Old Aug 01, 2004, 09:50 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Zoom 400, 'must do' Mods?
My Zoom 400 is on the way, are there any must do mods? Belt Drive, bearings, etc???
Here is my setup:
Shogun 400
JustGoFly 400DH BL motor w/9T pinion
CC Phoenix-25
HiTec HS-56 servos on cyclic/collective (3)
HiTec HS-50 on T/R
Berg 6 RX
JR G500T Gyro
TP 2100 3S Gen 1 packs
Deans Whip Ant.
Brian
Brill 1 is offline Find More Posts by Brill 1
Old Aug 01, 2004, 10:08 PM
rickc is offline
Find More Posts by rickc
rickc's Avatar
United States, IL, East Peoria
Joined Jun 2002
Just check your gear mesh's starting with the motor and main gear and work backwards, light weight paddle holders work well also. Other than that just check a few things over, the pin sticking out of the pitch slider needs a bit of CA to keep if from coming out. I also put a bit of CA on the swash to keep the bearing in place. You can use a MonoKoat heat gun to heat up the main gear and bend the gear out to widen the stance if you care to. Other that that just fly it.....
Rick
rickc is offline Find More Posts by rickc
Old Aug 01, 2004, 10:30 PM
sprice50 is offline
Find More Posts by sprice50
Shaun Price
sprice50's Avatar
Victoria, BC, Canada
Joined Aug 2002
Sounds like a great setup Brian. That's the same setup I will be using on mine. I should have it together in a week.
Please post the throttle curve/pitch you use successfully for 3D with this setup.
Shaun
sprice50 is offline Find More Posts by sprice50
Old Aug 01, 2004, 10:46 PM
Rudy Ackerman is offline
Find More Posts by Rudy Ackerman
Houston, TX USA
Joined Nov 2000
How about some feed back on the JustGoFly 400DH BL motor w/9T pinion
Rudy
Rudy Ackerman is offline Find More Posts by Rudy Ackerman
Old Aug 01, 2004, 11:33 PM
sprice50 is offline
Shaun Price
sprice50's Avatar
Joined Aug 2002
From what I have read it is a good motor. You need to set you ESC for a high pole count motor. curve of "My curve for 3D is 100, 75, 65, 75, 100"
Info gained from this thread:
http://www.rcgroups.com/forums/showt...3&page=5&pp=15
Zoom 400:- How do I fit the Canopy so it does not fall off? Darx-starz Mini Helis 2 Sep 26, 2005 01:17 PM
Must-do mods for Piccolo Fun? dstrout Micro Helis 22 Mar 16, 2005 05:06 AM
Question How Do I Set Up My Zoom 400 with Phoenix 25? BimmerM3 Mini Helis 7 May 11, 2004 08:46 PM
My Zoom 400 Mods Fred Bronk Mini Helis 10 Feb 29, 2004 09:57 PM
Must Do - Crazy Max Mods? nr5a Parkflyers 6 Jul 05, 2002 10:29 PM
