Old May 07, 2006, 10:02 AM
quietfly is offline
Find More Posts by quietfly
Joined Jul 2001
Do you have a diagram for Sermos parallel connection? The series connection has been working perfect for me. I connect two 6-packs together (my charger won't charge anything above 10 cells) and haven't had any problems. Thank you.
quietfly is offline Find More Posts by quietfly
Old May 08, 2006, 10:34 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Don’t have a photo; you need a “Y” on each side.
Two tails out of one connector, one for red side and one for black; the vertical leg goes to the charger.
Not sure how well it works to charge two packs NiXx in parallel?
jrb is offline Find More Posts by jrb
Old May 08, 2006, 05:33 PM
quietfly is offline
Joined Jul 2001
Thanks.
Old May 11, 2006, 08:00 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Here’s a new thread with a great source of good looking Six Packs!
http://www.rcgroups.com/forums/showthread.php?t=516101
Old Jan 18, 2008, 04:47 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Updated info about my Good Ole American Flyer: http://www.rcgroups.com/forums/showp...&postcount=290 .
Old Jan 19, 2008, 03:14 PM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Hi JRB,
Just wanted to say thanks for this post as it was the one that I stumbled across about the same time pulled down the Dynaflite 40 trainer that had been sitting in the garage rafters for about ten years. Being new to RC and (RCGroups) I read through this and thought "hey I can do this to my old trainer" as I was not real excited about gas and all that went with it. Long story short the trainer worked out very well and survived my self teaching process I have since moved on to foamies but have plans in the future for some A123's that should serve the trainer well!!
Brent
capt is offline Find More Posts by capt
Old Jan 19, 2008, 07:52 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Glad it helped capt!
Foamies are fun; but I really enjoy conversions.
These all use A123: 1/4 Cub, 1/5 Cub, FreeStyle 55" ws.
Old Aug 28, 2008, 08:57 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Found these notes and wanted to archive them with the article -- then not lost again!
RTF w/12xRC2000: 6#-13oz (109oz)
HOC w/12x8E: 31A, 12.9V, 406W
WA: 715
WL: 22oz/sq ft
60W/#
Old Sep 18, 2008, 02:29 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
And... with the power system chosen, if/when he decides to go LiPo... its just a matter of getting a pair of appropriate battery packs. 4S 5000 mah would work very well giving longer durration and lighter weight. 0.2 v nominal voltage change is negligible.
The reduced weight will be a huge bonus.
I just swapped out the original 7 cell 2000 mah from a Hobbico Superstar EP for a 3S 3700 LiPo. (and got a Castle 35 amp ESC... The Hobbico original won't take the higher voltage) Reduced prop so I get about the same watts as the original and the performance improvement is still amazing.
Not even brushless... yet.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Sep 18, 2008, 03:06 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Actually, performance isn’t bad with good set of 3S LiPos – prop up to 13x10.
But, best is A123-4S!
Even the LVC work very well with the A123s; not good for LiPos though. The A123s are seen as 11 NiXx which set the LVC or 8.8 volts (11*.8) – 2.2 volts for the A123s very safe.
And the A123s can be recharge quite quickly; in less than 7 minutes at 20amps!
Old Sep 18, 2008, 03:22 PM
Joined Mar 2005
I chose to suggest 4S LiPo because nominal voltage is almost the same as the 12S NiXX
Same prop... almost the same amp draw.
I'm just starting to deal with A123 and LiFePO4... Stuck 5S2P Ryobe pack into a 1/6 Sopwith planning to turn a 14 X 4 or 14X5 prop appx 9000 rpm. (KV of the motor chosen says 10,800 at 18 v)
Old Sep 18, 2008, 04:21 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Most of my fleet is on A123s: Cubs (1/5 -- 5S2P & 1/4 -- 10S2P -- nearly 20minutes), other 40s on 6S (exactly same as 16NiXx or 5S LiPo), T-33 and American Flyer on 4S. and Mustang and Velox in 8S.
Old Aug 21, 2009, 02:29 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Bit of an update:
A motor with a Kv in the mid 600s is a good way to go -- i.e. a E-flight Power 46 BL.
Closer to 700 would help you use a 3S pack.
The Jeti 45/3 and its speed control flew my Good Ole America Flyer great on a pack of A123-4S.
Old Aug 27, 2009, 02:35 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
A bit more of an update:
Used the following motor and speed control in my SNJ flying on A123-6S w/13x10 – 33amp; also used the ESC in my Sundowner 50 w/E-Flite 46 BL – both fly using the ESC’s BEC:
TR 42-60C 500Kv Brushless Outrunner
http://www.hobbycity.com/hobbycity/s...idProduct=6231
TURNIGY Plush 60amp Speed Controller
http://www.hobbycity.com/hobbycity/s...eed_Controller
Here’s the link for their 40 ESC -- TURNIGY Plush 40amp Speed Controller:
And a couple higher Kv motors that would work in a 40 trainer:
TR 42-50A 700kv Brushless Outrunner / 720W
http://www.hobbycity.com/hobbycity/s...trunner_/_720W
TR 35-48-C 800kv Brushless Outrunner Eq: AXi 2826
http://www.hobbycity.com/hobbycity/s...r_Eq:_AXi_2826
Old Apr 13, 2010, 11:07 AM
Geo1 is offline
Find More Posts by Geo1
Geo1's Avatar
Joined Mar 2008
Hi all just wondering
I have a pt-40 with a 40 I never finished , if I got a TR4250A-700 what engine mount do I need to get it in the front of that plane if the metal one from the manufacturer is still in there ?
Would a 3600mAh 4S 30C Lipo Pack be a good one to power this plane for about 10-12 minute flights ?
and which prop ?
Geo1 is offline Find More Posts by Geo1
Convert your Glow-Trainer - Complete package msmith Aircraft - Electric - Airplanes (FS/W) 6 May 02, 2005 04:31 PM
Convert 5LB glow 3D Bipe to Electric-How?? Rcpilet Power Systems 12 Apr 24, 2005 06:16 PM
How to convert MPG2 into MPG1 or AVI.. Haldor Life, The Universe, and Politics 4 May 12, 2002 07:29 PM
How to convert from fuel to electric mikeb33 Electric Plane Talk 3 Nov 01, 2001 06:16 AM
Glow to 400 speed How to convert Jaymz007 Electric Plane Talk 10 Jun 06, 2001 12:29 AM
