Old Sep 09, 2004, 08:43 PM
BEA flyer is offline
Find More Posts by BEA flyer
Concord, MA
Joined Jun 2002
Let me see if I can find a picture to post later. The plane was a Bimbonic Electronic Airplane of my own design about 4 1/2 lbs and 450 squares. I ran 11 1700 FAUP A cell Sanyos. This is probably more amps than you should run if you want a lot of charge cycles, but they are pretty lightweight.
There are a pile of planes that Northeast Sailplanes sells that would work well with this motor. The great thing about them is their weight and ability to swing a big prop with no gearbox.
BEA flyer is offline Find More Posts by BEA flyer
Old Oct 27, 2004, 03:48 PM
waltj2k is offline
Find More Posts by waltj2k
3DHobbyShop disciple
waltj2k's Avatar
Dallas Intl, Texas, United States
Joined Aug 2004
This was a great article. I am new to this hobby and I can see where ARF conversion is possible and can still be affordable. It looks like I came into the hobby at the right time. The Price/Performance point seems to be getting lower every 6 months.
I like the dual pack idea. I just ordered 2 8 x 2100 packs to run in my Zagi. Based on your findings I may be able to use these in a double pack setup.
Also thanks for the listing of planes. It's also what I have been looking for.
What I would love to see is a .25 conversion using a cheaper Speed 400 or 480 as opposed to brushless.
Walt
waltj2k is offline Find More Posts by waltj2k
Old Oct 27, 2004, 05:41 PM
Concord, MA
Joined Jun 2002
You need a bigger motor for a .25 plane. The 400 or 480 is a 1/2 A equivelant.
We used to fly H Rays with a 25 at 3 1/2 lbs and 400 or so square inches. this would be a speed 600 size plane, preferably geared. Cost about 20 and figure another 30 for a cheap decent gearbox. And only one 8 cell pack. Two would be too heavy
Old Oct 27, 2004, 11:37 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
.20 sized planes have been flown via Magnetic Mayhem on 8 cells direct drive and up to 10 with a gearbox.
Examples are the Happy Fly 20 and Frontier 20 from World Models; article in QF (SEM). Here too??
10 cells and a geared Endo can get you a larger plane .30 for sure; Carlos seems to like it in two Machs from WM:
http://www.rcgroups.com/forums/showthread.php?t=215044
http://www.rcgroups.com/forums/showthread.php?t=225134
The Hobbico SuperStar EP is also worth considering; understand there’s a new wing w/ailerons now: http://www.rcgroups.com/forums/showthread.php?t=112961 .
But none of the above are Two Six Packs.
jrb is offline Find More Posts by jrb
Old Nov 16, 2004, 01:19 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
24 cell 3S8P 9200ma Li-Ion DuraPlane
I have used a Duraplane with Jet 30/3 12/6 prop to test new 50 cent surplus cellular phone Li-Ion prismatic Qualcomm TXBAT033 batteries.
The $12 1 HP 24 cell 3S8P pack weighs 2 1/2 LBs
The trainer does Touch 'N GOs for over half hour and takes off in 10 feet at 45 degree , a neat short take-off and land plane, weighs about 7 LBs
hall woo is offline Find More Posts by hall woo
Old Nov 28, 2004, 07:55 AM
meridian610 is offline
Find More Posts by meridian610
Joined Nov 2004
Jim,
Thanks for your excellent explanation.
Would you share with us more of your non “plug and play” geared recipe that you’ve been using for flying forty trainers?. (As you mention: more elegant & efficient).
Charles
meridian610 is offline Find More Posts by meridian610
Old Nov 28, 2004, 02:01 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Below are links for more info; the two geared solutions that were listed in the article, my gallery, and the successful systems posting where other geared set-ups can be found.
The “brushed” system is kind of plug and play in that once again all of the parts/components can be obtained from a LHS. Its economical and fairly capable, again using 12cells (two six packs).
With respect to “more elegant & efficient” my meaning rely refers to matching a prop to the plane’s mission and getting the most from a motor and pack. In general larger props and running an electric motor at higher rpm is more efficient, to get there take a more elegant solution; the heart of which is a variable ration gearbox.
By being able to vary the ratio of the gearbox you can better match the motor to the prop needed for the load/mission. Just like a transmission in a car.
Two gearboxes that do this are the Great Planes GD-600 ( http://www2.towerhobbies.com/cgi-bin...&I=LXSL79&P=ML ), and my personal favorite the MEC SuperBox ( http://www.modelelectronicscorp.com/ ).
The GD-600 useable pinion range is 10T to 20 (something) with 1/8” shaft motors like 05/S500/S600/550. A great 10cell combo was developed by Gary Wright and uses the Kyosho Endoplasma.
For more than 500watts and a lot more ratios and pinion shaft diameters (1/8, 3/16, & 5mm) go with the MEC.
Fixed gear ratios (i.e. planetary boxes) limit prop selection in much same way as a direct drive solution.
Brushed: http://www.rcgroups.com/forums/showp...92&postcount=4
Brushless: http://www.rcgroups.com/forums/showp...39&postcount=1
Gallery: http://rcgroups.com/gallery/showgall...500&ppuser=497
Successful systems: http://www.rcgroups.com/forums/showthread.php?t=203529
Old Feb 24, 2005, 11:01 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
That last grade hurt; think it was a zero .
Old May 13, 2005, 04:59 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
3700s & SPT
My Two Six Packs of Zapped and Pasted GP3700s in MEC SPTs arrived yesterday and are looking great! (Model Electronics Corp, Solderless Power Tubes: www.modelelectronicscorp.com )
C/10 equalizing charge over night, resting during the day, and then a 5amp Peak and they're better than 3300s configured the same way; will get even better with a few cycles under their belt – cycling them now.
A bit larger (diameter) than the GP3300s, the GP3700s squeeze into the SPTs; looks like Pete trims a bit of the bottom shrink to be sure of getting good contact.
Used my Omega ( http://www.rcgroups.com/forums/showp...48&postcount=3 ) for the static tests listed below; data is HOC (hot off charger):
SPTnGP3700sZ&P: 33amps, 7.2volts, & 234watts
SPTnGP3300sZ&P: 32amps, 7.2volts, & 225watts
SMC GP3300: 30.8amps, 7volts, & 208watts
SPTnP3000sZ: 26.6amps, 6.3volts, & 169watts
DuraTrax RC2000s: 26.6amps, 6.3volts, & 169watts
More capacity and power; looking forward to using them in Rick’s Eagle 2, and in my American Flyer & Omega.
Pete’s also got an A size SPT for GP1100s & 2000s; another very good cell.
Beyond the Tootsie Pops I found a new MEC Logo in the box; it’ll look good on a model.
Old May 15, 2005, 05:02 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Fixed the links.
Old May 17, 2005, 02:51 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Here’s a scan of the new log; decal is clear it’s the backing that is yellow.
Old Feb 18, 2006, 10:40 AM
quietfly is offline
Find More Posts by quietfly
Joined Jul 2001
Could you post a diagram of a series harness for two 6-cell packs?
quietfly is offline Find More Posts by quietfly
Old Feb 19, 2006, 07:44 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
The Sermos/Anderson Power Pole connectors allow you to do it w/o a harness; a Dean’s harness is pretty straight forward: connect the red and black from the two pack together in series, and the other red blacks like a pack.
Old Feb 21, 2006, 09:29 PM
quietfly is offline
Joined Jul 2001
Nice looking series pack. Thanks.
Old Feb 26, 2006, 12:37 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Here’s a shot of a series harness; though it goes from packs with Deans to ECS/Charger with Sermos/Anderson PP.
Convert your Glow-Trainer - Complete package msmith Aircraft - Electric - Airplanes (FS/W) 6 May 02, 2005 04:31 PM
Convert 5LB glow 3D Bipe to Electric-How?? Rcpilet Power Systems 12 Apr 24, 2005 06:16 PM
How to convert MPG2 into MPG1 or AVI.. Haldor Life, The Universe, and Politics 4 May 12, 2002 07:29 PM
How to convert from fuel to electric mikeb33 Electric Plane Talk 3 Nov 01, 2001 06:16 AM
Glow to 400 speed How to convert Jaymz007 Electric Plane Talk 10 Jun 06, 2001 12:29 AM
