Old Aug 13, 2004, 06:15 AM
catfishchaser is offline
Find More Posts by catfishchaser
Near Muncie, IN.
Joined Aug 2004
Lite-ply vs. Balsa...
When constructing a hull assembly, can the keel and bulkheads be made of Balsa or is it best to make them from Lite-ply? Just wondering how much stronger the Lite-ply is than Balsa and if an all Balsa hull would be weak. Been doing some reading and have seen a few folks say that Lite-ply is no stronger than Balsa and harder to cut/clean up. Any opinions on building an all balsa hull for something in the 30" range?
catfishchaser is offline Find More Posts by catfishchaser
Old Aug 13, 2004, 08:38 AM
thething84 is offline
Find More Posts by thething84
If it ain't broke, fix it
Cambridge
Joined Aug 2004
i recently boat a boat. which is made from balsa and cardboard for the details on the deck. looking at the construction of it seems to be made with bout 3mm balsa sheet. and it is plenty strong enough. aslong as you don't expect to be hitting any iceburgs or anything. lol. providing ya strengthen it enough balsa should be fine i would think. mine has now been coated in fiberglass resin. which is tough and waterproofed the base aswell
thething84 is offline Find More Posts by thething84
Old Aug 13, 2004, 08:57 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
There are some grades of balsa that are stronger than oak.it is a very variable material,can recomend a small book called the story of balsa,if its still available.
olmod is offline Find More Posts by olmod
Old Aug 15, 2004, 12:26 AM
OhioMike is offline
Find More Posts by OhioMike
OhioMike's Avatar
Grafton, Ohio
Joined Sep 2003
I generally use lite ply/1/8" for stations/bulkheads when constructing a scratchbuilt hull. Planking generally is balsa in either 1/16" to 1/8" thickness. Ca'd to the stations as they lay. With this method, you generally will have some areas in the planking that need filled and i usually do so with the new light fillers. Then once the stern and bow blocks are faired in and everything is fair to my likeing, i then will proceed with the fiberglassing stage. Hull sanding/fairing and attachment of the bilge keels or any other items needing sealed in place by the final resin coat stage. Then removal from the building board and ultimately removal of those light ply bulkheads for the most part, except for those that will remain in place. Some people i know use the light ply for superstructure construction and then cover this with styrene(.020 to .040) or aircraft ply(1/64 to 1/32nd inch.). Gives a smooth surface and sharper corners. Hope this helps.
OhioMike is offline Find More Posts by OhioMike
Old May 18, 2012, 05:51 AM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
balsa all the way but i do use lite ply for my formers. balsa is just so easy to shape
RC Trainer plane is offline Find More Posts by RC Trainer plane
Question Density of "Aircraft" ply vs Balsa? TheSaint The Builders Workshop 8 Jan 09, 2007 11:51 AM
where to buy lite-ply (?) DanB Beginner Training Area (Aircraft-Electric) 2 Aug 23, 2002 12:36 PM
foam vs balsa construction... Arbo Power Systems 3 May 08, 2002 08:53 AM
Lite stick vs. Pico stick vs. Mini Max surfdog4 Parkflyers 13 Apr 15, 2002 02:27 PM
carbon vs. balsa weight kist2001 Power Systems 4 Aug 03, 2001 12:32 AM
