Old Jan 26, 2002, 07:13 PM
JimF is offline
Find More Posts by JimF
Ellington, Connecticut, United States
Joined Apr 2001
Zagi trim questions
My zagi is trimmed well and flies straight when gliding, but it really pitches up under power. This is more noticible than most flat bottom trainers I've seen. I know this is normal to a point, but how much have you all noticed this? To get good level cruise at speed, I have to hold down elevator.
It pitches up to such an extent that it tends to almost stall, and drops a wingtip.
Help please.
Jim
JimF is offline Find More Posts by JimF
Old Jan 26, 2002, 11:33 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
United States, WA, Tacoma
Joined Jun 2001
Yup, it's a zagi thing, or at least it is on my 400 and others I've read.
Spacers under the front of the motor can help alittle. Mostly, just find your cruising speed and trim to level flight.
William A is offline Find More Posts by William A
Old Jan 27, 2002, 05:27 AM
DEATHspiral is offline
Find More Posts by DEATHspiral
San Diego, CA, USA
Joined May 2001
Move your battery just a tad bit forward, or add weight to the nose, but the battery movement forward should cure the problem. I have mine flying level.
DEATHspiral is offline Find More Posts by DEATHspiral
Old Jan 27, 2002, 08:57 AM
mopar_man is offline
Find More Posts by mopar_man
Terry Dunn
mopar_man's Avatar
United States, TX, Lubbock
Joined Jan 2001
Try all of the above. If they dont work, make sure your CG isnt too far forward. If it is, you will need more reflex in the elevons to fly level. When you power up, that same amount of reflex will cause you to pitch up. Just another idea.
mopar_man is offline Find More Posts by mopar_man
Old Jan 27, 2002, 11:32 AM
Dan H. is offline
Find More Posts by Dan H.
Crashez-vous sans stress!
Dan H.'s Avatar
Chicago
Joined Nov 2001
Computer radio?
After you've checked/adjusted the downthrust, CG and re-trimmed, if it still is annoying, and you have a computer radio that does throttle to elevator mixing, you can program a little down-elevator into your throttle curve. With some trial-and-error you could eliminate the pitch change.
Dan H. is offline Find More Posts by Dan H.
Old Jan 27, 2002, 06:35 PM
JimF is offline
Joined Apr 2001
Thanks for the input. I trimmed it out so it flies more or less level under full power. I had 3 flights today and worked it out pretty good. At least I know its a Zagi thing. Still having fun, but I'm feeling the need for speed. Maybe a motor upgrade!
Jim
Covering the Zagi (newbie questions) estill Foamies (Kits) 30 Feb 04, 2002 04:51 AM
Thinking of getting finally) a zagi, few questions though. Peter W Foamies (Kits) 53 Dec 13, 2001 01:12 PM
Zagi 400X questions davidhnsocal Foamies (Kits) 2 Sep 30, 2001 04:33 PM
Zagi Trim Question dmccoach Foamies (Kits) 3 Jun 03, 2001 10:29 PM
Some Zagi flying questions slowflyer Foamies (Kits) 9 May 14, 2001 07:25 AM
