Old Aug 05, 2004, 03:48 PM
sonic liner is offline
Find More Posts by sonic liner
Thanks Wilber and Orville !.
sonic liner's Avatar
United States, CA, Los Gatos
Joined Jan 2004
Twin Wattage f-86 saber in the works
Well it sounds expensive but i am going to combine two jets into one
aircraft.
The first idea is to build a straight center wing to connect them both
and have outboard ailerons only.
Power will be two astro fan packages with two 3s2p lipo packs.
I have done this with two GWS zeros with great results.(tractor prop powered).
The second idea came from a flying buddy of mine.
He suggested not seperating the fusalages as this may be to
"Draggy" His idea is to sand the inboard surfaces of the fuses
and combine them into one fusalage then mount this on a raptor
wing available seperatly from a known vendor. Still using the astro
fans and lipo packs for power.
I received the two kits last night at $49.00 EACH..almost 2 for 1
pricewise and did a mockup on the bench.
Both versions seem viable with option one being the easy version.
20 hecell round cells would be to heavy and either a heafty two
handed toss or bungi will be the order of the day.
Any comments, suggestions, tips etc. would be great.
I hope to have the build pics. going very soon. Thanks Pete
sonic liner is offline Find More Posts by sonic liner
Old Aug 05, 2004, 04:00 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Pete
Did you fly a twin zero at RSA ?
hall woo is offline Find More Posts by hall woo
Old Aug 05, 2004, 04:24 PM
Joined Jan 2004
Hey hall yes its me!
Any ideas on the tf-86 Pete
Old Aug 05, 2004, 06:14 PM
hall woo is offline
Permanently Banned
Joined May 2003
Using 3s2p 2100 TP ?
where you been ?
Old Aug 05, 2004, 06:33 PM
Racebelly is offline
Find More Posts by Racebelly
Vault-Tech Approved
Racebelly's Avatar
Simi Valley, CA
Joined Apr 2003
Pete,
I like your original idea of going with a straight center wing to connect the two fuses. You could make it look similar to the twin P-51 they made(P-82). This way you keep a semi-scale looking jet. Might be interesting.
Here's a pic...
http://www.studenten.net/customasp/a...=0&pte_id=2740
By eliminating the stock horizontal stab & creating a joining piece you might eliminate some of the issues with the stock setup also.
Not too sure about combining the two fuses & using the Raptor wing. Might look a bit Frankensteinish. But, to each their own. Just my 2 cents.
-Mark
Racebelly is offline Find More Posts by Racebelly
Old Aug 05, 2004, 06:37 PM
Joined Jan 2004
Yup...changed over to 3s2p t.p. 2100s and 3s2p 1200 t.p. lipos for about
6 weeks now.....never looked back.
Have a boat load of nim. and nicads now. Pete
P.S. I have been getting with the program.......catch the wave hehehehe
Old Aug 05, 2004, 06:42 PM
rcguy01 is offline
Find More Posts by rcguy01
Permanently Banned
Joined Apr 2003
i want the new narrow tanics 2450mah that can draw
25 amps continous. When will they have it in stocks?
rcguy01 is offline Find More Posts by rcguy01
Old Aug 05, 2004, 06:48 PM
hall woo is offline
Permanently Banned
Joined May 2003
RcGuy01
You get my PM ?
Old Aug 05, 2004, 06:54 PM
Joined Jan 2004
Thanks racebelly for your constructive feedback.
By conecting the two fusalages i will also have to increase the wing area
and with a tapered wing, although i have 2 sets it will not be easy.
But i can just run one set of enlarged tail feathers...pro..con..
Being a gemini i just have to do it somehow.
I do live near nasa ames research center but cant even get near their
wind tunnel to do some testing L.O.L.
On plan B i would just have to make a plywood template of the wing root
cross section and then would have something to either make constant chord
ribs from or somthing to hotwire or block sand down to when constructing
the new center wing. Would depron be of use here with c.f. spars going into
both ships? Thanks Pete
Old Aug 05, 2004, 06:55 PM
hall woo is offline
Permanently Banned
Joined May 2003
Pete
You should have enough power, going to be a piece of cake
Old Aug 05, 2004, 07:01 PM
Joined Jan 2004
Well o.k. then honey pass me the bone saw! Thanks for your support guys
and gals. Pete
Old Aug 08, 2004, 10:52 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
I can't visualize what your are trying to do. Would there be two complete fuses? Any sketches?
Either way, do it!
Justin
roccobro is offline Find More Posts by roccobro
Old Aug 09, 2004, 03:21 AM
Arthur is offline
Find More Posts by Arthur
Ceredigion, Wales.
Joined Oct 2000
So who is going to do the twin Mig ? Arf
Arthur is offline Find More Posts by Arthur
Old Aug 09, 2004, 06:24 AM
Paul DF jet man is offline
Find More Posts by Paul DF jet man
MORE POWER IS THE KEY
Paul DF jet man's Avatar
South Australia
Joined Jun 2004
Odd idea but still cool. I would be interested to see the end resalt good luck.
Paul DF jet man is offline Find More Posts by Paul DF jet man
Old Aug 09, 2004, 09:05 PM
Joined Jan 2004
Justin more data will be forthcoming as i wanted to collect as
much data as possible before doing anything.
I was going to try the mig first but that high t-tail looked
troublesome as far as a twin ship. Thanks for all of the support
from around the world pilots.
Pete
Sold Wattage F-86 Saber/ Mig 15 Jcopter Aircraft - Electric - Jets (FS/W) 9 Feb 25, 2007 11:10 PM
For Sale Wattage f-86, New in Box Alexis_Ruiz Aircraft - Electric - Jets (FS/W) 2 Jul 17, 2006 07:57 PM
FS Wattage F-86 Saber NIB kriptonic Aircraft - Electric - Airplanes (FS/W) 10 Jan 25, 2005 11:49 AM
FS-Wattage F-86 Saber replacement fuselage and stabs Dog1 Aircraft - Electric - Airplanes (FS/W) 3 Jan 26, 2004 06:31 PM
Wattage F-86 Saber PERI Electric Ducted Fan Jet Talk 2 May 05, 2002 11:32 AM
