Old Jul 31, 2004, 07:08 PM
ctoms is offline
Find More Posts by ctoms
Charlie Toms
ctoms's Avatar
US
Joined Feb 2003
GWS War birds on 400's ?
Does using a 400 size motor in GWS Warbirds direct drive work well. I see in the manual it is an option but have never tried it. I am looking for an improvement in flight time and power/speed over the stock geared unit.
What motor 6V or 7.4V? What prop?
Charlie
ctoms is offline Find More Posts by ctoms
Old Jul 31, 2004, 07:52 PM
daking is offline
Find More Posts by daking
PRO BRO #157
daking's Avatar
Sterling hts, Michigan
Joined Jun 2003
I am sure it would work ok but, the prop would be really small and look pretty fake IMHO. Maybe a 7.2 and a 8 or 9 inch prop??
daking is offline Find More Posts by daking
Old Jul 31, 2004, 08:33 PM
the Swamp Fox is offline
Find More Posts by the Swamp Fox
the Swamp Fox's Avatar
Wadmalaw Island ,SC
Joined Dec 2003
what battery pack are you using Charlie?
the Swamp Fox is offline Find More Posts by the Swamp Fox
Old Jul 31, 2004, 08:56 PM
van-S is offline
Find More Posts by van-S
I fly, therefore I crash
United States, NY, Kings County
Joined Mar 2002
I flew my GWS P51 with a dd 6v speed 400, 6x4 apc prop,8 cell NiMh 650 and 950. It flew with much better speed than the geared setup, even though the airframe was draggy. Lost it a couple of weeks ago when I took my eyes of it to check the tx. Plane was destroyed but the batts were okay! If I got another, I would go dd again.
van-S is offline Find More Posts by van-S
Old Jul 31, 2004, 09:09 PM
ctoms is offline
Charlie Toms
ctoms's Avatar
US
Joined Feb 2003
I have a couple battery choices. I could use an 8 cell pack of AAA size NiMH 700mAh I think they are or else I could use 2 or 3 cell packs of lith in 1200, 1500 and 2100's
I have several planes but I am thinking of the new spitfire from GWS I just got.
Charlie
Old Aug 02, 2004, 06:01 PM
Merlin61 is offline
Find More Posts by Merlin61
San Diego, CA
Joined Dec 2003
GWS 400 upgrade
Use GWS 400 motor/gearboxes. Warbirds like the 3.0/1 ratio. They slide right in. No modifications for F4U or Zero, but mounting stick needs shortening for Spit, Me-109, and P-51 to get fuse/spinners to blend in. Extra weight is O.K. as most people have to add dead weight to nose. APC 8x6 slow for more speed, 9x6 slow for more vertical. Kan or CBP 8 cell 1050s can be squeezed in. Good for 200+ full-throttle flights. If satisfied with 400/gb upgrade, substitute Zagi reverse timed 400 ($10) for 10-20% mor power-but shorter flights. My 400 modified warbirds blow away the 350s and fly like heavy-metal planes should-slow to climb, but come dowhill screaming.
Merlin61 is offline Find More Posts by Merlin61
Old Aug 03, 2004, 11:10 AM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
Spit9, the 400 motor/gearbox mod sounds like just the ticket for the spitfire since I've been reading most builders had to add nose weight to balance it right anyway. I would imagine with that big 400 sitting up front wouldn't need much (if any) extra nose weight. True? I've got an old 20 amp ESC and 9.6v 1100 mah battery sitting in a box waiting for a new home. I think they may have found one it a new Spit! I may just have to pick up a GWS Spit glider and 400 mtr/gbx to make a park flying screamer!
Thanks for the tip!
RCDad is offline Find More Posts by RCDad
Old Sep 29, 2004, 06:11 PM
Ralph Brekan is offline
Find More Posts by Ralph Brekan
a really nice guy, really
Ralph Brekan's Avatar
Phoenix Intl, Arizona, United States
Joined Jul 2004
I'd go 400DD with a 6040 or 7035 prop that will scream just fine. The 400 geared down will give more thrust (for faster climbouts) but the DD400 will fly way more scale (even though the prop isnt, LOL).
Ralph Brekan is offline Find More Posts by Ralph Brekan
Old Sep 29, 2004, 06:30 PM
SU Jags is offline
Find More Posts by SU Jags
Rejisterd Youzer
SU Jags's Avatar
United States, GA, Austell
Joined Apr 2004
Kamikazi, can you show you mounted the 400DD in the GWS planes?
SU
SU Jags is offline Find More Posts by SU Jags
Old Sep 29, 2004, 08:02 PM
thunder1 is offline
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
Direct drive speed 400s like small, 6 or 7 inch props. Most of the warbirds have two mounting holes fot the stick. The lower hole is for the direct drive mount. The mount is just a U shaped piece of plastic which cradles the motor. The motor is held in by rubber bands.
The main problem with direct drive is low end torque. It takes a while for direct drive motors to start pulling and the prop may be stalled until the model is going a certain speed. As long as you're aware of this, you'll be OK.
thunder1 is offline Find More Posts by thunder1
Old Sep 29, 2004, 08:05 PM
SU Jags is offline
Rejisterd Youzer
SU Jags's Avatar
Joined Apr 2004
Old Sep 29, 2004, 09:51 PM
thunder1 is offline
College Park, MD
Joined Sep 2002
Here's a picture of the 400 motor in the mount:
http://www.gws.com.tw/images/note%20...pitfire_07.jpg
Old Apr 07, 2005, 03:53 PM
Joined Jul 2004
I have one in my HET Mustang. You'll have to launch hard to get on step.
Old Apr 07, 2005, 09:45 PM
captglover is offline
Find More Posts by captglover
BLACK SHEEP 2
captglover's Avatar
Alexandria, VA
Joined May 2004
I fly my GWS Corsair with a geared 400 (D), APC 9x6SF prop, & 3S 1320 lipos. It flies fast and is robust, I have over 100 flights on it and its doing just fine.
captglover is offline Find More Posts by captglover
Old Apr 07, 2005, 11:25 PM
rbale1 is offline
Find More Posts by rbale1
Joined Dec 2004
I'd either go geared, or brushless if DD, your going to get half the thrust compared to geared and the spitfire flies fast anyways, relative to the corsair or zero. The spit likes weight up front, but it also likes to fly light, so I wouldn't throw in a 9.6v pack of Nimhs in there. Instead,I'd use lipos if you can afford them (allerc.com has a sale on several 3c packs going on now). Make sure you cut the battery bay all, or almost all the way forward or you'll need balast- even with the 400.
rbale1 is offline Find More Posts by rbale1
Yippee! GWS War Birds 400 Series GWS4CEO GWS (Grand Wing Servo) 160 Feb 23, 2006 04:37 AM
Yippee! How about my old GWS War Birds come with EPS-300C? GWS4CEO GWS (Grand Wing Servo) 10 Oct 30, 2005 10:34 PM
Question What's the best outrunner combo for GWS War Birds? lookoutbelow Parkflyers 42 Feb 04, 2005 03:35 PM
Alert gws war birds vs alpha war birds? tweissen Parkflyers 18 Aug 07, 2004 10:49 PM
Horizon/GWS makes good on RX's sukhoi26mx Parkflyers 3 Apr 26, 2002 02:21 PM
