Old Jan 29, 2002, 11:02 PM
Merlin1977 is offline
Find More Posts by Merlin1977
Joined Jan 2002
My first plane....set up ? on Tiger Moth
I just wanted to ask before I did anything......the instructions (if I am reading them correctly) say to "cut the wing joint cover along the cutting lines." Page 6 step 1. And well I dont see any cutting lines but I am pretty sure its telling me to cut the wing in half but I dont know why. I am not doing anything untill I am sure what to do. Please help Thanks
Merlin1977 is offline Find More Posts by Merlin1977
Old Jan 29, 2002, 11:13 PM
DaJudge is offline
Find More Posts by DaJudge
Fish & Fly
DaJudge's Avatar
Tyler, TX USA
Joined Jul 2000
Whoa Merlin. Put..the...scissors...down...NOW.
The wing joint cover is that yellow or white plastic piece that you'll see in the pic at the lower left corner of the page (fig. 10). It holds the dihedral of the lower wing and protects the area where the fuselage attaches.
Many of the Moth pilots here use a bit of ProBond or epoxy to stick the joint cover to the wing instead of the tape (which doesn't always hold well).
DaJudge is offline Find More Posts by DaJudge
Old Jan 29, 2002, 11:23 PM
Joined Jan 2002
That sounds alot better!!! I have read a lot about 5-Min. epoxy so I went down to walmart and picked up some. Its made by devcon ......same stuff right???....since I have already been a total dumbass I thought I might as well ask this now also. Thansk again!!!!!!
Old Jan 29, 2002, 11:30 PM
kansascloud is offline
Find More Posts by kansascloud
Checking the wind
kansascloud's Avatar
Aubry Township, Kansas South of KC.
Joined Jan 2002
On my second Moth
I'm building my second TM right now also. Let me know if you need any help. You can watch mine go together on a thread called Tiger Moth #2. You might get some ideas from things I learned from the first. You are gonna love flying this little airplane as long as you keep it out of the wind!
Devcon 5 minute is excellent. Glad you didn't butcher the wing.
kansascloud is offline Find More Posts by kansascloud
Old Jan 29, 2002, 11:31 PM
segal3 is offline
Find More Posts by segal3
Joined Dec 2001
5min epoxy...is...5min epoxy...which is...5min epoxy...just like...shoes, are shoes, are shoes. Different people make them.
I guess I should add that with epoxy you have 2, yes, 2 bottles that you mix together in equal amounts :-)
~Matt Segal
segal3 is offline Find More Posts by segal3
Old Jan 29, 2002, 11:40 PM
Joined Jan 2002
LOL Yeah I do have that part down. I just saw somethng in a hobby shop the other day that was much different looking. I just wanted to be sure before I melted the wing that I almost cut in two. I knew that didnt seem right at all but. This is my first time putting together anything like this so I have to ask a few completly moronic questions....sorry.
Spaulding is offline
Find More Posts by Spaulding
Dangerous
Spaulding's Avatar
LA
Joined Nov 2001
Do you have a Pepboys nearby? They have the best selection of epoxy I have ever seen. They have 60second epoxy that allowed me to build a moth in record time. They even have Titanium epoxy that is rated at like 2300psi.
Spaulding is offline Find More Posts by Spaulding
Old Jan 30, 2002, 12:44 AM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Merlin,
Use as little epoxy as possible. It is heavy, and can add a lot of weight if you are not careful. I used epoxy on my TM but I will use ProBond on my next foam plane. It is lighter and stronger, but it does take longer to dry.
Jeff
jeffs555 is offline Find More Posts by jeffs555
Old Jan 30, 2002, 07:40 AM
DaJudge is offline
Fish & Fly
DaJudge's Avatar
Tyler, TX USA
Joined Jul 2000
If you're going to go out and buy some adhesive for this plane, go to the hardware section at WalMart and get a bottle of ProBond. It's the best I've seen for strength and lightweight needs, plus it's completely foam safe.
Put a very thin amount on (with a brush or toothpick) because it will expand, especially if you mix a drop of water in with it before applying.
Discussion My first brushless set up Finally !!!! saucerguy Power Systems 4 Jul 14, 2006 07:29 PM
Question So I broke my first plane. Any advise on fiberglass? A_Langman Beginner Training Area (Aircraft-Electric) 32 Sep 15, 2005 12:28 PM
Help with my first AP set-up Dodgie Aerial Photography 11 Nov 04, 2004 03:44 PM
My First Plane - GWS Tiger Moth - A Newbie's Story The Enemy Parkflyers 562 Aug 09, 2003 02:24 AM
How to set up my first plane? dshuen Parkflyers 9 Nov 05, 2001 04:05 PM
