Old Aug 15, 2004, 07:29 PM
utflyer is offline
Find More Posts by utflyer
Sandy, UT
Joined Jun 2004
Can Some One Explain?
Can anyone explain what C/10, C/20, C/30 or C1, C10 means in regards to charging?
Dave
utflyer is offline Find More Posts by utflyer
Old Aug 15, 2004, 07:51 PM
FlyByMike is offline
Find More Posts by FlyByMike
Pittsburgh, PA
Joined Jan 2002
It's a way to describe battery charge and discharge rates. The 'C' is the nominal battery size - eg. a 650 mah bat has a 'C' value of 650 mah. DOH.
The number 10, 5, 1, 2, ... is a scaler. If the scaler is written as a divisor "/10", then C/10 means current flows at 1 tenth of C. Example: C= 650mah then C/10 is 65mah. Or C10 is 650mah times 10 or 6500mah (6.5 amps).
Hope this helps.
-Mike
FlyByMike is offline Find More Posts by FlyByMike
Old Aug 15, 2004, 08:24 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
MIke is right on-
To avoid confusion, the multipliers may be written as 2C, 10C, etc and the fractions could be written as 1/2C, 1/10C....etc.
hoppy is offline Find More Posts by hoppy
Old Aug 16, 2004, 07:32 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
They are used to rate the ability of a battery to serve up its energy and also to rate how fast you can charge it.
A 900 mah battery rated at 10C discharge can put out 9 amps or 10 X .9 amps
(900 mah is .9 amps)
That same battery may have a 1C, 1.5C or 2C charge rating so you would charge it at .9 amps, 1.45 amps or 1.8 amps depending on the rating. Charge it at 10 C and you can kiss it goodby and or start a fire, or worse.
Be aware that the batteries used for receivers and transmitters are typically rated at 1/5 to 1/10 C for charging. Motor batteries will be rated higher for charge. So don't charge your transmitter or receiver batteries like motor batteries. The cells are different.
For motor batteries:
Typicaly NICD batteries can be charged at 2-4 C. Some higher.
Typically NIMH batteries can be charged at 1-2 C. Some higher
Typically Lithium batteries are charged at .5-1 C. Some higher.
Best to know what you have and what it can take. Charge or discharge at too high a rate and you can weaken the cell, seriously damage it, start a fire or, in the case of the lithiums, cause an explosion.
be careful!
Outstanting information thread on Batteries - buy, build, use, maintain
http://www.radiocontrolzone.com/foru...threadid=79133
aeajr is offline Find More Posts by aeajr
Old Aug 19, 2004, 12:50 AM
utflyer is offline
Sandy, UT
Joined Jun 2004
Thanks all. The list comes through again. It all makes sense now.
Dave
can any one explain Diffuser Intakes to me? nativepaul Electric Ducted Fan Jet Talk 11 Sep 02, 2003 12:06 PM
Can some one explain the C in charge rate? And what do you charge your He-cell at? rspiegel Batteries and Chargers 10 Jan 08, 2003 09:50 AM
Can some one please recomend me the weigthless servo for the eco 8 tail ? ermit Electric Heli Talk 8 Sep 21, 2002 11:01 AM
can some one tell me? Jeff7 Foamies (Kits) 5 Jul 14, 2002 12:02 AM
can some one please help me ? wonder Power Systems 8 Mar 14, 2002 07:44 PM
