Old Jul 15, 2001, 09:27 PM
quietfly is offline
Find More Posts by quietfly
Joined Jul 2001
what gives more flight time/power?
Milliamps? or number of cells? A 6 cell 900Mah will give me about 15 minutes flight time. What if I wanted more flight time? More cells or more capacity?
quietfly is offline Find More Posts by quietfly
Old Jul 16, 2001, 01:49 AM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
well, it depends on the plane. But for the sake of argument, lets say a speed 400 sport plane. For more duration you could simply get a bigger capacity pack. If you want more power add a cell or two.
Also, for a longer duration, but with a slight reduction in power, run a 7.2 volt motor, instead of 6 volt motors, the 7.2 motor can handle more cells as well.
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old Jul 16, 2001, 05:39 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Capacity in mAh is how many mA you can draw for an hour. Power is rated in watts, but watts are (amps * volts), so for a given number of cells, volts are about equal so you can have more power by increasing the amp draw. The rate at which you draw amps determines how quickly you drain the mAh out of your pack - 1000 mAh = 1Ah or 1A for an hour. So if you have a motor/prop combo that draws 10A on however many cells, you will drain a 1000mAh pack in (1000mAh = 1Ah, 1Ah / 10A = 1/10th hour or 6 minutes). Power equals (roughly) the number of cells x the current draw in amps.
This is all covered in the FAQ, however..
..a
Discussion does a higher mAh on a lipo only give you more flight time or more power?? john-rcg Batteries and Chargers 26 Oct 09, 2006 07:54 AM
What config to change to get more flight time jyzoom Castle Creations 3 Nov 01, 2005 08:06 AM
What config to change to get more flight time jyzoom Micro Helis 8 Oct 27, 2005 01:16 PM
What is your total flight time? Super_Hornet Micro Helis 1 Feb 13, 2004 11:42 PM
What will it be to the flight time for different teeth pinion? Super_Hornet Micro Helis 7 Feb 12, 2004 11:58 PM
