Old Aug 03, 2004, 06:26 AM
cv990 is offline
Find More Posts by cv990
UK
Joined Feb 2003
Brushless - 2 Motors from 1 ESC ?
Probably an easy question for those in the know - can I run 2 brushless motors from 1 brushless speed controller (amp rating permitting, obviously) ?
I suspect the answer is "no", cos doesn't the ESC do some back sensing from the motor ?
Thanks.
cv990 is offline Find More Posts by cv990
Old Aug 03, 2004, 06:55 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Usually no, but some motor/esc combinations do work ... for example Kontronik sell a "twin drive set" with two motors and a single (normal) ESC which works fine. If you run some searches this crops up fairly often ... you might find other examples of specific setups that have been tried.
Bill Glover is offline Find More Posts by Bill Glover
Old Aug 03, 2004, 06:58 AM
zeuglodon is offline
Find More Posts by zeuglodon
Tree Hater
zeuglodon's Avatar
Howland, Ohio
Joined Jun 2004
You got it. The answer is "no" for just that reason. That's what was explained to me when I asked about it. I pretty much decided to use brushed motors at that point so I never really got into the wiring aspect of it --- so I'm not sure about BEC. I suspect that if you use a "Y" harness to connect 2 ESC's to your throttle channel they would be running parallel and the voltage would be safe for your radio, but I'll accept the word of someone who understands this better than I do.
zeuglodon is offline Find More Posts by zeuglodon
Old Aug 03, 2004, 01:04 PM
raptor22 is offline
Find More Posts by raptor22
Striving to Rip the Bring
raptor22's Avatar
San Diego, socal, USA, North America, Earth, Solar System, the Orion arm, Milky way, Universe
Joined Apr 2003
The wiring would be in parralel; it would not double voltage. So, you use the two ESC's w/ a Y harness.
--Alex
raptor22 is offline Find More Posts by raptor22
Old Aug 03, 2004, 01:38 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
Some peple have got it to work, with identical motors. Others have had problems with one motor not starting properly.
There's a video here of it working really well, apparently the poster took no special precautions, it just worked for him.
http://www.rcgroups.com/forums/showt...7&page=2&pp=15
Once running, they should be OK if the motors are turning at the same speed. If one is slightly slower it should draw a bit more power to keep it in sync, but if they get wildly out of sync the controller will get confused.
Robin
RobinBennett is offline Find More Posts by RobinBennett
Old Aug 03, 2004, 02:33 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Two BL (sensorless) can operate on one ESC but what limit success is start-up of both motors. Once running they run in perfect sync and the ESC see only "one". The key is getting a ESC with appropriate (tolerant) start-up algorithms. Using two identical motors is important, also keeping the motorwires (the pair of three) identical in length.
Some combos work, others dont. By reports here on the Ezone Kontronik ESC's offer the greatest chance of success. Motorbrand is less important, ESC is the key.
One can only parallell such a system so your ESC need atleast 2x amp rating of one motor/load.
Haldor is offline Find More Posts by Haldor
Old Aug 03, 2004, 07:49 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Who carries the Kontronic ESC's?
GregG is offline Find More Posts by GregG
Old Aug 03, 2004, 08:03 PM
DrZiplok is offline
Find More Posts by DrZiplok
USA, CA, San Francisco
Joined Feb 2004
Greg,
You can get them from Perry at AeroMicro, although I have always bought mine used here on the 'zone.
My success rate for twins is 100% Kontronik, 0% other (CC, TMM, Jeti).
= Mike
DrZiplok is offline Find More Posts by DrZiplok
Old Aug 04, 2004, 05:27 AM
Littlescreamers is offline
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
It works! Just do it!
Scott
Littlescreamers is offline Find More Posts by Littlescreamers
Old Aug 04, 2004, 11:21 AM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
I made 2 CD motors for a friend and they start and run perfectly on a Tsunami 10 in its default 'mode3' setup. They both have the same number of turns and are connected in parallel (how else?!). I wanted him to connect the same winds together (A to A, B to B etc) but he forgot so we're not sure if he did this or if this is important or not. He now wants a 4 engined model on one ESC; oh no, my fingers are sore!
David.
David T is offline Find More Posts by David T
Old Aug 04, 2004, 02:45 PM
Joined Nov 2000
According to Castle Creations it is not possible to run two brushless motors from one ESC ... well, theirs anyway
http://www.rcgroups.com/forums/showthread.php?t=259943
Old Aug 04, 2004, 03:20 PM
T_Hill is offline
Find More Posts by T_Hill
Arlington, TX
Joined Sep 2003
My P10 and P25 work just fine with 2 motors and one controller. I know several others running them this way with no problems.
Tracy Hill
Conversion motor works
T_Hill is offline Find More Posts by T_Hill
Old Aug 04, 2004, 08:08 PM
DrZiplok is offline
Joined Feb 2004
And I've tried both the P10 and P25 in dual configurations with consistently poor results. I can say for sure they don't reliably start Astro or Mega motors like this.
Perhaps a better way to state it is like this:
Castle Creations explicitly say that their controllers are not designed to run more than one motor in parallel.
Kontronik explicitly say that their controllers are designed to run more than one motor in parallel (and they sell a product based on this).
= Mike
Question Two BL motors from 1 brushless ESC..? bpm Electric Motor Design and Construction 6 Aug 27, 2007 09:36 AM
Question 2 motors on 1 esc? jhspring Power Systems 2 Dec 18, 2006 04:43 PM
Discussion Can you run 2 brushless motors from 1 ESC??? SGTalon Power Systems 1 Jun 30, 2006 09:20 AM
HELP....2 small brushless tail motors for one ESC>??? -=PLanE CrazY=- Parkflyers 6 May 08, 2005 02:28 PM
Brushless 2 motors one ESC MartinL Power Systems 1 Jun 03, 2002 09:44 PM
