Old Aug 03, 2004, 06:45 PM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
DIY 12F675 Brushed ESC ?
Hi all
Has anyone built the fairly recent DIY ESC described here besides me ?
http://www.designsoft.com.au/ahome/rc/PIC-ESC/ESC.html
Ta
Martin
PLMS is offline Find More Posts by PLMS
Old Aug 04, 2004, 12:09 AM
MAVA is offline
Find More Posts by MAVA
MAVA's Avatar
El Dorado Hills, California, U.S.A.
Joined Mar 2000
Good link !!
PLMS,
Thank you for the link, the design looks simple.
I have not built one, but I like the 64 step throttle. Will build one soon and lay-out several boards to solder onto the back of the motors.
Step 7 Very good info for the first time builder.
Simple for a first time DIY ESC project.
Martin
MAVA is offline Find More Posts by MAVA
Old Aug 04, 2004, 06:18 AM
TugBoat is offline
Find More Posts by TugBoat
NSW, Australia
Joined Jun 2003
Hi Martin,
Ironsides has just pointed this thread out to me, and suggested I stand up...
Well, I'm the designer of the ESC and I've build quite a few...
I hope the ESC is working OK for you. If there are any questions I am happy to answer them.
I actually have an improved version of the software (not on the web site yet) that also offers:
- glitch counter
- Lost Model Alarm
as part of the design.
One of the reasons I have not updated the web site is that I have been busy with other things. Plus the number of options required too much documentation (ie. I got lazy).
As I said - any questions just fire away.
Tim
TugBoat is offline Find More Posts by TugBoat
Old Aug 04, 2004, 03:08 PM
MAVA is offline
MAVA's Avatar
Joined Mar 2000
Tim,
Thank you for your comments,
It is good you are including a Lost Model Alarm and a Glitch counter.
I realy have no questions, but I do have a dream.. Maybe you can add a programable BEC voltage detector. Where you can use a rotary hex switch(s) or even a simple push button switch. Make the setting on a EEprom. That is it. Again it is a dream.....
I will build one of your controllers soon.
Thank you
Martin Vargas
Old Aug 04, 2004, 04:12 PM
TugBoat is offline
NSW, Australia
Joined Jun 2003
MAVA,
The real problem is that there are not many pins left on the PIC for really complex things. What this means is that certain options can't be used in combination - or in some cases you need the external transistor inverter on the receiver signal input (this frees up some I/O pins).
Because the LVC is programable (when the PIC is programmed, just change the value in the assembler source file) I just have a few different ESCs and use the 'right one'. Of couse this is not so easy with the 'back of motor' mounting.
I don't know how many different LVC voltages you want, however, it would be easy to set the ESC up with two possible voltages (both set at the time the PIC was programmed) and use the jumper to select between them. (with the 'no-brake' design just add a pullup resistor and a jumper to ground to GP3). I presume you want 2S or 3S LVC options?
Just out of interest are you looking at building the 'no-brake' design or the 'brake' design?
Tim
Old Aug 04, 2004, 04:16 PM
TugBoat is offline
NSW, Australia
Joined Jun 2003
MAVA,
If you were to post a layout for 'back of motor' mounting that would be great and could help others as well.
Tim
Old Aug 04, 2004, 08:28 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
Well done Tim
Hi Tim
Pity we're in different states, we have much in common I suspect. See my RC and Automotive stuff here and you'll see what I mean.
http://www.users.bigpond.com/webspace/
Go to the SPAD/Mugi page for RC tinkering
About the ESC.
I built your full version with brake, using the hex file with the soft start and brake.
Well done on the programming BTW, very smooth bit of code. I love the variable rate PWM on the drive AND the brake outputs. The "Armed" ring via the motor amature is just a thing of wonder. I did it about 10 times in row I was so amused. Good thing.
I've made the BEC cutout somewhat crudely adjustable by including a small SMD trim pot on my layout. My layout is all SMD except for the FET and Reg.
It's etched single sided so it's not much smaller than your vero layout but I did it as test case for spend a few dollars on professional DS and though plated boards (in with other stuff we get made).
I attached a low res image of the PCB. If anyone wants the whole protel files I'd be happy to post it zipped up.
Two things.
One, I had an early failure of the ESC after a couple of minutes running. It seems the Schottky diode in the brake FET failed (IRF9540). It took out the main switching FET also, as well as burning off a track. I have now fitted a 3A SMD Schottky in addition to replacing the FETs. Seems to be going stong now.
Second, if you have any new SW I'd be keen to try it. Email me at mr.sneezy@bigpond.com is you like.
If you were to include a selectable BEC cutout then this ESC would be ultimate for my use. I go between 6V and 9V cut outs (9 cell NiMh or 3S Lipo)
The I'd be happy to see the brake setting locked on in code, this would free another pin.
Great Stuff Tim, I can't imagine the hours you have spent on this.
Old Aug 04, 2004, 09:50 PM
TugBoat is offline
NSW, Australia
Joined Jun 2003
PLMS,
Re: the schottky diode (loss of FETs)
I suspect that the problem may relate to the use of 9 cells/3S lipo and the rating of the diode in the FET. I have never had a problem with 8 cell and S400 motors - but all my testing is with 8 cells.
I agree that an extra Schottky is a good idea - I will update the diagram and text as soon as I can to reflect this.
Re: Programmable LVC
The current software permits the brake to be permanently on (you need to set the constants in the source and assemble the code yourself). Most of my ESCs are like that by the way - I tend to use the jumper to trigger the 'glitch' counter readout (also by buzzing the motor).
I will update the software to support two LVC settings in the code that are switch selectable using the 'Brake off' jumper. It may take a week or so for me to get round to it.
(I did consider the trim pot solution and didn't particularly like it - mainly for long term reliability reasons. With the 'two LVC switch selectable option' the trim pot will trim both voltage points - which should work fine.)
I will let you know when it is done.
Glad you like it - it did take me a while to get the whole thing working like it does - but the result was worthwhile. All the ESCs I build are now 'power PWM' - makes flying much easier in my opinion.
I should also give credit to Ironsides in Toronto who helped with the testing and documentation proofing. His input has resulted in a 'proper' product of much better quality than if I had just designed it for myself. Many thanks David.
Tim
Old Aug 04, 2004, 10:43 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
Hi Tim and David
In my last post the 9 cell pack was a typo, it should have been "(3S Lipo or 8 Cell NiMh)".
I was on an 8 cell pack testing it when FETs failed. I have not actually run it yet with the 3S pack (till I make another, or do a dual cutout).
The only related question I can think of is how critical is the 3.3nF capacitor on the brake FET drive ? I think I used 2x1.5nF (SMD's stacked up).
Anyway, all is well with it now.
cheers
Martin
Old Aug 05, 2004, 02:34 PM
Ironsides is offline
Find More Posts by Ironsides
Ironsides's Avatar
Toronto, Canada
Joined Jan 2003
Tim:
Thanks for the kudos, all I tried to do was break it ;-)
David
Ironsides is offline Find More Posts by Ironsides
Old Aug 06, 2004, 10:55 PM
MAVA is offline
MAVA's Avatar
Joined Mar 2000
PLMS,
Todays controllers do not include the additional diode to save space or cost!
My opinion is to add them to the Break and Motor Output part of the circuit.
I like your site-The pusher model interest me for some of my friends.
PS you would know a good site for DIY ODB-1 reader for FORDs.
Martin
Old Aug 07, 2004, 05:40 AM
hadihf is offline
Find More Posts by hadihf
Joined Dec 2003
A DIY Speed controller
Hi,
A very good DIY brushed speed controller. The PIC can be programmed incircuit. I buid one and it runs cool at 20A!
http://jaichi.virtualave.net/spdy1684-e.htm
Regards
hadihf is offline Find More Posts by hadihf
Old Aug 08, 2004, 03:48 AM
TugBoat is offline
NSW, Australia
Joined Jun 2003
I found the time over the weekend to update the circuit diagrams, software and web page to include the LMA, glitch counter and dual (jumper selectable) LVC options.
To use the more complicated options you need to grab the source code, configure the options and build the code.
PLMS,
It could be that the reduced value of C6 contributed to the problem with the FETs. C6 ensures that the brake FET doesn't turn on due to noise and stray capacitance - reducing the value of C6 increases the risk that the brake FET can turn on while the motor drive FET is on.
All my measurements and testing show that 3.3nF is OK for use with 8-cells, a S400 motor and a IRF9540 brake FET. However, the noise on the gate does get close to the gate/source breakdown voltage. Reducing C6 below 3.3nF is definitely not recommended, if in doubt increase it.
I was considering increasing the specified size to something like about 5.6nF for C6 - however I have not had a chance to look at this on the bench. However, I can't see why there would be any problem and the effect on the brake turn on time would be minimal. The problem is that too large a value for C6 will limit the ability of the soft brake to function correctly. If larger values of C6 are required then decreasing R12 & R11 may also be required.
If you look at the bottom of the web page there is a .HEX file for the ESC with the brake permanenty enabled and 6V/9V LVC selected by jumper.
Tim
Old Aug 11, 2004, 12:49 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
Hi Tim
Martin here (PLMS).
I will add another 1.0nF to the brake circuit. However it (your ESC design) has done a few long flights since I last wrote and I have not blown another fet anyway.
I have had some past ESC experience with running Cobalt motors, and the size of Schottky diodes on them. After burning out the original ESC's diode (GWS ICS-480) I fitted bigger ones and got no more trouble. I think the diode should be on the motor tags, but this is not always neat or practical.
I'll build another one now using the update with dual BEC cutout. I think I'll add a 3A schottky across the brake fet regardless (as I have plenty of SMD ones).
Since we both fly Zagi's (both clones) I'll ask a question about ESC brakes. How much reduction in propeller speed do you see ? My Gunther prop still turns, but I'm fairly sure it's slower than with brake off. My IRF9540 fet has 0.1ohm spec, does a lower On Z give better braking ?
Your ESC is the first one with braking I've used.
Thanks for doing the updates, I apprieciate your efforts. It allows me to spend a little more time doing the flying part of the hobby.
cheers
Martin
Old Aug 11, 2004, 07:13 AM
TugBoat is offline
NSW, Australia
Joined Jun 2003
Martin,
I must admit my Zagi and Unicorn both have the standard speed controllers in them - I built both planes before starting playing with ESCs and didn't want to pull them all to pieces to change the ESC.
Just out of interest I will try replacing the ESC in the Zagi when I next fly it and compare the brake with the standard ESCs brake.
The ESCs I built are all on S400 gearbox planes - on these the brake stops the prop (unless you build up a lot of airspeed...)
The standard ESC for the Zagi and Unicorn have a brake and the props stop unless you are doing a lot of speed. But as I said I will do a direct comparison next time I get a chance.
Sorry, I don't know how much improvement in braking you get as the resistance of the brake FET drops. I suspect not much, as far as I could see all the other DIY ESCs I could find circuits for used FETs similar to the IRF9540.
The 'soft' brake was intended for gearboxes to reduce the stress on the gears. I never thought about its use in direct drive applications - but I can't see any reason not to use it. Once the brake is fully on you can't get any more braking than that (without going to some form of active brake).
The diode directly on the motor is more important the longer the leads between the motor and the ESC get, also it reduces the reliance on the brake FET - which as you found is a good idea!
Tim
Discussion DIY Brushed ESC Mosfet garethadams DIY Electronics 6 Oct 15, 2006 11:39 PM
WTB: 15-20 amp brushed ESC Bill Germanson Aircraft - Electric - Airplanes (FS/W) 0 Oct 26, 2002 01:08 PM
WTB - 50 amp brushed ESC, 3000 NiMH Panasonics Bill Germanson Aircraft - Electric - Airplanes (FS/W) 3 Oct 14, 2002 08:33 PM
WTB Brushed ESC for 20 to 30 cells GoodTill Aircraft - Electric - Airplanes (FS/W) 5 Jan 18, 2002 08:17 PM
Brushed ESC Steve KO Electric Heli Talk 1 Dec 10, 2001 03:07 PM
