Old Mar 24, 2005, 05:14 AM
lanre is offline
Find More Posts by lanre
See me! I dey fly!
lanre's Avatar
Yenago, Bayelsa State, Nigeria
Joined Jul 2004
cold you post a diagram of the hall sensor?
lanre is offline Find More Posts by lanre
Old Mar 26, 2005, 10:21 AM
Rajesh L G is offline
Find More Posts by Rajesh L G
Bangalore, India
Joined Nov 2003
That reminds me, I had seen that there was a mistake in the hall sensor wiring in the datasheet. The connection from Hall2 and 3 to the resistor from Vcc is missing in the datasheet. Hall1 is hooked up correctly. Guess this was what your question was about.
Rajesh
Rajesh L G is offline Find More Posts by Rajesh L G
Old Mar 26, 2005, 01:37 PM
lanre is offline
See me! I dey fly!
lanre's Avatar
Joined Jul 2004
Rajesh,
what i ment was how do i identifiy the position of the pin on the hall sensor
And thanks for the correction
lanre
Old Mar 29, 2005, 02:45 PM
lanre is offline
See me! I dey fly!
lanre's Avatar
Joined Jul 2004
view the data sheet of the ic
Old May 04, 2005, 12:36 PM
lanre is offline
See me! I dey fly!
lanre's Avatar
Joined Jul 2004
plz can you tell e which of the folloiung is going to the signal point on the reseiver? And on the datersheet you suppliy the motor power seperat how do i do it?
Old May 05, 2005, 02:45 AM
Bangalore, India
Joined Nov 2003
The terminal marked JMP is the one going to rx. It goes to the mosfet where you would normally connect the motor.
The battery is directly connected to Vm. Vcc needs to be around 5V, so you need a regulator. The current needed is very low, so you can use any light weight regulator or even a zener.
-- Rajesh
Old May 05, 2005, 12:25 PM
lanre is offline
See me! I dey fly!
lanre's Avatar
Joined Jul 2004
i dont undersatnd it cos i have a 2 channel rx but i dont know how to conect it
---lanre
Old May 06, 2005, 03:36 AM
Bangalore, India
Joined Nov 2003
lanre,
It would be better if you describe what kind of receiver you have and what its outputs are.
The circuit I gave works for receivers with built in ESC with PWM rate in kHz range. If you have something else, you might need to redesign the low pass filter. Basically what you need is a differential signal proportional to the throttle applied between EC and ECR pins. If you need more help, you need to give details about your rx.
-- Rajesh
Old May 14, 2005, 12:42 PM
lanre is offline
See me! I dey fly!
lanre's Avatar
Joined Jul 2004
well my receiver dose not have a built in ESC
Old Dec 11, 2005, 06:16 PM
lectraplayer is offline
Find More Posts by lectraplayer
Professional Crasher
Joined Apr 2004
Originally Posted by Zlatko
Thanks Rajesh,
Fair enough about the PIC based brushless ESC. I guess I can dream
The controller chip from my HD is a Texas Instruments TLS2251 , I googled and searched TIs site but no joy. Does anyone know more about this chip?
Cheers
Try AllDatasheet.com.
www.alldatasheet.com
Me, I'm looking for a new power-FET for a UPS and a decent ESC I can build into a rebuilt computer fan. I would like to build a decent fan for, maybe, an F-18 EDF jet. ...that and have me a high-powered (1400VA) UPS. 4 IRFZ-46's are used in the inverter for this thing, and they've all blown!
lectraplayer is offline Find More Posts by lectraplayer
Old Mar 21, 2007, 12:55 PM
rafaelvc is offline
Find More Posts by rafaelvc
Joined Mar 2007
rewound CD-ROM motors
Hi, I am new around here. I was wondering if this controller would work with rewound CD-ROM motors like the ones you can find at http://www.rcgroups.com/forums/showp...87&postcount=4.
If not, does anybody know how to simply modify the controller in order to make it able to do so?
thanks,
Rafael
rafaelvc is offline Find More Posts by rafaelvc
Brushless power system for a WindDancer? mwtrull Power Systems 9 Nov 21, 2002 01:09 AM
Brushless Power Ratings... Yogi Power Systems 1 Nov 13, 2002 06:09 PM
All you brushless power heads, come check out these incredible videos! Martin Hunter Parkflyers 0 Oct 22, 2002 08:00 AM
Jeti brushless power lead lenght Kimble_Schmitz Power Systems 5 Jun 19, 2002 08:13 AM
New brushless power set-up for the Voyager marcusg Electric Heli Talk 12 Dec 11, 2001 03:33 AM
