Old Jun 26, 2001, 05:26 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
suggestions for next plane
Howdee all. I currently have (2) Firebird XL's. They fly fine with the rudder flap mod. Its not that I'm getting bored with it but, would like more challenging venues ala
rudder/elevator types of planes. I fly on my farm in a huge field. Take offs are done by hand launch (too bumpy for landing gear)
and most of the field is waist high grass so
crashes aren't all that bad. The 'birds are my first rc planes so I have basically no experience with attaching servos and other electronics. But would like to start building these types. Been on this board just reading posts for a few weeks and have determined you guys are the experts! So, which model do you guys recommend? Looking for a park type flyer first. Balsa based?
Foam? What should I look for? T-52 looks sort of interesting. I'd like to be able to do some loops and other simple aerobatics at first. Thanx to all those that reply!!!
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Jun 26, 2001, 05:28 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Get a T52, then a Zagi.
..a
Old Jun 26, 2001, 10:16 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
T-52 in standard configuration and then change the 10deg dihedral wing to a flat wing with ailerons for axial rolls/inverted flight/etc. This plane will take you from beginning to medium aerobatics with only the change of a wing and one more servo. The other very strong point of the T-52 is its durability. New flyers are amazed that it can go in head first and end up with maybe a broken prop or wing rubberband. Usually, you can just pick it up and fly again.
I owned a Wingo and spent most of my time gluing it back together
hoppy
hoppy is offline Find More Posts by hoppy
Old Jun 27, 2001, 09:27 PM
Joined Jun 2001
Thanx. Been looking around at some different sites. Man, a whole lot to chose from!!! Packaged kits w/electronics sans
transmitter. Lots of different Hitec transmitters (3 channel). What I want is to only have to make 1 transmitter purchase. I'd like to use it on both a T-52 and a Zagi and even on a slower flyer like a duskstik.
My main fear is not so much flying, its putting together all the servos and speed controller etc. I don't want to be fryin anything!!! All the things that go into the
plane is starting to get befuddled.
Dave...
Old Jun 28, 2001, 10:19 AM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
I got a sky scooter pro because it had everything with it. It also came pre assembled. so it was easy to decipher how everything was hooked up. Plus I managed to make a few simple mods so that the plan would fly well. The scooter pro is a great way to learn without spending a lot of money, and all of the radio equipment will transfer to a xagi, if I want to use it there. I got started flying for $165, and maybe $50 in mods and supplies. I think this plane is the perfect match between, cost, performance, durability, and value. good luck
soholingo is offline Find More Posts by soholingo
Old Jun 28, 2001, 01:43 PM
Joined Jun 2001
Soho, the mod you made with your sky scooter pro, was it the prop and gearbox? How did it fly stock from the box without mods? If I'm not mistaken, it comes with a HiTech 3 channel AM radio. So, you can use the radio
with the correct innards on a Zagi or T-52?
Dave...
Old Jun 28, 2001, 09:40 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Dave, although it costs more, $179 at hobby club, the Hitec Flash 5 comes with a small RX, the 555, and 3 HS 81 servos. It is a computer based TX with 5 model memories, digital trims that are remembered for each plane, dual rate switch, elevon mixing, exponential rates, etc etc. It is so much better than the cheaper models that it is well worth the price if you think that you will become a rabid flyer. I bought the 3 channel Hitec and got the Flash within 3 months.
Good luck
hoppy
Old Jun 28, 2001, 10:38 PM
Joined Jun 2001
Thanx for the info, Hop! So, if I go with the flash 5, I should use the same servos and
RX that comes with the transmitter for a T-52, Zagi, Cub or whatever I decide to build?
Old Jun 28, 2001, 10:51 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Dave...
Exactly!!!! I used the 3:1 gearbox and the 9x6 slowflyer prop, and it made ALL the difference in the world. My plane went from a difficult to launch, hard left turning plane, to something I could trim while flying easily.
As for the reusability of the parts, I plan on doing just that. Putting my parts into a xagi or a t-52 or something else later. The scooter is the PERFECT way to test the waters of this hobby without spending a lot of money, and your equipment is reusable. It's a 3 channel radio, and the pro comes with an esc, so you have everything you need. I will say this again. I don't understand why the scooter pro isn't better received here...
j
Old Jun 28, 2001, 11:27 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
The radio that came with my skyscooter(beg verson) dos'nt have elevon mixing, and won't work with my zagi.
William A is offline Find More Posts by William A
Old Jun 28, 2001, 11:45 PM
Mike C is offline
Find More Posts by Mike C
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
I think the Flash 5X glider version is worth the money for sure. I got mine from New creations and Kirk switched out the servos to HS'55 and saved me a little money and weight. If the electriconics is what you dread. They can solder all the connectors on and you just hook it all together. On mine the connectors are installed in such a way that you cnnot mess it up. Hobby Lobby also offers this in what is called plug and play. Get a bettter quality radio you will love it. As for planes I used the T52 and it has done great for me. It will take a ton of abuse, I should know!
Mike C is offline Find More Posts by Mike C
Old Jun 29, 2001, 11:29 AM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
That's true because it's a 2 channel radio, the radio with the PRO version is 3 channel and supports elevon mixing.
j
Discussion Airfoilz...suggestions for the next plane design... Captain Carlton 3D Flying 78 Sep 23, 2006 08:52 PM
Suggestions for next plane ChefBoyRD Parkflyers 6 Jan 16, 2005 11:20 AM
Beginner looking for next plane suggestions TheCheat Slope 82 Dec 02, 2004 01:30 PM
Suggestions for next plane Dan Navarrete Foamies (Kits) 0 Nov 12, 2003 03:15 PM
Suggestions for NEXT PLANE? glenclif Parkflyers 9 Jul 31, 2002 02:17 PM
