Aug 03, 2004, 10:13 PM
USA, tn, Cordova
Joined Oct 2001
Seems to be a common breaking point for this charger,mine was doing the same thing. Those are two different solder joints and should not touch, you might have too much solder on them and they appear to touch. Try removing some of the solder with some Radio Shack de-solder wick. Use a small tip, don't hold the iron on the board/joint too long, just until the solder melts.They should be reattached with the black wire on the outside as you have them positioned in the pic.
Take it to work, seems like there is always a solder geek somewhere in the building!
