Multiplex EasyStar - Thread 9
Here it is, a brand new thread for our "rambles" about the EasyStar.
It is the logical following of thread 8: http://www.rcgroups.com/forums/showthread.php?t=243273 |
Jack, welcome. There are alternatives for the glue, Pro bond or Gorilla glue, both polyurethane glue. Which will need to be clamped with rubber bands, or Med or Thick CA with no kicker, gives a little time to get every thing straight and true, again rubber bands to hold it together, and you can put some kicker on the seams after it is together, which will turn yellow at first, but will return to clear. Let both of these methods sit for at least 4-6 hours to dry.
Motor mounting methods are abundent, the simplest is to use double sided tape or silicone or shoo goo, which can be cut gently with a hobby knife and removed. Leave some slack in the wires to be able to pull them out some to change motors. Don't let them get glued to the channel. Zoomzoom uses a pvc pipe (thinwall) and modifies the inside bumps on the nacelle. I use two aluminum straps that are formed from thin alum. sheet and bent to fit, can be taped on with strapping tape. Here is a link to the one I made: http://www.rcgroups.com/forums/showt...nt#post2072679 |
| Thread Tools | |
| Multiplex EasyStar Thread 14 - Better'n sliced bread! | intheswamp | Foamies (Kits) | 525 | Feb 02, 2005 01:27 PM |
| Yippee! Multiplex EasyStar Thread 13 - Epic Adventure | superboss | Foamies (Kits) | 501 | Dec 16, 2004 11:50 AM |
| Multiplex EasyStar Thread 12 - Ongoing Saga | TreeTrimmer | Foamies (Kits) | 501 | Nov 18, 2004 03:02 AM |
| Yippee! Multiplex EasyStar thread - Part 3! | tim hooper | Foamies (Kits) | 496 | Apr 08, 2004 05:40 AM |
| Multiplex EasyStar thread - Part 2 | tim hooper | Foamies (Kits) | 502 | Mar 11, 2004 05:10 PM |
