Old Aug 09, 2004, 11:50 AM
Zoomzoom is offline
Find More Posts by Zoomzoom
Joined Jul 2002
Twist lock latches
I'm looking for small light weight twist lock Dzus type fasteners. Does anyone know where I can get something like that or have any ideas ?? I want to recess it into a carbon fiber panel I made. Thanks
Zoomzoom is offline Find More Posts by Zoomzoom
Old Aug 09, 2004, 12:35 PM
RCParkflyer is offline
Find More Posts by RCParkflyer
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
http://www.dzus.co.uk/Live/Dzus/CMS....ucts/Catalogue
before you spend a fortune on those fastiners, you might want to go to your "big Name" hardware store, and see if they have any of the fastiners that are used in "pre-fab" wood furniture kits. I've seen some pretty small fastiners used in shelfing, so they must sell replacments for them. Good luck
RCParkflyer is offline Find More Posts by RCParkflyer
Old Aug 09, 2004, 03:07 PM
JerryHall is offline
Find More Posts by JerryHall
Ravenna,Nbraska
Joined Sep 2003
You might try Wick Aircraft Suply in Highland, Ill...1-800-221-9425
JerryHall is offline Find More Posts by JerryHall
Old Aug 09, 2004, 04:15 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Two words: Mc Master-Carr, they have everything and they are online.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Aug 09, 2004, 04:47 PM
thrmaln is offline
Find More Posts by thrmaln
United States, CA, Glendale
Joined Jun 2001
Mc master is the way to go
Hello,
McMaster Carr has just about everything you could ever need. Where else can you buy Tampons in bulk and Lasers micrometers at the same place LOL.
(www.mcmaster.com)
In the search fields try captive fasteners. I found some but they may be too big on page 3057. you can jump to page 3057 if you put that in the search field as well.
Best regards,
Marc Webster
thrmaln is offline Find More Posts by thrmaln
Old Aug 09, 2004, 09:47 PM
Zoomzoom is offline
Joined Jul 2002
Many thanks for all the replies. The Master Carr fasteners on page 3057 look like they will do the trick, going to order a bunch tomorrow.
I had looked all over the internet, surplus nuts and bolts stores and many many harware stores with no luck. Again many thanks to all
Old Aug 10, 2004, 12:19 AM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Let us know how it goes. Are you going to try the wing nut one?
Justin
roccobro is offline Find More Posts by roccobro
Old Aug 10, 2004, 12:28 AM
Zoomzoom is offline
Joined Jul 2002
It looks like the fasteners on the bottom of page 3057 might work. They kind of remind me of the metal pins used to hold down drum brake shoes on 1960's~1970's GM cars. The pins go through a slotted washed and you turn them.
It still would be nice to find some mini nylon Dzus type fasteners.
Old Aug 10, 2004, 01:53 PM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
They shouldn't be hard to make for some manufacturer that produces nylon parts. Definitely post some wieght numbers and impressions when you get them.
Justin
Old Aug 10, 2004, 08:14 PM
Zoomzoom is offline
Joined Jul 2002
I ordered them and hope to get them Friday ?? When I get them I'll post some info.
twist-lock firewall? Phreakish Parkflyers 6 Nov 16, 2003 05:19 PM
