Old Aug 10, 2004, 07:46 PM
JAM is offline
JAM
Find More Posts by JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
What paint should be used on balsa sheeting
Whats the best and lightest paint I can use to finish my Balsa sheeted P-51. Or are there some other ways to do this with out adding a whole lot of weight.
JAM is offline Find More Posts by JAM
Old Aug 11, 2004, 02:04 AM
tim hooper is online now
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
I'd go for a plastic film such as Solarfilm. Any particular reason why you'd plump for paint?
tim
tim hooper is online now Find More Posts by tim hooper
Old Aug 11, 2004, 07:10 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
I prefer filling the grain with light spackling first, then a traditional nitrate/filler mix, then nitrate, then color, then (if gloss preferred) clearcoated. All sprayed and wet-sanded between coats.
It takes a little time, but less than a good film covering.
If you are doing a camo scheme and don't mind a little grain showing, you can do it real light real quick - like these:
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Aug 12, 2004, 06:08 PM
JAM is offline
JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
Andy what brand of paint and type . Thanks
Old Aug 17, 2004, 03:23 AM
Virgil Kee is offline
Find More Posts by Virgil Kee
Kill Devil Hills, NC
Joined Jun 2002
What paint on balsa sheeting?
Andy, On your post you said, "I prefer filling the grain with light spackling first, then......"
Does the spackling ADHERE to bare balsa? I'll be doing this very soon, BUT hope that it works better than with my experience on using it to repair STYROFOAM! On the styro, the spackling does NOT adhere, curls up onto the back of my applicator (cut from an old credit card). I've tried thinning it with water, beer(!), WBPU, white glue (for strength), RC-56, etc., with no improvement.
Again, does the stuff STICK to the balsa? Also, do you thin it?
Virg.
Virgil Kee is offline Find More Posts by Virgil Kee
Old Aug 21, 2004, 11:57 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
It sticks just fine. Sand it lightly to take off the excess.
You got a PM too.
Andy
Site Sponsor
Old Aug 21, 2004, 03:00 PM
Dzlstunter is offline
Find More Posts by Dzlstunter
Dzlstunter's Avatar
Jacksonville, IL
Joined Dec 2002
Depending on how thin and weak the balsa is, you can thin spackling with water to a "slurry" solution--one you can brush on, but barely. You will have a thick coat, but you are going to sand it all off anyway, leaving only enough to fill the grain. Then very carefully (I use an airbrush) spray some sort of a dusting coat of primer or clear to "set" the spackling; I find that brushing will lift it our of the grain, defeating the purpose. Rough up a bit with very fine sandpaper (I use 400 wet-or-dry if I have any handy), then paint as thin a color coat as you can. This makes for a pretty lightweight finish. For electrics, I would spray acrylics. Good luck, Dzl
Dzlstunter is offline Find More Posts by Dzlstunter
Discussion What size of prop should be used w/ brushed 350 motor on my Slow-stick? kfc2 Parkflyers 10 Aug 12, 2008 07:01 PM
Grauper 12x6 CAM Folding Prop - what constants should be used? down_shift Power Systems 0 Apr 30, 2003 02:44 PM
Zapping small cells (500AR and 600AE). What voltage should be used? Erik Johansson Batteries and Chargers 8 Dec 31, 2002 09:47 AM
what paint can be used over testors enamel? bushpilotx1 Scale Kit/Scratch Built 1 Aug 31, 2002 07:37 PM
What prop should be on this ZAGI? snowman610620 Foamies (Kits) 1 Feb 22, 2002 06:42 PM
