Old Jul 22, 2004, 12:27 PM
Bonsai Master is offline
Find More Posts by Bonsai Master
Dive Bomber in Training
Bonsai Master's Avatar
Loveland, Colorado, United States
Joined Apr 2004
How about a compiled list of hints for building/flying?
Has anyone compiled a list for people about building/flying park flyers?
Such as:
BUILD
o Do not use alot of glue to build your plane!
o use velcro for battery placement allows you to adjust the CG easily.
o build your plane to your flying location - tall grass= no landing gear, want to take off=find a place with dirt or pavement.
o If you glass your plane fly it BEFORE painting!!!!
o bring along a cooler to place your batteries in to cool them down. They operate better when cooler - and charge better. This works best if you are going to stay and fly alot. If you do this I would recommend NOT putting drinks in there also!
o fully discharge your NiMh and Nicads after flying your plane(Not needed with Lipos). Each time you do not fully discharge your batteries you are decreasing the life. By discharge I mean run till the motor cuts off. It wouldn't hurt to fully discharge occasionally too.
o Know other flyers in the area and talk with them. Find out the freqs they use so that you are not working in your garage and shooting down a plane in the park!
o Check your servos EVERY time you fly. Check for direction - you never know if a reverse switch could have accidentally be thrown on the transmitter. I found a tail hinge that was broken this way.
o Do not fly at populated parks!
I've only been flying for a few months - i'm sure there has to be alot more suggestions.
just some thoughts, any more input?
Bonsai Master is offline Find More Posts by Bonsai Master
Old Jul 22, 2004, 12:53 PM
Peter Khor is offline
Find More Posts by Peter Khor
Peter Khor's Avatar
Mostly in Norman, OK
Joined May 2002
Since this is GWS forum ... related to GWS planes:
* GWS supplied glue is good! Use it like contact cement
* GWS hinges are good! Use a drop of foam-safe CA to secure
* CG on most GWS planes are quoted for experienced flyers, you can move it forward 5-10mm
* If you need need to replace a plane, remember that Slope Glider versions are available.
Just a quick comment wrt to batteries though; you don't need to fly till LVC for NiMh or NiCads; just charge and fly. Once in a while you might want to discharge a pack and then slow charge it at C/10. iirc deep cycling batteries (NiCad, NiMh) will decrease the number of life cycles.
As for cooling a pack, DON'T put it in a cooler with ice, etc. You will sooner ruin a pack. Battery packs (esp NiMh) operate BETTER when WARMER. In fact, even if you had just charged a pack 1 hr ago, you can put it back on a peak charger to 'warm it up' - you'll get better performance. Best way to cool a pack is forced-air cooling.
Peter Khor is offline Find More Posts by Peter Khor
Old Jul 22, 2004, 04:10 PM
Cincy E-Flyer is offline
Find More Posts by Cincy E-Flyer
www.silentflyers.com
Cincy E-Flyer's Avatar
Cincinnati, OH
Joined Jun 2004
Besides, if you put your packs in the cooler, it leaves less room for the beer!
Just kidding of course!
Cincy E-Flyer is offline Find More Posts by Cincy E-Flyer
Old Jul 22, 2004, 05:18 PM
WilliamS is offline
Find More Posts by WilliamS
Joined Jun 2004
i don't think putting the batteries into a cooler after flight is a good idea, if putting batteries in unusually low temp. is good at all....
WilliamS is offline Find More Posts by WilliamS
Old Jul 22, 2004, 10:18 PM
Joined Apr 2004
it is common practice to put regular batteries in the refridgerator to keep the charge. I was under the impression that a hot battery does not charge as well as a cooler one. And by cooler i mean not warm to the touch, not cold to the touch.
Old Jul 23, 2004, 12:53 AM
Reverend is offline
Find More Posts by Reverend
Reverend's Avatar
Innsbruck, Austria
Joined Oct 2003
HI Bonsai! (Wow, that rhymes )
What you suggest in your first post is what I've tried to do with my Site GWS-Fans.com
Take a peek!
Rev
Reverend is offline Find More Posts by Reverend
Old Jul 23, 2004, 01:58 AM
WilliamS is offline
Joined Jun 2004
that's right
hot or even warm packs are not suppose to be charged, natural temp is the best.
How to adjust the Cessna 180 properly for great flying performance ecost Parkflyers 6 May 26, 2009 02:29 AM
How about making depron elevons for an IFO/Firefly ScienceGuy Scratchbuilt Indoor and Micro Models 6 Dec 06, 2003 07:17 PM
Favorite Tips and Hints for building martys Scale Kit/Scratch Built 7 Apr 08, 2003 11:01 AM
How about an U-2 for the kids under 10? GWS4CEO Parkflyers 11 Mar 23, 2003 09:44 PM
Just Ordered T-Moth, Any Hints for Building or Flying? glenclif Parkflyers 12 Jun 19, 2002 07:59 PM
