Old Aug 03, 2004, 06:32 PM
mgdon is offline
Find More Posts by mgdon
United States, NC, Belmont
Joined Mar 2004
Best stator coating for bare metal stator?
I'm rebuilding a PJS 3D 550 that had been pretty well trashed and stripped-no wire etc.
Whoever stripped it also took off all the coating off the stator in addition to the wiring.
I'm thinking of putting plastic on the front and rear cut to match the stator outline to help prevent wire shorting on the sharp edges but what is the best coating other wise for the rest of the stator?
I've tried thinned out epoxy before but didn't like it.
mgdon is offline Find More Posts by mgdon
Old Aug 03, 2004, 07:40 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Hi
The problem with coaing the stators is that surface tension pulls the coating away from where you need it ,ie the corners ,you could try some thin u sections of fish paper or any paper probably will do ,slipped onto the sides of the stator poles.
olmod is offline Find More Posts by olmod
Old Aug 03, 2004, 08:10 PM
Buzzard is offline
Find More Posts by Buzzard
Eine melodie im wind
Buzzard's Avatar
North Carolina, United States
Joined Jun 2003
Sorry oldmod but gotta ask
What is fish paper
Dahl
Buzzard is offline Find More Posts by Buzzard
Old Aug 03, 2004, 08:28 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
ok
Its an insulating paper check here.http://www.smallparts.com/products/d...tions/fshp.cfm they have lots of other nice goodies also like silicon rubber o rings for prop savers.
Old Aug 03, 2004, 09:00 PM
Buzzard is offline
Buzzard's Avatar
Joined Jun 2003
Oh goodies!!!!!!!!!!
thanks,
Dahl
Old Aug 03, 2004, 09:34 PM
mgdon is offline
Joined Mar 2004
fish paper
Olmod,
Thanks-Again!
I'll call around tomorrow and see if I can find some.
Also have you heard of something that sounds like "Capstan" tape?
Old Aug 03, 2004, 09:45 PM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Originally Posted by mgdon
Olmod,
Thanks-Again!
Kapton tape
Gerald is offline Find More Posts by Gerald
Old Aug 03, 2004, 09:50 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
oh yes
Id forgotten that! some of the other uses for audio 1/4 " tape and others like vcr tape are good for binding grafts on fruit trees too. but id stick with the fish paper ,it gilloutines nicely and can be folded around a former to make up small u shaped pieces it only needs to cover the two outside corners on each side.
Old Aug 03, 2004, 09:53 PM
Buzzard is offline
Buzzard's Avatar
Joined Jun 2003
How does the audio tape hold up to the heat?
Dahl
Old Aug 03, 2004, 10:55 PM
FlyByMike is offline
Find More Posts by FlyByMike
Pittsburgh, PA
Joined Jan 2002
Capstan: n. 1. A round roller. 2. The round roller used to 'pinch' the recording media (i.e. tape) on 1/4" reel-to-reel or vcr machines against the driven motor spindle.
eh olmod?
-Mike
FlyByMike is offline Find More Posts by FlyByMike
Old Aug 07, 2004, 12:14 AM
mgdon is offline
Joined Mar 2004
Well I found some fish paper.
The type I found is kind of like cardboard with some kind of flexible stuff in it-not very flexible however.(I'll bet there's some thinner fishpaper but this was all they had).
I did find some great stuff though called "Insulating Cambric".
It's a very flexible plastic cloth, .010" thick-"Dielectric srength (whatever that is) 5000 volts"
I think it'll be perfect.
I did try some " Dielectric insulating spray paint"-very thick stuff.
I'll try winding without the cambric first and if I get any shorts use it.
Old Aug 15, 2004, 12:01 PM
mgdon is offline
Joined Mar 2004
The paint as Olmood said it would flowed away from the corners but the "insulating cambric"cloth is great-worked fine-wound 20 turns of 25 gauge-no shorts.
Nice new mounts for the 22.7mm stator... WreckRman2 Power Systems 22 Nov 26, 2004 09:42 PM
AXI Stator Coating - What IS that stuff? Tom Frank Power Systems 2 Sep 24, 2004 01:17 AM
Whoops! Is an 8x4.5 folding Graupner prop too much for a GB single stator motor on 3s? Hogster Power Systems 3 Aug 21, 2004 06:10 PM
Stator winder for GB Brushless sloper steve Power Systems 2 Jun 15, 2004 02:14 PM
Is this Stator suitable for conversion? The Max-Q Power Systems 7 Apr 04, 2004 05:23 PM
