Old Jan 28, 2002, 04:51 PM
mromaszewicz is offline
Find More Posts by mromaszewicz
SF Bay Area, California
Joined Jan 2002
Interested in starting with e-helis, need advice
Hello All,
I've lost all my flying fields for gas powered models, so I am thinking of getting an electric heli or perhaps converting my Raptor30.
I would like to have something with performance close to that of my Raptor, meaning I would like to have a heli with a decent pitch range (-9, 9) and decent power.
I've been looking around the web for info, and it looks like the Logo20 may be the way to go. Does this particular heli have about the same amount of slop-free pitch as a Raptor30? I've seen people recommending setups of (-4, 9) for one of these birds, but is it capable of more?
Secondly, what motor/controller combination is the best. I've been thinking of the pletenberg/schulze combo, but I can't find a US distributor. Do I need to order these from germany?
And lastly, given that I don't know very much about rechargeable battery technology, I need some battery advice. NiMH have nice capacity/weight ratios, but can they push enough juice to fly the Logo? Will placing them in a logo push them so close to their maximum that they will wear out fast?
A logo20 is an expensive proposition, so is it realistic to perhaps convert a raptor to electric power? could I expect similar flight times to a logo, or is the raptor just too heavy?
Thanks a lot for any advice,
-- Marcin
mromaszewicz is offline Find More Posts by mromaszewicz
Old Jan 28, 2002, 05:32 PM
misskimo is offline
Find More Posts by misskimo
TeamTP,Minicopter,Spartan
misskimo's Avatar
Mississippi 31 years , Now Kotzebue , Alaska 12
Joined Apr 2001
hey
Hi , if you like tinkering you can convert the rappy into electric , but it will be heavy , they have a e raptor dont they ? but anyway , if you want a heli that can compair to the rappy , the logo 10 at this place will do the trick , http://www.eflightpacks.com/
you can get your batteries there also , 12 to 14 cell will do you fine , the motor to get is the 600 18 or just tell Tony that you want it hopped up to do 3 D and if you want to know more about the logo , this is the other place to find out more http://groups.yahoo.com/group/Mikado...yguid=65800794
its new but there is people talking sometimes , but mostly here at ezone , the logo 20 is a 46 size heli , which is great but costly too , and then if you have the cash get the joker , this is the badest on the market , """they say""" http://www.minicopter.de/de/joker.html
they have some small clips in the site too , I think 4 or #5 has some good blade popping going on, too sounds great ,
I was going to tell you to get the Voyager , but it requires alot of hopup parts to get it to out drag the rappy
The batteries , in the last few years they have went a long way , it like this , lets say you have a ep concept , 7 to 8 cell heli , you try 6 cells and the motor will pull to many amps and your batteries will genarate alot of heat and wear out quickly with the stock pinion , 7 cells better , 8 cells real good but then you have to get the gearing right too , start changing pinion . be back in a few
misskimo is offline Find More Posts by misskimo
Old Jan 28, 2002, 07:34 PM
JIMJAM is offline
Find More Posts by JIMJAM
JIMJAM's Avatar
Columbia, South Carolina, United States
Joined Feb 2000
Welcome. Do a search on all the electric helis and you will find tons of info and opinions on about everything. As far as converting a IC heli to electric, you would be better off buying something designed from the ground up to be electric. Also, you can utillize the forums here and learn from others. Especially with brushless setups, experimenting can be very expensive.
JIMJAM is offline Find More Posts by JIMJAM
Old Jan 29, 2002, 12:53 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Logo 10 or Voyager
One of these will serve you well, and the Logo 10 is about the same size as the Rappy.
Where do you live? I have both of them.
EFlightpacks will treat you good!
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jan 29, 2002, 04:10 PM
Joined Jan 2002
Logo20 vs Logo10
Thanks for all the replies. Where do you fly Mr. Bronk? I live in Mountain View, so perhaps I could drive out to your flying site and see you fly your electric birds.
Now as for the logo10 vs the logo20.
Are both these helis capable of 3D? I don't mean loops and rolls but do they have enough negative pitch for inverted climbouts with the same power as right side up? Can I run them off NiMH for longer flight times when I'm not doing aggressive 3D?
Since brushless is so expensive, what motor/esc combo would you guys recommend for each heli? I was reading that a plettenberg (sp?) motor with a schulze heli specific esc is a very nice combo for the logo20, but I haven't been able to find where to buy this beastie. In either case, it looks like I have to live off water and rice for a while to afford one of these
-- Marcin
Old Jan 29, 2002, 07:22 PM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
hey
here take a look at the logo in action , thats the first heli , the second one is the Joker , this is a big movie file , 12.784KB but it is wellWORTH it , Tony
http://www.mjustus.rc-modellflug.net/rm/melleacro.rm
Old Jan 29, 2002, 07:54 PM
Steph280 is online now
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Brushless combo is not really that expensive when you consider the cost of a glow engine, pipe/muffler, speed governor, and a servo. Yes you have to include speed governor because heli brushless ESCs has them built in.
Not to mention the brushless motors don't wear out like the glow engines do.
Steph280 is online now Find More Posts by Steph280
Old Jan 29, 2002, 08:33 PM
harley-y2k is offline
Find More Posts by harley-y2k
Nashua N.H.
Joined Jan 2002
Subj: Re: ele motors
Date: 1/24/2002
> plettenberg 300/25/a3 Heli ==> 255.00 U$
> schulze 35ho and how much ==> 189.00U$
> kontronik tango 45/08 ==> 289.00U$
> 3slh-14-32 ==> superseeded by the Beat 35-8-30, no price yet
ICARE
www.icare-rc.com
1(450)449-9094
bob.
harley-y2k is offline Find More Posts by harley-y2k
Old Jan 29, 2002, 09:28 PM
e-sailpilot86 is offline
Find More Posts by e-sailpilot86
e-sailpilot86's Avatar
Joined Jun 2001
Hey misskimo(Tony?)! That video rocks!
e-sailpilot86 is offline Find More Posts by e-sailpilot86
Old Jan 29, 2002, 09:40 PM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
it does , dont it ?
man I wish I could just hover upside down , and I will have that joker in the next few months , I need something that can do stationary flips like that , because 9 months out of the year Im flying in the gym here at work in Alaska , cant wait till spring time , june , damn thats a long time from now july in summer, aug. is fall ,and the rest is winter , Tony
Old Jan 29, 2002, 09:57 PM
Phoenix-IT is offline
Find More Posts by Phoenix-IT
Elder Freak
Phoenix-IT's Avatar
Dallas Intl, Texas, United States
Joined Jul 2001
Logo 10 Pitch Range
Hi mromaszewicz, welcome!
You asked about the pitch range of the Logo 10. According to the manual the range is -11 to +12 with the 120 degree CCPM configuration. I don't know what the range is with the 90 degree configuration. I just ordered a Logo 10 as my first helicopter, I've never flown 3D, but have seen many videos and local flyers doing it. I've seen the Logo 10 3D videos and it looks at least as capable as the Raptor. Some of the things I saw in the Logo video I haven't even seen done with an beefed up X-Cell 60 locally! (Of course that could be the pilot...)
Anyway, hope this answeres your question.
Chad
Phoenix-IT is offline Find More Posts by Phoenix-IT
Old Jan 30, 2002, 08:20 AM
Fitz Walker is offline
Find More Posts by Fitz Walker
No "R" !!!!!!!
Fitz Walker's Avatar
United States, TX, Houston
Joined Jan 2000
Re: Interested in starting with e-helis, need advice
Originally posted by mromaszewicz
Hello All,
I'm surprised no Logo20 fliers have responded yet, so I will. I fly a Logo20. The pitch range is very good, I could probably get something like +/- 12 if I wanted to. I currently have about -9, +12
As a general rule, you are better off with Nicads for high performance flying. There is a new HV NiMH people are talking about, but that is "bleeding" edge stuff right now.
-- Marcin
It is realistic to convert a Raptor to electric, but it is not realistic that it will have anywhere near the performance of a Logo20. Plus, the Logo is a bit larger.
Fitz Walker is offline Find More Posts by Fitz Walker
Interested in a Carbon Rapp-E? ScotY Electric Heli Talk 30 May 08, 2008 05:47 PM
Discussion Interested in getting into slope soaring. I need some advice. hanknmorgan Slope 179 Jan 23, 2006 01:09 AM
Zagi THL with 400 motor? Need Advice. tomcor Foamies (Kits) 1 Mar 03, 2003 07:37 AM
Anyone interested in starting a electric only club in (around) Cleveland? Chris K Electric Plane Talk 0 Dec 01, 2002 10:00 PM
Repeated Crashes with Tubby Cubby-Need Advice Mark E Parkflyers 6 Jul 30, 2002 12:39 PM
