Old Aug 06, 2004, 01:00 AM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
What is the best way to test a plane when alone.
I need to make some throttle adjustments to a plane, but being that it is a foam plane I don't have a way to secure it unless someone else holds it. Do you guys have any types of rigging to test an assembled plane without pulling the motor system out of it?
I was told to lower the epa of the throttle so it is smoother. Right now when I throttle up the plane has a soft start and then pops what looks like into a 2nd gear. When it hits the higher rpms it makes the plane uncontrollable and dangerous.
The setup is as follows:
GWS Beaver
Futaba T7CAP
E-Flite Park 370-4100kv motor
Hacker Master Car Mini controller (setup in forward only with break)
3s Etec1200HP
TeamTEOR is offline Find More Posts by TeamTEOR
Old Aug 06, 2004, 02:49 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Copule of lengths of water pipe rammed in the ground and covered in pipe foam insulation?
Then just put the model between and let the wing bear on the foam insulation?
Old Aug 06, 2004, 03:20 AM
lipolenny is offline
Find More Posts by lipolenny
London,England UK.
Joined Jul 2004
Try a black and decker workbench with some pieces of foam wedged under the u/c,then slot whole assembly between the jaws-tighten just enough to stop model moving-works well with my 3dx and 3s packs!!.
lipolenny is offline Find More Posts by lipolenny
Old Aug 06, 2004, 05:55 AM
JREEVES is offline
Find More Posts by JREEVES
Wayward Pilot
JREEVES's Avatar
USA, FL, New Port Richey
Joined Sep 2001
How about taking a foot long piece of 2x6 or 2x8 lumber, drill two straight holes half way into it 4" apart, then push two new #2 pencils into the holes. Put the fuse between the pencils so they capture the leading edge of the tail. You can also use it to check CG by balancing the wing on the eraser heads.
JREEVES is offline Find More Posts by JREEVES
Old Aug 06, 2004, 02:31 PM
astroboy is offline
Find More Posts by astroboy
Superhero, Third Class
astroboy's Avatar
Carson City, NV
Joined Nov 2000
I used a couple of bricks with some padding on them, one in front of each stab panel. That's assuming your plane has an undercarriage.
Jeff
astroboy is offline Find More Posts by astroboy
Old Aug 06, 2004, 03:04 PM
AUBrian is offline
Find More Posts by AUBrian
Zen Flying Master
AUBrian's Avatar
Sweetwater, TN
Joined Sep 2002
If you're out in the field, I've put the back of the fuse between my legs so that the tail is against my ankles and that holds it...otherwise, 2 strong sticks solidly in the ground would do the same thing. (P.S. Don't do this at home unless you're sure nobody nor any animals will come to check on the noise)
All of the ways so far discussed work just fine as well, and you could also consider small piece of ply (maybe 1/2") with a line of holes drilled in it to stick dowels in. That way you could space the dowels based on the plane.
Last but not least, tie a string around the fuse or tail (make sure you take precautions so that it doesn't cut in) and tie off to something solid.
AUBrian is offline Find More Posts by AUBrian
Old Aug 07, 2004, 11:21 PM
TeamTEOR is offline
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Thank a lot guys. I'll use some of these great ideas for more than just testing out the esc. I need to test out thrust as well, and using a digital fish scale inline to the tie off idea will flip the bill nicely.
Old Aug 08, 2004, 06:44 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Originally Posted by TeamTEOR
.. I need to test out thrust as well ...
Why?
Old Aug 08, 2004, 07:07 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
Andy's question is a good one, because static thrust tests aren't going to tell you what your dynamic thust will be at the speed your plane becomes "uncontrollable and dangerous".
Perhaps the most important element in your setup is missing here: What prop are you using?
As a matter of fact, if the prop is relatively high-pitched in relation to its length, it may stall during a static test and measure low in thrust, but exhibit high thrust at the speed you plane gets in trouble. A flatter prop would test higher in static thrust, but lower at speed. Try a flatter prop.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Aug 08, 2004, 09:05 AM
TeamTEOR is offline
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Ok, I will try that, I didn't realize there would be a difference in thrust like that on a test bench.
Right now I am using D gearing and 1080 prop, I'll drop down to a 1047. Should I try a even larger prop like a 1147?
The plane was really unstable, atleast I didn't hurt anyone and/or crash it. I did land it far enough away from everyone so no one had to worry about anything there. Talk about rocket, I thought those Park motor were going to have a little less pep over a HiMaxx.
Alert I Want to her From you .....What is the best way to attach a servo to your plane??? Zachary Beginner Training Area (Aircraft-Electric) 12 Jul 17, 2004 06:40 PM
What is the best way to make a fiber glass cowl? KOMET 44 The Builders Workshop 9 May 31, 2004 06:01 AM
What is the Best Way to Harden My Receiver and ESC? Talon Driver Electric Plane Talk 9 May 01, 2002 04:51 PM
Best way to test battery charge? mism42 Electric Plane Talk 5 Dec 22, 2001 05:24 PM
Lite Stik-What is best way to make removable stabilizer? Ron MIller Parkflyers 4 Jul 02, 2001 01:23 PM
