Cessna 172 Electric
I have a 36" wingspan Cessna 172 that I converted to speed 400 power. It weighs about a pound, and I can see that it will take off, but my 20-amp ESC is giving me problems. Whenever I throttle to full power, it dies on me, and I'm asuming it's because of an auto-cutoff feature that will prevent the motor from being over-worked. I am using a master airscrew 7x4 prop in direct-drive, and I have tried this with a 6x4 Zinger. Same thing happens, the motor cuts off. When I run the motor with "no-load", or no propeller, it doesn't cut off. If I use a smaller propeller, I'm concerned about not getting enough thrust. Am I actually using too "big" of a prop on the motor? The ESC and motor are from FMA direct. Another thing is that it takes half as much distance on the throttle stick to reach full power. Is this normal for electrics? By the way, I'm using an 800mah 5-cell AA rechargeable with Sanyo cells.
http://www.redwoodsoaring.rcplanet.c...age/page1.html [This message has been edited by e-sailpilot86 (edited 07-01-2001).] |
Wow, a C-172 of that size at 16 oz. That's great.
I wouldn't think your prop is the problem (though the 7x4 is too much for the typical speed 400 at 7 or 8 cells - mabey ok at 5 cells....) I'd go with a 6x4 to start with anyhow. Buuuut, i'm wondering about your 5 cell setup. You may be activating the BEC cutoff under load with only 5 cells. Especially if you are running old cells or have a bad cell in there. Let's hear what other more "learned" guys have to say here - you will get a better response but this is my first thought. Have you tried running with smaller cells like 600AE's? You could be lighter with 7 cells and have plenty of voltage to go around. It would be worth just a test to see if it will work that way. And a 600AE would do well in this setup with the higher cell count. As far as the FMA controller goes, I'm not familiar with that brand enough to say why it is giving you an apparent full throttle response at half stick. Have you gone over your radio setup to be sure you don't have any old program peramiters in there? Wadda you guys think? Ed |
Latest blog entry: The Gas Turbine Engine (with images)
Funny, when I went to post this there weren't any other replys! Now I've been redundant!
You can't say Ezoners don't try to help! Ed |
The plane is a Guilliows Cessna 172 skyhawk, 36" span, could easily use a geared speed 280. Has a wing area of about 150-200 sq in. It's a pretty plane, but takes a while to build. You could give it ailerons, they are pre-cut for the plane. The kit is about 20+ years old, and is a conversion. It is originally Control Line, or a free-flight. It just needs a little thought to make R/C. Lousy wood though, if you build one, reinforce the center wing panel, where it mounts. I don't know how to post a picture, sorry, explain to me and I will asap.
I made up a quick webpage with photos for those of you who'd like to see the plane. Here's the link: http://www.redwoodsoaring.rcplanet.c...age/page1.html [This message has been edited by e-sailpilot86 (edited 07-01-2001).] |
Hi e-sail. I also did a conversion of this plane last year. It flew really well 'til I decided to increase the elevator throws for better aerobatics. That's when I discovered the meaning of "high speed snap-stall-spin'. It bit the pavment from about 50' straight in. I'll get it back in the air one of these days.
Anyway, mine flew fine at 16-18 ounces and it too had a direct drive 7.2v speed 400. I used 7 cells of 600AE and a graupner 6.5x4 JU52 prop. I added the ailerons too. You can see details of it at this web page: Cessna Skyhawk 172 |
| Thread Tools | |
| GUILLOW'S CESSNA 172 SKYHAWK conversion to electric. | reznikvova | Parkflyers | 25 | May 03, 2008 12:56 AM |
| Great Planes Cessna 182, Electric Powered | PaulF | Scale Electric Planes | 32 | Dec 15, 2005 10:35 AM |
| Cessna 172 Skyhawk | Grave Digger | Scale Electric Planes | 0 | May 08, 2003 06:38 AM |
| Cessna 180 Electric Conversion | chiozza | Parkflyers | 4 | May 01, 2003 07:33 AM |
| I´m looking for a Cessna 172 3-view, enyone got one? | Philip Thulin | Parkflyers | 0 | Sep 07, 2002 08:10 AM |
