Old Jul 22, 2004, 12:54 AM
Splash is offline
Find More Posts by Splash
One
Splash's Avatar
Seattle
Joined Feb 2003
DC-3 / C-47 very scale prop-hub set up
Good evening guys,
We ( e-flightline hobby ) have special VarioProps with 2mm hubs and 6.2" scale blades to help make your DC-3/C-47 look and fly very scale.
Here are a few pix of the set up. We should have a video posted tomorrow.
Have a great evening.
Splash is offline Find More Posts by Splash
Old Jul 22, 2004, 01:10 AM
R2800 is offline
Find More Posts by R2800
Motley crewmember
Melbourne,Fl
Joined Sep 2002
Very nice.
Are we talking the Speed 400 motors here?
May have to switch to these for my DC-3
R2800 is offline Find More Posts by R2800
Old Jul 22, 2004, 01:17 AM
Splash is offline
One
Splash's Avatar
Seattle
Joined Feb 2003
Nope,
you can use any 2mm shaft motor. We have had the varios on both the stock can motors and the pix you see it flying with are twin Himax 2015-3600. We are about using 1/3 of the total pitch available. So you wanted to push more amperage with a bigger pack you could but it flys better than scale now and has over 20 minute flight times.
Old Jul 22, 2004, 10:33 AM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Is there a bolt-on 3 blade setup for a std. IPS shaft?
Tim Wolff is online now Find More Posts by Tim Wolff
Old Jul 22, 2004, 10:49 AM
aplphabandaid is offline
Find More Posts by aplphabandaid
Alphabandaid
Marshfield, Wisconsin, United States
Joined May 2003
What pitch, size and hub works with the stock motor. Like what I see.
aplphabandaid is offline Find More Posts by aplphabandaid
Old Jul 23, 2004, 05:00 PM
HawkLover is offline
Find More Posts by HawkLover
Callsign: CornDog
HawkLover's Avatar
Milpitas, CA
Joined May 2003
Looks like a winner! How did it fly with the stock setup? Is this a plane better suited to brushless motors?
HawkLover is offline Find More Posts by HawkLover
Old Jul 23, 2004, 07:05 PM
David A Ramsey is offline
Find More Posts by David A Ramsey
New Jersey, USA
Joined May 2003
Originally Posted by Splash
Good evening guys,
Nice Props! Can you tell me what the Amp draw is with these props on a 2S lipoly with the stock motors?
David A Ramsey is offline Find More Posts by David A Ramsey
Old Jul 26, 2004, 12:07 AM
Splash is offline
One
Splash's Avatar
Seattle
Joined Feb 2003
Good day guys,
The plane flys ok with the stock set up but we wanted long flight times and just a bit more power.
With the vario's you dial in your pitch so you can match your battery pack and ESC.
We have them set up now to draw 9 amps on each motor.
We flew on both the stock and brushless let up with this props. We just needed to dial in a bit more pitch with the brushless to get us where we wanted to be the stock set up flew well too with this set up.
Old Jul 26, 2004, 03:37 AM
mc411800 is offline
Find More Posts by mc411800
Crimson Swine...
Australia, VIC, Romsey
Joined Jul 2003
Splash,
Just ordered my Varioprops for the DC3 from your website. Sweet!
Noticed on your site that your DC3 is running 6x4 3 bladers. What pitch are you guys running with the Varioprops? Mine will be stock build, stock motors, ETEC 1200 2S2P (very similar to yours, by the look of things).
Cheers,
Mick
Canberra, Australia
mc411800 is offline Find More Posts by mc411800
Old Jul 26, 2004, 09:32 AM
Alphabandaid
Joined May 2003
I too just ordered some, and will be flying stock motors initially.
Just dial in the appropriate pitch to match the battery pack, i.e. most any pitch should be adeqaute to fly?
Old Jul 26, 2004, 09:37 AM
Splash is offline
One
Splash's Avatar
Seattle
Joined Feb 2003
Good day guys.
We are using the 6.2" blades and the pitch is about 1/3 of the available pitch (lots of room to move up) It flys very scale and I need to get the video up.......I promise later today to get it posted.
Old Jul 27, 2004, 10:50 PM
Splash is offline
One
Splash's Avatar
Seattle
Joined Feb 2003
Good evening guys,
Sorry, but Im a day late with the video, but click here to see the DC-3 video
Let me know if you have any questions.
Old Jul 28, 2004, 07:40 AM
Tim Wolff's Avatar
Joined Sep 2002
Since you asked. Once again...
No is an acceptable answer. But, any response will acknowledge that you read the question....
Old Jul 28, 2004, 09:05 AM
Alphabandaid
Joined May 2003
I know a lot of folks using 3 blades on IPS. Try Hobby Lobby.
Old Jul 28, 2004, 09:49 AM
Tim Wolff's Avatar
Joined Sep 2002
Hah! That is a neat 3-blade for IPS at Hobby Lobby. I know GWS makes a 9x7 3 blade too. I'm looking for something to bolt on to a CD ROM outrunner conversion that uses a 3mm threaded IPS shaft. The variprop setup is not cheap and I don't want to get into something that is going to require additional adaptors or require the replacement of the shafts on the CD ROM motors. If they don't just "bolt on" then it is a lot cheaper and less hassle to cut down some 9x7 blades to "fit".
FAQ Time for a Twin - Blu DC-3 / C-47 project Gene Bond Foamies (Scratchbuilt) 982 Jun 30, 2015 04:23 PM
DC-3/C-47 kits? CAWayne Electric Plane Talk 126 Feb 10, 2012 10:38 AM
Sold DC-3 / C-47 sloper pdawg Aircraft - Sailplanes (FS/W) 2 Oct 06, 2005 08:52 PM
Cool GB Brushless for the GWS DC-3/C-47? ticketec Power Systems 0 Oct 21, 2004 01:52 AM
