Old May 04, 2001, 03:06 AM
NickBee is offline
Find More Posts by NickBee
Flanders, NJ USA
Joined Jan 2001
Motor/GearBox/Prop question....
Got my Virus 400 in the air today. Boy is it a great flyer!!! It can fly very slow with plenty of power of loops. With the light wing loading it leaps off grass in a few feet.
The only issue is the gearbox that it came with is not great. It vibrates and full throttle and there is too much slop in the mechanism for clean power transitions. The stock set up is a multiplex 400, 3:1 gear and an 11x4.7 APC. I'd like to get a Graupner "1700 Series" Gear Drive at 2.33:1. Will I still be able to swing the 11x4.7 prop? I am currently using an 8 cell 600AE pack, but also plan on getting an 8 cell 1100NMH pack. I love the look of the large prop and would like to use it if possible.
Thanks!!!
NickBee is offline Find More Posts by NickBee
Old May 04, 2001, 08:23 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Have you balanced the prop?
hoppy
hoppy is offline Find More Posts by hoppy
Old May 04, 2001, 08:58 AM
Mitch G is offline
Find More Posts by Mitch G
Mitch G's Avatar
Naperville, IL USA
Joined Nov 2000
I think an 11x4.7 will be too much prop for a 2.33 GB. (Motocalc shows 13.9 amps static with this combo. It shows 10.4 amps static with your 3.1 GB.)
According to motocalc, a 9x4.5 with a 2.33:1 GB will give you the closest match to your 11x4.7 and 3:1 GB combo as far as amps draw is concerned.
(Note: I don't know if 9x4.5 props are readily available or not.)
I personally have had good experience using a 9x6 (11.3 amps static) and an 8x6 (9.1 amps static) with a 2.3 Mini Olympus GB on my T-52.
Mitch
Mitch G is offline Find More Posts by Mitch G
Old May 04, 2001, 09:02 AM
NickBee is offline
Flanders, NJ USA
Joined Jan 2001
Yup, Balanced the prop.
It's just a CRAP gearbox. The small flange mounts and slop make it very unstable. I guess I could glue the gearbox to make it better, but I'd rather not permanently affix it. Looks like I'll go with a Graupner BB Aluminum gearbox (then I can get a 3:1 ratio). I just can't wait to fly it again!!!
FS: X-250/Cutie motor, gearbox, prop, esc Al P Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2003 07:33 AM
Motor/gearbox/prop suggestion for 1 145 mAh Li-Poly and RFFS-100 BEC Scratchbuilt Indoor and Micro Models 16 Dec 17, 2002 03:34 PM
FS: New Speed 400 motor, gearbox, prop bmwbob Aircraft - Electric - Airplanes (FS/W) 0 Jul 13, 2002 09:20 PM
I need help determining motor/gearbox/prop for sailplane Chris K Electric Plane Talk 5 May 01, 2002 09:29 PM
MG-1 motor/gearbox/prop kit nip + GWS Props Al P Aircraft - Electric - Airplanes (FS/W) 1 Jan 06, 2002 12:56 PM
