Old Jul 31, 2004, 04:54 AM
novalogix is offline
Find More Posts by novalogix
experiencing RC flight...
Singapore Woodlands, Singapore
Joined Jun 2004
Rare Foamies Show-off thread
Hi all, lets share your rare, unique or even wierd foamies pix. Include in the flying characteristics and the setup specs. I want to consolidate all these models that i have seen in this forum and i believe there are more out there. So come on fellows!
novalogix is offline Find More Posts by novalogix
Old Jul 31, 2004, 07:51 AM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Well maybe not rare, but lets say you can't buy this on the market!
My flat-plate delta-plane!
Setup:
2s1p 1200mAh Kokam pack
CN12-R-XC 7.2v motor
3x2 prop
Draganeye servos
Hitec Rx
Cheap 5A ESC
Flies extremely well - very smooth in the air, control inputs give very accurate results. Good range of speed. Performance starts to sag after 10 minutes (probably my old battery!), but had a comfortable 18 minute flight with the odd stop here and there. Easy to hand catch. Easy to hand launch using balsa wood keel underneath.
Construction materials: 7mm polystyrene sheeting (the white crumbly polystyrene) for the wing, 1/8" balsa wood for the elevons and fins. Zagi-style covering tape for fins, wing and elevons. 4x0.5mm wide CF reinforcement strips run (vertically) the width of the widest part of the wing at the back, and straight down the centre line of the wing. Also there're two similar CF strips stuck flat against the top of the wing at the front for impact absorbtion!
All up weight = 155g
Took an evening to build
Hogster is offline Find More Posts by Hogster
Old Jul 31, 2004, 09:59 AM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Im Guessing that a Sorta Grumman Goose is not a common plane ..
All bluecor Construction .. Plane is self designed ..
I am running 2 Razor 350 brushless motors in GWS eps gear boxes .. C gearing with 9x7 3 blade props .. speed control is a Phoenix 25 in a watertight bluecor box .. reciever is a GWS 4 channel servos are 1 HS-55 and one GWS pico..
Batteries .. two 3 cell etec 1200 Li-poly packs
Wingspan is 36 inches .. controls are rudder elevator
With fresh packs she will ROW in roughly 25-30 feet
Heres the build and design thread with video links ..Bluecor Grumman Goose Thread
Hope this is what you were looking for
Vyceroy is offline Find More Posts by Vyceroy
Old Jul 31, 2004, 10:09 AM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
Here's my $10 e-Gremlin, made with a Canadian PVC downspout for a fuse (lighter & thinner). Wing is the same size as the original combat plane, 48" span, root chord of 12", tip of 10", 2" elevons. The fins are 2mm coroplast. Took just an evening to build, flown the next day.
I simply transcribed the wing dimensions on a 1" slab of pink insulation foam, and cut the outline. The rest is done outside. Using a soldering iron, I carve a slot to bury and glue a 30" carbon arrow shaft on the underside. I also ran some 1" fibre tape spanwise both sides. I used a 2-D cell portable hot-wire foam cutter (from Michael's) to chamfer the leading and trailing edges.
The 'cutting edge' is only a couple of inches long. Drawing some lines about 2" back from the edge helps guiding the tool, as well as using a 1/2" aluminum rod on the edge to prevent cutting too deep. Then I used a palm sander to finish it off. Took about two minutes and minimal dust to get it to a semi-symmetrical TLAR airfoil. I did sand the trailing edge a bit more on one side (bottom-tip/top-root) to create a bit of washout. It's actually quite flat on a good portion of the cross-section.
Put some captive nuts in 1/16" plywood that was taped and glued to the underside for mounting to the fuse. Elevons were made out of 3/16" foamboard (with the paper on it for stiffness). I also taped control rod tubing to the leading edge to make it 'ding-proof'. I used vapor barrier tape (tuck tape) for covering the wing & elevons. It's very stiff tape with a very good adhesive, if you don't mind red with logo printing.
Powered with an AXI 2820/10 on 9x1950 cells and an 11x7.5 folder, it flies like a bat at 50 oz. Roll rates are great. Flies easily at 50-60% throttle, and the climb rate at full throttle is great. Launching is an underhand throw at ~45 degrees, as there's nothing to grab underneath.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Aug 01, 2004, 10:54 AM
Joined Jun 2004
all these are awesome! guys letś not stop here, bring it on! there ought to be more
Old Aug 01, 2004, 11:12 AM
Johnnie_w2 is offline
Find More Posts by Johnnie_w2
Johnnie_w2's Avatar
Humble Texas
Joined Jun 2004
3F Chicken
How about My 3F Chicken?
WS 48"
Power Gws 300c "c" 1047 prop
2 cell Li-po's @ 1200ma
3ch r-e-t
never have weighed it
So is it rare enough?
Johnnie_w2 is offline Find More Posts by Johnnie_w2
Old Aug 01, 2004, 11:55 AM
bigbear3721 is offline
Find More Posts by bigbear3721
bigbear3721's Avatar
JimThorpe, Pennsylvania, United States
Joined Nov 2003
How about this one, resized .60 glow plains for a Kaos.
38" wing
23.oz
Himax 2025-5300
APC-E 9-6 prop
TP-1900 3-cell
CC PH-25 speed controller
Brian.
bigbear3721 is offline Find More Posts by bigbear3721
Old Aug 01, 2004, 12:04 PM
Joined Nov 2003
Heres another one resized ugly Stick glow.
42" wing
23.oz
Himax 2015-5400
TP-1900 3-cell
APC slow 10-7
CC PH-25
Old Aug 01, 2004, 06:49 PM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Scout
Just messin around does VTOL but still working on transition to flight.
350c
8cell 700
12X6 prop
kram242 is offline Find More Posts by kram242
Old Aug 01, 2004, 10:17 PM
pylot2b is offline
Find More Posts by pylot2b
Virginia Beach, Virginia, United States
Joined Jan 2004
Does an F-14 qualify
I thought I would add my latest creation. Maiden flight set for tomorrow.
WS 19"
Length"19
1 edf 40
AUW 5.1 with battery
Tailerons
pylot2b is offline Find More Posts by pylot2b
Old Aug 01, 2004, 10:28 PM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
hogster any plans? i have a spare 50xc floating around for a coulpe of weeks and some 6mm bluecore
gazza2003au is offline Find More Posts by gazza2003au
Old Aug 01, 2004, 10:51 PM
Tim H. is offline
Find More Posts by Tim H.
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
EDF MF480 Mini Bobcat. For those who have not seen this one before...
Yes, it's Fan Fold. Everything but the booms and stab...
Wemotec Minifan 480
Kontronic Fun 400-36
11 cell Sanyo 1700FAUP NiMh (long before lipo's)
It's still intact and waiting for a lipo fix...
Tim H.
Tim H. is offline Find More Posts by Tim H.
Old Aug 01, 2004, 10:52 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
that plane gets me in trouble Tim .. i get all aroused by it lol
Old Aug 01, 2004, 10:56 PM
Tim H. is offline
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
This one is all Fan fold too...
MB 339
Mega 22/20/4 pusher prop
8-10 cell cp1700
VERY fast! Video is up at www.foamyfactory.com/videos.htm
Tim H.
Old Aug 01, 2004, 10:58 PM
Tim H. is offline
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
ROFLMAO... I figured there are a lot of new Ezoners who have not seen these beauties...
Tim H.
Stevens Aero Appreciation Thread - Show Off Your Models!!! (Part 2) doc-e Parkflyers 1109 Apr 26, 2016 10:52 PM
Yippee! Slow Stick Appreciation Thread-Show off your model--Part 1 Spencer J Parkflyers 80 Jul 18, 2009 05:40 AM
Gallery The Show Off Thread :d helisfreak Micro Helis 6 Sep 29, 2006 03:01 PM
Mountain Models Appreciation Thread-Show off your models! Mindblade Parkflyers 501 Apr 18, 2005 11:46 AM
Stevens Aero Appreciation Thread - Show Off Your Models!!! doc-e Parkflyers 535 Feb 20, 2005 07:29 AM
