Old Aug 04, 2004, 04:03 PM
Reed is offline
Find More Posts by Reed
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Build Log
JART - Build Thread
So I've decided the only thing that will get me off my butt to finally build this thing is to do a build thread. I've disclaimed before re: my building skills but it can't hurt to do it here. If you want the best possible advice for building planes there are others to whom you should go. A partial list of those whose knowledge I'll be stealing in this thread reads like this:
Phil Barnes
Carl Maas, Jr.
TFLG
Paul Masura
Joe Cormier
Russ Thompson
Robert Cavazos
Ralph Roberts
Craig Toutolmin
Tim Bigley
Tim Neja
Ken Russell
Leagun James
Brian McLean
etc, etc, etc...the list is endless.
Here are the drawings I used to begin this project. They were created in Illustrator but you could easily do a good enough job with a pencil and paper.
Reed is offline Find More Posts by Reed
Old Aug 04, 2004, 04:13 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
The foam begins...
Starting with a couple of sheets of 3/4" blue foam, I blocked out enough to cut out the fuselage. Two sheets were joined with a light coat of 3M77. Then I printed out the full-size drawings and laid them over a sheet of 1/32" ply so I could cut out some templates...
Old Aug 04, 2004, 04:17 PM
Jeff Charlot is offline
Find More Posts by Jeff Charlot
Insert custom witicism
Jeff Charlot's Avatar
San Diego
Joined Jun 2001
Looks great Reed, I'll be watching this closely. I'm just about ready to bite the bullet and scratch my first project.
Jeff Charlot is offline Find More Posts by Jeff Charlot
Old Aug 04, 2004, 04:22 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Looks pretty sexy. My only concern would be that the fuse towards the tail is too skinny and will be very prone to breaking. not to mention awfully small to put a linkage in to.
TFLG
TFLG is offline Find More Posts by TFLG
Old Aug 04, 2004, 04:23 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Wired
Here's my little set-up for cutting foam...darn simple, really. Just a dimmer switch connected to a socket going to a battery charger.
Old Aug 04, 2004, 04:27 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
TFLG
Yep, you got that right. The linkage is ok, I checked that out (well, hopefully) and my thought on strength is just to add some carbon back there and rely on that forward fin to help out. BTW, the drawing is not quite right back there as you'll see. (edit 2006: the plans above are now the current drawings).
This reminds me to encourage everyone to chime in as they watch here. I'm bound to need some help as I go along.
Old Aug 04, 2004, 04:30 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Bowed and Bent
And here are the bows I've been using so far. Could have used a smaller one to hack out the fuse but it turned out ok.
Old Aug 04, 2004, 04:40 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Ooooo, Sexy...
I cut the top airfoil shape first (it's an 8020 airfoil sized up to the length of the fuse and fattened in the back - see TFLG's comment above) so I'd have a nice smooth side to lay the profile templates on. You can see the bottom template still stuck to the foam that's been cut away.
In these pics I've already done quite a bit of sanding to get the fuse shaped properly. I think I used 220 wrapped around a chunk of flexy foam that I got out of an electronics package.
Old Aug 04, 2004, 04:50 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Picture of the Corrs
Beautiful, eh?
Old Aug 04, 2004, 04:57 PM
Pete-O is offline
Find More Posts by Pete-O
Just tape it, it'll fly
Pete-O's Avatar
Broomfield Jeffco, Colorado, United States
Joined Jun 2003
Cool. Now I get to see how I'm 'sposed to do it. I didn't bother with templates for my fuse, just marked it at key points and cut off sections, then sanded per eyeball.
Pete-O is offline Find More Posts by Pete-O
Old Aug 04, 2004, 04:58 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Picture of the CORES
Sorry, got a little sidetracked, though I imagine dutchydawg1 will quite enjoy that little diversion.
Here are the cores I cut using a hybrid method of the swing-wire made famous by TFLG (http://www.rcgroups.com/forums/showthread.php?t=191128) and standard upper and lower templates used with bow-cut cores. I didn't have a popsicle stick (http://www.rcgroups.com/forums/showthread.php?t=258798) so I used a chunk of wood from the scrap heap as a handle. The wire is just some SS leader wire - don't pull too hard, though!
Old Aug 04, 2004, 05:07 PM
ACM is offline
ACM
Find More Posts by ACM
ACM
slopetrash wannabe
Belly of the Beast/NorCal
Joined Feb 2003
I love it, another free education/inspiration. That thing looks like a deadly weapon. Way cool-ROCK ON!!
ACM is offline Find More Posts by ACM
Old Aug 04, 2004, 05:13 PM
Brian Courtice is offline
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
Like TFLG said... sexy!
Looks very nice Reed, it ought to be a total rocket ship on the slope too. Thanks for doing the build thread. I love to see someone else's plane come together online. This is particularly nice cause it's an original plane, and it isn't another foamie.
Are you going with lost foam, or are you gonna make a mold from the plug?
BTW, I am about half way finished with a new original design glass sloper of my own. I'll be posting pics soon.
Brian Courtice is offline Find More Posts by Brian Courtice
Old Aug 04, 2004, 05:16 PM
ORANATOR is offline
Find More Posts by ORANATOR
Slope Stud
ORANATOR's Avatar
United States, CA, Oceanside
Joined May 2001
Free carbon
Hi Reed,
I think that is a very sexy plane, if you send me your address I will send you out some Prepreg carbon tow and some prepreg carbon weave to stiffen up that tail section.
I am definitely watching this thread close.
I will try and get a picture out later but I HAVE too go fly now.
ORANATOR
ORANATOR is offline Find More Posts by ORANATOR
Old Aug 04, 2004, 05:17 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
The Kit
Here are all the parts as they come in the kit - oh wait, there is no kit.
Now the really interesting stuff starts. I'll be glassing the fuse first, hope to get to that tomorrow.
BTW, I should say something about the parameters I used to design this bird. This is an off-off-and way off-scale classic jet profile. I chose the side-view shape just because I like it, even though it creates some problems in construction and that pointy nose will be hard to keep intact after a few one-point landings. Looks-wise, I just wanted something I could really relate to in the air.
More important than looks, for me, is how this thing will fly. The wing is a sort of PSS/60" combo job - 8" root, 4" tip, 1 1/2" LE taper, 56" span. I'm using a 6062 airfoil because it flies well inverted and it's fast. Not the greatest airfoil for heavy wingloading and hard turns, but that's my compromise - I plan to bring the wingloading in at 18-20 oz. with ballast provisions to bring it up to around 24 oz. Dry AUW should be around 50 oz.
I'll be bagging the wings and tail feathers because I wanted true flying surfaces all around and because I wanted to try bagging. This plane won't be for formation flying, it's for me to tear up the sky all by me lonesome. I wanted something that's very neutral, very aerobatic, and goes right where you point it. We'll see.
Discussion JART - Build Thread Index Reed Slope 48 Jan 22, 2016 05:53 PM
Discussion YAJBT (Yet another Jart build thread) nauga Slope 67 Oct 21, 2007 09:41 PM
Build Log Oh yeah another jart build Thread! W49 Slope 48 Oct 18, 2006 08:46 AM
Discussion Jart Build. But Not A build thread Rocket Ronnie Slope 30 Feb 06, 2006 06:24 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 11:41 PM
