Old Aug 04, 2004, 01:41 PM
ToddL is offline
Find More Posts by ToddL
ToddL's Avatar
Chandler, AZ, USA
Joined May 2001
2 Brushless motors on one ESC?
I am sure this has been asked before, but I could not locate it in a search.
Could I run 2 CDROM type 10A motors from one PHX 25 controller? If so, I assume the motors would be hooked up identical wires in parallel.
ToddL is offline Find More Posts by ToddL
Old Aug 04, 2004, 02:25 PM
Shawn Palmer is offline
Find More Posts by Shawn Palmer
Schumacher USA
Tampa FL
Joined Jul 2000
Will not work. One ESC per motor in brushless.
Shawn
Shawn Palmer is offline Find More Posts by Shawn Palmer
Old Aug 04, 2004, 03:16 PM
myk is offline
myk
Find More Posts by myk
myk
myk's Avatar
Lake Sawyer, Washington
Joined Jul 2003
Shawn
I think Shawn's answer is the "Right" answer from the Mfg, however the "Real" answer is that it may work and has many times, there are many reports of your setup working on the forums, however you will probably void your warranty in the process.
myk is offline Find More Posts by myk
Old Aug 04, 2004, 04:56 PM
Schumacher USA
Tampa FL
Joined Jul 2000
Well, ok - let me explain in more detail what happens when it does appear to "work"
The controller is looking for back emf from a single motor. When it gets two signals, it averages them together to decide how to run "the one motor" it sees. The result is, since no two motors are electrically and magnetically identical (nor Kv identical) the controller runs neither motor entirely accurately. Innacurate running means extra amps for the same rpms, and extra heat on the motor, and a general degredation of performance compared to a single motor. It also reduces the amp capacity of the controller, due to the extra heat that is generated on the controller itself (I don't know why this is - that's one for Patrick to answer).
Will it harm motors doing it? Will it harm the controller doing it? That depends on how close you are to the amp specs of the motors and controller, how "different" the motors are, and a host of other things, but the very real possibility exists for one or all three to be damaged, where there is none for two single motors and controllers.
Think of it this way - if it was totally OK to run twins on our controllers - we'd be advertising the poopie out of it as an industry leading accomplishment! LOL (only one controller claims that now, and with a lot of specific stipulations). And I only throw that out there to quell the folks that may say "they just want to sell more controllers". Take it from someone who knows better - not a good idea.
Shawn
Old Aug 04, 2004, 11:31 PM
myk is offline
myk
myk
myk's Avatar
Joined Jul 2003
Even though you might blow something up, check out these videos, they are awesome, I just might have to try this some day. First is a twin counter rotating CD-Rom by skirtz that is running on a single Phoenix 25
http://skirtz.rchomepage.com/twin01.wmv
Second is also a twin counter rotating CD-Rom by EljimbO that is running on a single Phoenix 10
http://home.comcast.net/~eljimb0//MVC-610W.MPG
Here are the links to the corresponding threads these are from
http://www.rcgroups.com/forums/showthread.php?t=253610
http://www.rcgroups.com/forums/showthread.php?t=246407
Oh and sorry Shawn for endorsing this (well sort of) but it is just too cool even if your controllers don't "officially" do this.
Discussion 2 Brushless motors on one ESC! Rwarner1976 Foamies (Kits) 6 Mar 20, 2006 11:57 AM
Question 2 brushless motors on one brushless controller? hawaiianspork226 Power Systems 5 Mar 10, 2005 01:04 AM
can you run 2 brushless motors off of one esc? jeff262 Power Systems 4 May 30, 2004 11:39 PM
Can you run 2 brushless motors off of one ESC nikolaus_c Power Systems 1 Jul 05, 2003 11:44 AM
2 brushless motors on one speedo? juantrinidad Foamies (Kits) 0 Jul 01, 2002 02:23 AM
