It's as dangerous as putting a fuse between the battery and the ESC (with BEC). DON'T do it. |
Copenhagen, Denmark
Joined Apr 2003
Hi
I have a similar history as FreeFlier. I charged a 11s3p 6600mAh pack using a Schulze 636+ charger at 4A. Cell count was correct, the pack had less than 20 cycles, the pack had worked perfectly, the pack had no visible damage, the pack was never involved in a crach or mishandled by other ways, the pack was never overcharged or overdischarged. The pack was used in a Joker helicopter. But during my last charge the pack didn't come up to full voltage before a center cell started to whistle. At that time my charger had put more than 6Ah into the pack. At the time I noticed it the pack was warm and cells located in the center of the pack was swelling. I moved the pack outside very fast and couldn't do anything but looking at how the pack turned into a pile of ash during the next 5 minutes. 6 foot fire spikes kept comming out of the pack for 5 minutes as each cell got on fire. So be carefull. I have learned not to use lipo's again before I have a totally safe place to charge AND store my packs (iron box with bricks inside). I have also learned to favor packs which are built from a serie of parallel groups of cells (instead of paralleling series of cells). In such packs each group of cells tend to balance each other because cells in parallel will always share a common voltage. An 11s3p pack is normally built by paralleling 3 11s1p packs. So if just one cell is bad and end up with a higher voltage than the rest of the cells mishap is sure to happen sooner or later. So avoid packs like 11s3p, 11s2p, 10s3p where cells cannot geometrically be arranced in to parallel groups close to each other. Use instead packs like 12s3p, 9s3p, 10s2p, 5s3p and so on. Thomas |
Joined Jan 2002
jimsp,
the quote I used was abridged from Stew's initial post. In another part, he says:"Yes it did later occur to me that perhaps the pack should not have been placed in the water at that time, but the puffing., the odor, and liquid spots were quite unnerving, and rational thinking was at least a few minutes away..." I can sure sympatize with that. - RD |
Joined Jul 2004
Let's assume that after a crash a cell is dented or otherwise damaged externally. Instead of taking chances with it, a prudent pilot may elect to dispose of the cell. What is the correct method? Discharge it until it is below 3.0V (under no load) (or other voltage?), then submerge in saltwater, then puncture and re-submerge? I am asking in advance so that I know if/when the time comes... |
Walled Lake, MI, USA
Joined Feb 2000
The only way that every single Li-poly incident can be called user error or negligence is if every Li-poly user is expected to be on guard every second that any of thousands of possible incidents could cause a pack to fail catastrophically. This means always having every pack under close observation, or stored in a fire-resistant container where it cannot possibly cause any damage even if it does fail catastrophically. There is no tolerance for momentary lapses of attention, nor for any human error in this scenario. If you make a mistake that results in pack failure, then you're guilty of user error or negligence. Unfortunately, humans are imperfect and are guilty of numerous errors every day of their lives. Most modern products are designed to protect the user from common human error. Li-poly cells, as used in e-flight, are near the bottom of the list in terms of protecting users from common human error. Many people will not put up with the close level of scrutiny and care required to safely use Li-polys, nor should they have to. It's up to the industry to produce safer alternatives that provide more passive protection to users. It's been done with many other products that we use on a daily basis, and it will also be done for Li cells used for e-flight. |
Joined Jul 2004
(If the battery vents hope that the heat melts sand silicates into glass, then use glass to make jewellery, offer jewellery to spouse as a peace offering? )Seriously, what is the correct rational response? And after the battery has cooled down (assuming it would not "vent with flame"), what then (see my post immediately above)? |
Space Coast
Joined Oct 2000
Joined Feb 2000
Now, if someone had a videotape of a Li-poly pack sitting on the bottom of a glass bowl under 10 inches of water with flames and sparks shooting from the pack on the bottom up to the surface and out into the air, that would be an entirely different situation. With no proof as to whether the pack was under 10 inches of water or floating on the surface, any discussion here about the failure mode of Li-polys in water would be purely speculative. |
Joined Jan 2002
Well, that got the disposal done in a hurry and I don't fault it. - RD |
Joined Apr 2003
Ted Cooper's been MIA. Nobody knows where he's been, just right after his started testing new Lipos. Hope he is... survived and well.
Tojusi's question answered please!
I too have a pack gone south, I believe. Bought it used, a Kokam 3s 600mah Lipoly that was slowly loosing capacity. It was used to fly my FanTastic Models Gee Bee R1, pulling all of 2 amps. Last time used I was recharging at home and touched the pack after about 10 minutes on my Apachee 1500 charger and it had a hot spot on it. Unplugged immediately and ran outside with it. In my haste, I cut the leads off the pack, one at a time, of course, so now it sits in my back yard on a brick waiting for my next move. Cutting the plug off was not the right thing to do cause now I can't discharge it, the leads were cut off right at the shrink wrap covering. It cooled in a few minutes and has been out there for more than a week now, rain or shine. From the sounds of this thread, dropping it in a bucket of salt water doesn't seem to be the correct thing to do. Thought of taking my 22 and shooting a hole through it and standing back to see what happens, then dropping it in the bucket. Any ideas on what to do with this darn thing would really be appreciated. Tom
| Thread Tools | |
| Discussion Lipo loss caused by spark | 2lakea | Batteries and Chargers | 8 | Apr 29, 2006 05:16 PM |
