Old Aug 09, 2004, 06:33 AM
century_series is offline
Find More Posts by century_series
Pro Slacker
century_series's Avatar
Linköping, Sweden
Joined Nov 2003
Asymmetrical AP-plane out of depron
Hi everybody!
Just started building a 480-sized plane for aerial photgrophy. I know, it should be posted under AP but it's made of depron mostly so here it is.
The idea is to separate the "aeroplane-part" from the "camera-part", minimizing vibration-induced distortion in the pictures. Hence an asymmetrical plane looking like the Blohm & Voss 141 from WWII. I was hoping the depron might absorb some vibes as well.
Anyone tried this before?
Specs:
Span 1200 mm (47.2")
Cord 300 mm (11.8")
Wing area 36 sqdm (558sq")
Length 820 mm (32.3")
Weight approx 650 g (22.9 oz)
Speed 480
cells: 8 KAN 1050 mAh (180 g, MUST go for LiPo!!!)
Building technique is similar to a balsa model, ailerons are cut and faced similar to a BalsaCraft model.
More pix will come...
/Patrik
century_series is offline Find More Posts by century_series
Old Aug 09, 2004, 07:31 AM
Modellhobby is offline
Find More Posts by Modellhobby
Modellhobby's Avatar
Lidköping/SWEDEN
Joined Aug 2003
Looks good!
Is the last photo part of the pod?
Looking forward to hear from the maiden.
/Stefan
Modellhobby is offline Find More Posts by Modellhobby
Old Aug 09, 2004, 02:07 PM
jimkirley is offline
Find More Posts by jimkirley
Joined Jul 2004
hey Century,
Nice work, looking forward to the maiden! P.S. the banana peel goes in the trash!
KEEP BUILDING---JIM.
jimkirley is offline Find More Posts by jimkirley
Old Aug 09, 2004, 03:54 PM
Buzz_Man is offline
Find More Posts by Buzz_Man
Fly safe, fly often!
Buzz_Man's Avatar
United States, GA, Powder Springs
Joined Dec 1999
What a cool idea - asymetrical! I never would've thought of that. Looks great so far. Hope it works, good luck!
Buzz_Man is offline Find More Posts by Buzz_Man
Old Aug 10, 2004, 02:44 AM
Pro Slacker
Linköping, Sweden
Joined Nov 2003
Jim, no time for carying trash, building only!
As for the idea of asymetry, I really can't take any credit. Check the Blohm&Voss 141!
It is an interresting thing considering the following: our props rotates CW in the direction of flight. This produces a propwash over the fin which turns the plane to the left. To counteract this you can either build your fin (vertical stabilizer) canted a few degrees, or trim with the rudder (if you have one) or move the thrustline to the left (producing a right-turning torque).
Ideally, the asymetrical thrust-induced torque should balance the propwash torque under power. With the motor off, the drag of the camera pod should balance the draf of the fuselage. Ideally!!! Then there is the question of center of gravity...
As for the last pic, the campod. You're seeing it from the bottom and the front is to the right, still lacking a nose cone. The cam mounting plate sits between the two bulkheads.
Anyway, more pix: first one shows the battery tray from below, second one is the rear fuse with depron bulkheads.
Later Dudes!
Old Aug 11, 2004, 02:58 AM
Pro Slacker
Linköping, Sweden
Joined Nov 2003
More build-pix:
1st: Slots in the wing are for the campod balsa tongues. The hole is for the aileron servo.
2nd: Campod with rear balsa tongues, they stick out about 15mm and glues into the slots in the wing.
As I went to bed I just realized how over-engineered this really is! A better way would have been to insert a couple of dowels, front and rear, in the campod and secured it to the wing with a rubber band! I mean, if a fuse can be held to a wing with rubber bands, a 2 oz pod might just stay attached! Duuuh, me and Homer Simpson...
Old Aug 12, 2004, 08:58 AM
Pro Slacker
Linköping, Sweden
Joined Nov 2003
Late last night I closed up the wing, top skin glued. Should have taken a photo but that would just have shown a massive white blob w/o contures or anything... I'll post a pic when I've cut out the ailerons and glued the LE and TE.
This morning my 20 month old son, Oscar, found some depron left overs and promptly started building and making aeroplane noises!!! We had a bit of dep-bashing and made a 5-minute delta he could toss around. Great stuff!
I keep telling people I really haven't tried to make an aviation nut out of my son, but nobody believes me! Strange...
/Patrik
Old Aug 12, 2004, 10:20 AM
Lidköping/SWEDEN
Joined Aug 2003
Now Century, all you have to do is buy him an brushless combo and some good radio gear...
Who knows. Maybe you can borrow his LiPo pack from time to time :-)
/Stefan
Old Aug 12, 2004, 09:08 PM
shakysticks is offline
Find More Posts by shakysticks
clumsy thumbs
shakysticks's Avatar
Lincoln, NE
Joined Dec 2003
Looks great - I use the same basic construction method for my depron/fanfold wings. I really like the way they turn out.
shakysticks is offline Find More Posts by shakysticks
Old Aug 13, 2004, 03:16 AM
Pro Slacker
Linköping, Sweden
Joined Nov 2003
More late hour work last night. Cut out the ailerons and prepared wing for LE and TE. Edges will be of balsa mostly as a vaccine against hangar rash .
Aaah, I can almost smell the maiden flight...
/Patrik
Old Aug 13, 2004, 04:37 PM
Zeroaltitude is offline
Find More Posts by Zeroaltitude
Cheapskate freeloader!
Zeroaltitude's Avatar
Orebro, Sweden
Joined Oct 2002
Hey Patrik, great idea for a Ap plane!
From looking at your drawing though, have you considered offsetting the horisontal stabilizer too so that it is centered on the wing? The B&V had this IIRC, and I fear you may experience some rolling tendencies with the stabiliser set up as per your plan, because it will be acting more on one side than the other.
This may not be a problem, I certainly am no expert on assymetrical planes, but in theory at least you might encounter a problem.
Good luck!
Anders O
Zeroaltitude is offline Find More Posts by Zeroaltitude
Old Aug 14, 2004, 01:20 AM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Don't forget to check out Burt Rutans "Boomerang". It would make a great model too if you could actually find some drawings on it......
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Aug 15, 2004, 09:56 AM
Pro Slacker
Linköping, Sweden
Joined Nov 2003
Hi Zero!
Yeah, the stabilizer should have been asymetric as well. As it turned out the fuse is so much heavier than the pod so the offset will only be 25 mm. If I ever build the serious version (3 m span, AUW 5 kg, SLR camera etc) the stab will def be way off center!
Arx, I'm actually drooling over the Boomerang as it's a great assym concept ! They would really scratch their heads at the flying field over that one... As a flat plate design this winter maybe, hmm, yesssss!
Old Aug 16, 2004, 04:07 AM
Pro Slacker
Linköping, Sweden
Joined Nov 2003
Slow weekend, not much built.
Well, I had my sister in-law and her son visiting so... BTW, my in-law is a police officer so she can't very well be an out-law, can she (pun intended )?!
Managed to tamper a bit with the camera tray though.
/Patrik
Old Aug 16, 2004, 11:44 AM
Lidköping/SWEDEN
Joined Aug 2003
Watch out!
I think that bananapeel is stalking you...
/Stefan
Btw, building looks great!
Poll Check out my new AP plane -scratch built. Let me know what you think. simo10 Aerial Photography 48 Jun 13, 2008 09:54 PM
Looking for a good design for homemade AP plane out of Fan Fold... Picoflyer Aerial Photography 8 Dec 15, 2004 06:54 AM
Am I dreaming?Or could this be the best plane out there? Gonflyin01 Foamies (Kits) 6 Jan 26, 2002 04:54 PM
Is there a good foamie aqua-plane out there? DaJudge Foamies (Kits) 9 Oct 10, 2001 05:52 PM
