Old Aug 09, 2004, 02:34 PM
Nicke is offline
Find More Posts by Nicke
hem.bredband.net/b254298
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
Yippee!
Fireworks III build thread
Look what I picked up at DHL today!
It's the one to the right. The other one I picked up years ago.
Nicke is offline Find More Posts by Nicke
Old Aug 09, 2004, 02:36 PM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
The plane is a fireworks III, and it came really well packaged in austrian newspaper balls. I feel sorry for the guy wrinkling up the newspaper into balls, it was hundreds of them!!!
Old Aug 09, 2004, 02:38 PM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
And here's the contents.
I really hope I found everything necessary in all that paper, cause now I've thrown it away...
I'll post more as soon as I get started
Old Aug 09, 2004, 03:39 PM
greg morrison is offline
Find More Posts by greg morrison
San Francisco
Joined Jul 2000
It looks great. I want to order one of these myself but getting it here to the states is a very expensive proposition so I'm hesistant to pull the trigger at this point. I look forward to future posts re assembly/flying.
Greg
greg morrison is offline Find More Posts by greg morrison
Old Aug 09, 2004, 04:22 PM
averen is offline
Find More Posts by averen
Love my Pike Superior!
averen's Avatar
Austin, TX
Joined Jul 2003
I too have been contemplating picking up one of these! It's either going to be the Blaster, Fireworks III or the Osiris. I like the Fireworks III the best! Also the more expensive of the 3 and hardest to get here in the states...
Anyways...more pictures!
Jared
averen is offline Find More Posts by averen
Old Aug 10, 2004, 10:22 AM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
Ok, I actually did some "building" yesterday, but it was bedtime so i only posted the first shots.
I looked through the "building instructions", and it lost me completely. Looked throgh it a few times more, and decided to use it as a guide, but I'll be assembling it the way I feel suits me best.
So I started assembling.
The first step I decided was to mount the wing to the fuse. So first came drilling the mounting holes in the wing. The front hole was pre-drilled with 4mm bit, and the rear was pre-drilled a few mm down. So I only had to drill one hole, and there was no risk of slipping on the cf because of the pre-drilled groove (correct word?)
Old Aug 10, 2004, 10:25 AM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
I then taped the wing on the correct position on the fuse and drilled the rear fuse hole through the wing hole.
Then I put in a nylon bolt, to fix the wing even better to the fuse, and making sure the wing was straight on. Drilled the front hole. Voilą!
Old Aug 10, 2004, 10:27 AM
averen is offline
averen's Avatar
Austin, TX
Joined Jul 2003
mmmmm....carbon fiber pretty.
Looking good
Jared
Old Aug 10, 2004, 10:32 AM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
I then had a look in the manual, and found a page with parts that i thought might be useful to mount in the fuse, strengthening the wing mount.
The manual said something about a 2mm balsa part, which I could see no use for, other than getting the mounting bolt ply parts more easily into the fuse. I decided to skip that.
I drilled the ply parts, and ca:d a 4 mm nut on each. I then glued them in place into the fuse using epoxy. After that I realized that the balsa part might have been quite useful after all...
Old Aug 10, 2004, 10:43 AM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
To help me decide whether to put the flaperon servos in the pod or the wing, I put all the equipment in the pod, and taped the tail parts in place to get an approximate CG.
Now, was that crowded in there or what??? And I thought my slingshot pod was crowded. After this, I'd rather call i quite spacey.
This made me consider putting the servos in the wing, but then I'd have to put lead in the nose since the cg was quite far back. Sure, the tail wasn't sanded yet, but I think that might be compensated by the added weight of the linkages anyway.
So I'll give the pod mounted servos a shot. I just dont know where to put the receiver... in front of or behind the servos
Have a look at this crowded pod
Old Aug 10, 2004, 01:22 PM
MGerstgrasser is offline
Find More Posts by MGerstgrasser
Austria
Joined Oct 2003
Hi,
I also used a Schulze 8xx in my second FW3. If you remove the case and heat shrink it, you can put it in front of the servos just above of the battery. Pic.
Be careful when removing the case from the Schulze Rx. It is glued to the PCB and components on several points.
Matthias
MGerstgrasser is offline Find More Posts by MGerstgrasser
Old Aug 11, 2004, 10:54 AM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
Thank you, I think I might try that.
Update on the build:
Yesterday evening someone I met at a F3K competition called. We are going to travel together to a competition held on sunday, and we will go on saturday.
Soooo; now I really have to build fast, so there won't be much time to post as the build goes along.
But I've progressed quite far from yesterday evening:
Wing and aileron servos + linkages are in place.
Stabs sanded and almost completely covered. So what remains i s to mount the stabs, and make linkages.
I only have one concern; the horiz stab mount seems really flimsy! Maybe it gets stiffer as the two parts are glued together. Maybe it should be soaked with ca, since the cf seems really "dry".
I'll post updates and competition report next week.
Old Aug 12, 2004, 01:09 PM
Nicke is offline
Nicke's Avatar
Sweden, sthlm
Joined Nov 2001
HELP!!! Wing is warped!
Ok, I'll post build and flight reports next week, but now i need som HELP!
On the maiden it banked hard left. I had to dial in a LOT of rigt trim to make it fly straight. The right aileron is as much as 5 mm above the left at the root!
So how can I straighten a moulded wing
Does the good ol heatgun and twist method work??? Need help fast, I only have tomorrow to do final trimming before the contest!
Old Aug 12, 2004, 02:09 PM
marctrudeau is offline
Find More Posts by marctrudeau
West Boylston, MA
Joined Feb 2003
Dear Nicke,
I'd shoot to get a replacement wing from the manufacturer.
...but, for the contest, for bagged wings, you can put each wing panel flat on a building board (making holes in the board to clear pags and horns), cover it with many layers of bath towels, and fill the bath towels with as much boiling water as they'll hold, and let it cool. Then do the other wing.
I worry about the effect of this on a hollow-molded wing, so I'm not making a recommendation. You might end up with very different airfoil or a completely ruined wing.
Has anyone else tried this or another method on a molded wing (presumably glass/balsa/glass laminated skins)?
Would the manufacturer agree for you to try it or the head-gun method and give you a new wing if it gets ruined? (Seems they owe you another wing!)
Good luck,
Marc
marctrudeau is offline Find More Posts by marctrudeau
Old Aug 12, 2004, 02:18 PM
Austria
Joined Oct 2003
Hi,
sorry to hear that. I also had a problem with aileron trim needed to fly straight (about 2mm at root). In my case it was one of the flaps beeing twisted. The wing itself was straight. Check that, before you apply any heat. Untwisting the flap works with some heat. I used a hair dryer, not a heat gun. Only a small amount of heat and force was necessary. The fix is not permanant an has to be repeated every now and then.
If it's really the wing in your case, complain and try to get a replacement.
Greets,
Matthias
P.S.: @Marc:
I think that's a method that works well on bagged foam wings. In the case of a glassed balsa wing, I would never do that, because there is a great chance that the humidity will go through the glass layer and warp the balsa.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
