version is limited to 9 cells direct or even 10 cells with a gear drive. You can exceed these numbers, but the motor will not last very long.
Shawn
Eflightpower.com
sf_247 is offline Find More Posts by sf_247
Old Jun 26, 2001, 11:37 AM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Thanks for the reply. So if I have a 7.2v engine and replace it with 6v engine, then I will gain more power, all things being equal?
Thanks this is great information...
Jay
Old Jun 26, 2001, 03:22 PM
vicman is offline
Find More Posts by vicman
Costa Messa, Ca, USA
Joined Mar 2001
You will get little more power assuming that you will use same amount of cells like you used with the 7.2V.
With 8cells you may shorten the life of the 6V but not drastically. And when they cost less then 10 bucks, who cares anyway.
Jay
vicman is offline Find More Posts by vicman
Old Jun 26, 2001, 04:50 PM
sf_247 is offline
Austin, Texas USA
Joined Mar 2001
Exactly. All things being equal, you will get more power with the 6V.
Shawn
Eflightpower.com
Old Jun 27, 2001, 08:03 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
So if I have a 7.2v engine and replace it with 6v engine, then I will gain more power, all things being equal?[/B]
FYI: Around here, we call them motors..
..a
Old Jun 27, 2001, 01:07 PM
jbourke is offline
Find More Posts by jbourke
Administrator
jbourke's Avatar
United States, OR, Corvallis
Joined Nov 1998
With the same propeller and voltage, the 6V will spin the propeller faster. The laws of physics demand that this requires more power. So the current draw is higher.
Both motors have the same torque limit since they are the same basic design. The 6V motor produces less torque per amp than the 7.2V. So that means that the 6V can handle more amps.
Because of the above factors, the 6V motor will typically be best for a performance setup and the 7.2V will be best for a more leisurely setup.
The situation becomes a little more confusing if you are going to play with the cell count or propeller when you compare motors. But, as a general rule ignoring some second-order losses, it is true that two motors of different winds but the same general design will have the same RPM and torque limits. The reason to choose one wind over another is not to get more power to the propeller, per se, but rather to choose how the power is taken from the battery pack. E.g. Do you want to run many cells at low current or few cells at high current? Either way, turning a certain prop at a certain RPM requires a certain amount of power. This is inescapable.
You wanted to know which motor is faster. The simple answer is that the 6V is faster, but this is categorically untrue if we remove most of the assumptions that people have. In reality, both motors can be equally fast assuming that we can change the battery pack and propeller to match the motor.
You asked which motor is more powerful. Again, the simple answer is the 6V, but this ignores the fact that the torque and RPM limits are the same which really means that they are equally powerful.
They are also roughly equivalent in price. Its the same basic motor. Its just that one has a different winding in the armature. Thats what makes one motor a "6v" and another a "7.2V".
The 6V will always be "faster" or "more powerful" than the 7.2V up until the point that the limits of the motor are reached. At that point the 6V will be really, really slow compared to the 7.2V.
Note that "6V" and "7.2V" are names and nothing more. Technically there is no such thing as a voltage rating for a motor. Aveox uses designations like 2Y, 3Y, and 4Y which are analogous to the 4.8V, 6V, and 7.2V specs for speed 400 motors. The difference is that Aveox names their motors by the number of winds, which is a far better way to describe the difference between them.
I know that you probably want a simple answer to the question, but the actual inner workings of electric motors is very intriguing and is useful information for a hobbyist.
Jim
jbourke is offline Find More Posts by jbourke
Administrator
Old Jun 27, 2001, 11:15 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Jim
Thanks for the blow out. That was exactly what I was looking for, and I appreciate the effort.
Jay
Old Jul 16, 2001, 02:51 AM
CrashLander is offline
Find More Posts by CrashLander
Joined Dec 2000
So, how does a 7.2 volt motor on 8 cells compare with a 6 volt motor on 7 cells?
CrashLander is offline Find More Posts by CrashLander
Old Jul 16, 2001, 08:05 AM
Shawn Palmer is offline
Find More Posts by Shawn Palmer
Schumacher USA
Tampa FL
Joined Jul 2000
exactly the same, but the airplane is "one cell lighter"
Shawn
Shawn Palmer is offline Find More Posts by Shawn Palmer
Old Jul 16, 2001, 08:54 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Not exactly the same.. you'll have less power overall, and different efficiencies. Run it thru motocalc and compare..
..a
Old Jul 16, 2001, 01:37 PM
swami is offline
Find More Posts by swami
swami's Avatar
Ursel, Belgium, Europe
Joined Jul 2001
Here in Europe we have those wonderful little white props for speed 400.
They are called "Gummiprops", and are made by Gunter Flugspiel.
They have great performance, are difficult to break (unless you fly at below zero temperatures) and cost only about 1.25 US$.
they are also great for speed 280 (4 Amp on 6 cells).
Anyone seen them in the US yet?
Dirk.
swami is offline Find More Posts by swami
Old Jul 20, 2001, 05:37 PM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
Hello,
The little white 'Gunther' props are available world-wide and distributed with Multiplex Twin Stars, Twinjets, Pico-Jets etc etc.
Soho - Put a 6v motor in the new Skyscooter . . .
Keven.
keven64 is offline Find More Posts by keven64
Old Jul 20, 2001, 10:50 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Kev,
that's my plan, I have 2 6v speed 400's. But after watching Dave go through the same trials that I did, I know it was the batteries that were the cause of my low power... But fully charged batteries and a 6v should keep me up for a bit...
Found WANTED ***7.2V speed 400 motors*** SRush99 Aircraft - Electric - Power Systems (FS/W) 12 Aug 04, 2007 10:26 PM
Falcon 400 vs Graupner 7.2v speed 400 Haydar Power Systems 8 Nov 28, 2005 08:56 PM
Identifying 6V vs 7.2V Speed 400 Motor bmizes Power Systems 4 Apr 22, 2004 09:57 PM
7.2v speed 400 vibration crocket Sport Planes 8 Jan 23, 2002 08:37 PM
Difference between 6v and 7.2v Zagi speed 400 thexfiles Electric Plane Talk 2 Nov 28, 2001 11:06 PM
