Here is a history link to the page on my site about her. You need to read the story of her crew fighting off 5 boat loads of Royal Navy Marines in the pitch dark with a hand full of very brave sailors....the Captain was a real hero...a movie should be made.
![]() http://www.orgsites.com/al/americanprivateer/_pgg4.php3 It's my understanding that she was taken to England inspected and drawings made of her so to copy her. She was then damaged coming in/out of dry dock having her back broke and had to be scrapped. Not a very fitting end to a great ship.
She a has a heavy metal, 20+ lb, ballast plate and wood spacer hanging under her via a couple of threaded rods that go all the way up through the deck. The hardest part about preping her is setting her on those rods at the same time. The ship isn't that heavy, but it is an ackward postition with all the weight extended and she will give your back a work out after a while.
Can the rods be put in from the top? Or, DanL suggested having them go through the ballast and have a lock-nut at the bottom, under the ballast - then you drop the rod in from the top (and just leave it there) and you can lean the cart back to put on or take off the nuts without reaching through rigging and other 'gotchas.' There's a little more to it than that, but I'm trying to be brief.
