Old Aug 11, 2004, 03:18 PM
jimklein is offline
Find More Posts by jimklein
Minneapolis Mn
Joined Jan 2003
Yippee!
IFO owners thread #1
Hello, my name is Jim & I'm a recent IFO-aholic...
I am starting this thread as doing searches of IFO's leads to great ideas but not one continuous thread... (or if I'm wrong, please point me to the master thread...) I see there are other SlowStick & Unicorn threads so here's an attempt at starting an IFO (MK3/Mini/Trainer/Wild) one.
Please post your IFO pics & build & flight experiences & questions here...
jimklein is offline Find More Posts by jimklein
Old Aug 11, 2004, 03:28 PM
jimklein is offline
Minneapolis Mn
Joined Jan 2003
I am the proud owner of a Mini-IFO with the following mods...
-LensRC CDRom Motor 15T
-860 ThunderPower Battery
-Single front wheel system borrowed from Boomer
-Castle Creations 10A Brushless Speed Control
-.080 rod for the body so the rudder doesn't jiggle when going fast
-Direct control rods for the elevons instead of pull-pull
I bought it to cure the many times windy or Minnesota winter blues so I can fly indoors in a gym... & boy is it fun & manueverable in that sized area! Touch-n-goes, or "roll on the floor forever & pull up at the last second", & landings are great!
Old Aug 11, 2004, 04:51 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
How about some pictures Jim? Setup of my Mini same as Jim's except using 2S1P TP 640's and 340 Kokams! Insane aerobatics and Video on my website.
boomer
www.boomerseflight.com
boomerace is offline Find More Posts by boomerace
Old Aug 11, 2004, 05:33 PM
jimklein is offline
Minneapolis Mn
Joined Jan 2003
Here's a pic of our IFO's...
Old Aug 11, 2004, 05:34 PM
jimklein is offline
Minneapolis Mn
Joined Jan 2003
.. & some links to indoor movies...
http://mywebpages.comcast.net/jimklein814/dadifo.avi
http://mywebpages.comcast.net/jimklein814/miniifo.avi
Havin fun!!!
Old Aug 11, 2004, 05:51 PM
boomerace's Avatar
Joined Sep 2001
Jim,
Cool planes and cool vids! I sure wish we had indoor space here but at least weather isn't as bad as yours! Was Asst City Engineer for South Saint Paul, Aitkin County and Engineer for consulting firm in Olivia after graduation. So I remember the winters!
boomer
Old Aug 11, 2004, 07:09 PM
fwilly is offline
Find More Posts by fwilly
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
The first video on this page is the only one I have of my Mini. http://www.rcsites.net/fwilly/video.html
I never got any of it with the cdrom. Shortly after I put it on, I snapped the main bow, and after I repaired it, it never flew right again. I need to rebuild it.
fwilly is offline Find More Posts by fwilly
Old Aug 12, 2004, 07:34 AM
jimklein is offline
Minneapolis Mn
Joined Jan 2003
Wow... Those flying skills & a broken IFO??? Good luck getting it fixed soon!!!
P.S> Is your rudder moveable or does it just look like it's moving in takeoff?
Old Aug 12, 2004, 08:58 AM
fwilly is offline
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
Not sure why it broke. It was a pretty mild crash compared to some I have done.
Yup, it had a working rudder.
Old Aug 12, 2004, 09:30 AM
mattk0 is online now
Find More Posts by mattk0
mattk0's Avatar
United States, MN, Apple Valley
Joined Jan 2004
I'm glad to hear it's a moving rudder!! I was a bit concerned that you had a REALLY floppy rudder on takeoff! ;-) How is the rudder on the mini? I've considered putting it on mine, but afraid to add the additional weight...Does it give enough to make it worth it? (I guess I'd assume so, being it's a prettty large rudder)
mattk0 is online now Find More Posts by mattk0
Old Aug 12, 2004, 09:46 AM
fwilly is offline
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
I liked it with a rudder. It was very hard to hover, but there were other things that a rudder made possible. It could do climbing inverted flat spins really well. Harriers were easier with a rudder.
What it really needs along with a rudder is just a little side area. That would make it easier to hover. I plan on adding a little bit of side area when I rebuild mine. I was thinking I could build it with two center rods spaced the diameter of the carbon rod appart, and use the space in between to fit a removable covered circle of carbon. I figure the best place for it is somewhere around the CG.
Old Aug 12, 2004, 11:59 AM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Hey Boomer, I really like your LG mount! Question, where it is attached to the main boom, how is it done? Looks like a piece of tubing. Is it slotted and glued to the boom? The wheel mount looks like tubing or Shrink tube on the outside of the brace, which is it. Did you do the same on your T-IFO or did the stock gear with larger wheels work OK? Thanks for the great mod!
Pete
peterv is offline Find More Posts by peterv
Old Aug 12, 2004, 12:33 PM
boomerace's Avatar
Joined Sep 2001
Pete
Rear attachment is tubing slotted and wrapped and glued to the boom and then rod CAed in the tube. Rear brace has two fiberglass rods wrapped and glued to it which are spread for the crutch on each side of the wheel. From the center out wheel is drilled to fit the rod then the tube spacers then the crutch arm which is wrapped and glued to an aluminum sleeve. Aluminum sleeve probably isn't critical but it does allow some movement in shock landings as it allows the wheel assembly to flex up and down to better assorb the landing stresses without a twisting moment on the rear support crutch. I found it works better with the sleeves. the wheel assembly is then wrapped and CAed to each side of the bow just inside and in front of the LE.
boomer
Old Aug 12, 2004, 01:14 PM
jimklein is offline
Minneapolis Mn
Joined Jan 2003
I just thread-wrapped the angled piece directly to the body on mine & did the forked front-end like Boomers... Also created the forked piece but used the origional wheel by drilling it out & just drag the elevons on landing since my indoor site is short carpet...
But....
I do notice a flight characteristic difference from mine (with front wheel contraption) & my sons (no wheel, just catch landings)
Mine seems more inherently stable with the front wheel modification. (could be taken as a positive or negative)
Large true loops are way easy but I notice on inverted flight it now has more of a tendancy to want to right itself than my sons.
For me these are positives as I was thinking I wanted to use exponential on the transmitter to make it a little less sensitive overall, but the wheel mechanism has solved that & given me the ability to do great indoor touch-n-goes.
Boomer, do you notice the same thing?
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
Source for Kevlar thread and 1/4" CF? Sanman Hand Launch 5 Dec 06, 2004 10:03 PM
Aerobatic Thread 1 Norm Sport Planes 20 Feb 21, 2002 09:14 PM
IFO, 280, 4:1 box, how long does motor last? rktung Parkflyers 2 Jun 12, 2001 07:54 AM
