Old Jan 27, 2002, 03:30 PM
Richard Hayes is offline
Find More Posts by Richard Hayes
woburn, ma usa
Joined Jan 2001
help! How do I shape the front wing for the "and now' plane
Hi Guys: I'm new to the foamy plane construction. How in the world do I go about putting a curve in the BlueCor of the front wing of my And Now plane? I read another thread that talked about putting the wing into the oven? The wing won't fit the oven of my stove. Even if it did he didn't mention the temperatue used or how you bend it when it is hot. Any help would be appreciated. Thanks
Richard Hayes is offline Find More Posts by Richard Hayes
Old Jan 27, 2002, 03:49 PM
DBCherry is offline
Find More Posts by DBCherry
Worcester, MA.
Joined Nov 2001
Richard,
Haven't done it myself but, seems I read a thread on it.
Try this: use the rounded edge (or side) of your bath tub, and a covering iron or blow dryer. Slowly heat the foam while forming it over the rounded edge.
Be careful and heat it slowly.
Try doing a "Search" on the "And Now", I'm surre you'll find the thread.
DBCherry is offline Find More Posts by DBCherry
Old Jan 27, 2002, 07:20 PM
woburn, ma usa
Joined Jan 2001
Thanks for the input.
Regards
Dick
Old Jan 27, 2002, 09:11 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
The way that works for me is to first peel the skin off both sides. I know it's a pain, but it's a lot easier to bend once it's done. the skin must be virtually melted before you can bend it.
Then, use a heat gun. Hair dryer may work, but I know a good heat gun does. Keep moving it along the center of the bottom of the wing, where you want to bend it, while holding the trailing edge in your hand, and moving with the heat, as you lift the back, and press the front down onto the work surface. You can see the foam just start to melt as it wants to bend.
Alternatively, you can try bending it over an edge while heating the top, but I like to keep the top of the wing un-blemished, so I heat from the bottom.
The more of them you do, the better you get. Don't worry, the wing is only about $.50, so what if you waste one?
Use Tape on the Leading edge once you have sanded the edges round.
Here's my plans page: http://www.geocities.com/genebond/
Here's my pictures: http://photos.yahoo.com/genebond
Have fun!
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 28, 2002, 12:18 AM
Hippo is offline
Find More Posts by Hippo
The effect is sadly temporary
Hippo's Avatar
Ann Arbor, Michigan
Joined Oct 2001
I'm the wing baker.
Hi,
I'm the guy who was making bluecor wings in the oven. I have a wooden jig that I clamp the foam into while it's being heated. It goes in at 200 degrees F for 20 minutes (it takes a long time for the wood to heat up), and then I let it cool for 15 minutes before unclamping it. Check out the original thread. There are pictures of the Jig on page 2.
http://216.40.226.212/~admin2/forums...threadid=23929
I was only doing this for single sheet slowflyer wings. For anything with a spar or ribs, I wouldn't bother with heat. For the tiny, I'd just peel the skin from the inside layer only. Get a rolling pin, or 3/4" dowel and roll out the peeled side. The foam should bend easily toward that side now. Just work the shape til it's close, and then glue it onto the ribs. I like the 3M-77 contact cement so that I don't have to clamp or hold anything.
I hope it helps,
-Dan
Hippo is offline Find More Posts by Hippo
Old Jan 28, 2002, 12:46 AM
SteveC is offline
Find More Posts by SteveC
SteveC's Avatar
So Cal
Joined Sep 2001
blucor?
Why not use depron sturdyboard for the plane.
We don't roll the leading edge at all on our and_now's.
Any bending we do is by hand without heat.
Heating the stuff makes it contract and "bunch up".
The wing shape is maintained by flat-bottomed ribs 9mm tall.
Build it per the plans at http://www.flyelectric.ukgateway.net/indoor.htm
except use carbon for the fuselage and pushrods and throw an M1 motor on it, it will become your favorite plane.
I always keep one in the back seat of my truck, I haven't flown any of my other planes in ages.
SC
SteveC is offline Find More Posts by SteveC
Old Jan 28, 2002, 10:11 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Here's another version....
http://geocities.com/hoppyfl/
I used to worry about the shape a lot but what the heck, if they will fly inverted with an open bottomed wing, how critical can it be?? I use a paint stripper heat gun (B&D), they get much hotter than a hair dryer. If the hair dryer works, I'd use that. You have to be careful with the paint stripper gun as it can melt the plastic if you don't keep it moving and only use it for short time periods. The bathtub "form" sounds like a good idea. I'll have to try that myself.
hoppy
hoppy is offline Find More Posts by hoppy
Old Jan 28, 2002, 10:57 AM
pullin-gs is offline
Find More Posts by pullin-gs
Arlington,VA USA
Joined Jan 2001
This is what I did 10 months ago on my MeatStik for my wing:
http://home.att.net/~p.blakeslee/meat-stik/P6020082.jpg
http://home.att.net/~p.blakeslee/meat-stik/P6020084.jpg
I also built up a wing by sandwiching layered sizes of foam between two sheets that were cord-size in another plane 2 months ago.
http://home.att.net/~p.blakeslee/PB190326.jpg
http://home.att.net/~p.blakeslee/PB190330.jpg
Pullin'
pullin-gs is offline Find More Posts by pullin-gs
Old Feb 01, 2002, 03:49 PM
woburn, ma usa
Joined Jan 2001
Hi: Thanks for the input on bending the front wing for the AndNow sure nice having you guys around. Hope I can do the same some time :-)
Regards
Old Feb 01, 2002, 05:07 PM
mattk17 is offline
Find More Posts by mattk17
mattk17's Avatar
Dallas,TX
Joined Jul 2001
I am the worlds worst at using heat. I finally gave up and just bend the stuff with my hands or with a ruler. On large wings, I cut foam to the airfoil shape and epoxy to the underside of the wing. Works fine. On small wings, I just bend and go. Works for me. I just got back from flying the miniz. It has no supports for the wings and they hold their shape fine.
mattk17 is offline Find More Posts by mattk17
How do you waterproof electronics for float plane?? duganderson Waterplanes 20 Dec 15, 2006 11:23 PM
Replacing Slo-V front wing bracket "HELP" GregoryI Parkflyers 0 Feb 20, 2005 11:04 PM
How do I setup my radio for a wing (PCW) jandirks Radios 2 Aug 09, 2004 11:57 AM
Help! How do I get more vertical for my GWS P51 Mmarshall Power Systems 14 Mar 11, 2003 09:18 PM
Help! How do I retime my 6327 Graupner Speed 480 race motor for a gearbox. Joe Elston Electric Plane Talk 6 Apr 20, 2001 11:56 AM
