Old Jan 30, 2002, 07:03 PM
Dandi6065 is offline
Find More Posts by Dandi6065
DAve caNDI,& 5#'s of fury
Dandi6065's Avatar
Oscoda, MI :)
Joined Jan 2001
V tail vs. Conventional tail.
I have built the Bug from the RCM issue, and was wondering about adding a conventional tail, so I can use it with a standard TX, without mixing. Itís an older Attack 4 Am.
Can anyone tell me the difference in the two types of tails, and the different performance?
Dave
Dandi6065 is offline Find More Posts by Dandi6065
Old Jan 30, 2002, 07:27 PM
Gman2 is offline
Find More Posts by Gman2
Gman2's Avatar
land of permaban
Joined Jul 2001
v tails are lighter and have less drag. but
they have some inadvertant elevator effect when used as rudder and vica versa. They are harder to set up to correct angle of incidence. They need a computer radio. On the plus side they are out of the wing wash. They survive landings well. They can be made to break down nicely. They wont get snagged on brush.
Gman2 is offline Find More Posts by Gman2
Old Jan 30, 2002, 10:57 PM
Quacker is offline
Find More Posts by Quacker
ClearView rocks Phoenix& Dubai
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
V-tails also reduce weight and drag (lower wetted area). There is no "elevator effect." There are many small, inexpensive v-tail mixers that go inside the model, so you don't need a computer radio. Setting up a v-tail is no more difficult than a standard tail. It just looks different.
Q
Quacker is offline Find More Posts by Quacker
Old Jan 31, 2002, 01:55 PM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
... and some aileron wing V tail models have elevator-only, which needs no mixing at all (and saves the weight of a servo).
Bill Glover is online now Find More Posts by Bill Glover
Old Jan 31, 2002, 02:54 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
Scroll down the page and read The Great V-Tail Debate." Lots of good information.
SchiessCo is offline Find More Posts by SchiessCo
Old Jan 31, 2002, 02:56 PM
chlee is offline
Find More Posts by chlee
chlee's Avatar
Atlanta, GA
Joined May 2000
Additionally, if you accidentally snag a wing while landing (a common occurrence for me), the V-tail will lift up as the plane swings around, thereby saving your fragile tail feathers.
Lee
chlee is offline Find More Posts by chlee
Old Jan 31, 2002, 03:03 PM
Joined Nov 2000
... but in a hard landing a V tail can sometimes fracture at the root as it's not as strong as a continuous 1-piece tailplane. Easy to fix though!
Old Jan 31, 2002, 03:39 PM
Kevin Klejwa is offline
Find More Posts by Kevin Klejwa
Bosque Farms, NM
Joined Jul 2001
In my opinion the main advantage is that they don't get caught on objects when landing.
Kevin
Kevin Klejwa is offline Find More Posts by Kevin Klejwa
Old Jan 31, 2002, 05:54 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
but they look silly....
tic is offline Find More Posts by tic
Old Jan 31, 2002, 06:11 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
..no they don't; they look cool!
One question though; I understand that there shouldn't be any 'elevator effect' when rudder is applied, but doesn't the mere fact of having one up & one down just increase drag?
tim
tim hooper is offline Find More Posts by tim hooper
Old Jan 31, 2002, 06:24 PM
Joined Nov 2000
Probably no more than having one aileron go up and one down! I think a single surface would need more movement to get the same response.
Old Jan 31, 2002, 07:17 PM
tic is offline
tic
tic
thunderscreech
tic's Avatar
Joined Dec 2000
How comes we don't see more V-tails on realscale planes? the Beech bonanaza comes to mind.. nicknamed " the doctor killer" the FAA eventually put speed restrictions on the plane
Old Feb 02, 2002, 02:32 AM
sal is offline
sal
Find More Posts by sal
sal
NSP (Vermont)
Joined Aug 2000
V-tails have the same amount of drag as a conventional tail. T-tails have the least amount of drag because they have half the amount of junctions as a conventional tail meaning less interference drag. Since the vertical fin is capped by the horizontal stab and elevator, the vertical fin can be smaller because it is more efficient. Also T-tails tend to be in undisturbed airflow allowing for smaller horizontal components. This is a simplification and assumes that the respective tails are designed properly.
V-tails looks sleek and are great on slope soarers because they keep out of the grass on landing and are light weight so allow for overall lighter structure. This also holds true with TD sailplanes except a flying stab on conventional tail gives much better response at low speeds with out any elevator/rudder "coupling" . The T-tail is somewhat impractical on TD sailplanes due to complexity and weight. Also, since the launch method is typically a winch, the high angles of attack during launch usually blanks out the tail for the first part of the launch resulting in a positive pitch movement in the sailplane.
In an electric, because the weight is concentrated in the nose, the T-tail makes a good choice both structurally and aerodynamically. That isn't the whole explanation but it is a start.
sal is offline Find More Posts by sal
Old Feb 02, 2002, 06:06 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
A good summary, Sal..
..a
Old Feb 02, 2002, 08:39 AM
Dandi6065's Avatar
Oscoda, MI :)
Joined Jan 2001
Wow thanks all
Discussion t tail vs v tail vs conventional SPARTMAN Sailplane Talk 8 Nov 09, 2006 12:29 PM
V vs Conventional tail crashbuilder Slope 20 May 24, 2005 08:07 AM
V-tail vs. Conventional rudder/elevator. Sheriff Modeling Science 14 Aug 29, 2004 12:04 AM
Question V-tail VS regular Skiboy Hand Launch 12 May 25, 2002 09:48 AM
Todd's Tiny. Conventional or V-tail? smsgill Scratchbuilt Indoor and Micro Models 1 Jan 15, 2002 11:56 AM
