Old Jul 21, 2004, 01:16 PM
SoarNeck is offline
Find More Posts by SoarNeck
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Marske Pioneer IID
Hi folks,
I've come to the conclusion that I don't "design, build, and fly" model airplanes...I only design them! Haven't been able to get out in a few weeks now, and I'm getting the shakes Maybe this weekend.
Anyway, in my neverending quest for a decent winter project (the stability analysis on the Baby Albatross was a little scary), I came across the Marske Pioneer IID. The structure is simple, and its uniqueness appeals to me, since as far as I can tell only one model was ever built (Kuhlman, 1/4 scale).
That's both good and bad, since it means that I don't have a lot to go on. I've also never designed a flying wing before, so I have a few questions for those that might know.
First, the photos:
SoarNeck is offline Find More Posts by SoarNeck
Old Jul 21, 2004, 01:34 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Now, the questions:
1) Apparently, the full size model uses a bridle on tow. I couldn't quite figure out what type of tow was being referred to...does it use a bridle on aerotow as well? Why wouldn't a traditional nose release work?
Knowing first-hand what can go wrong with a single release point, I don't fancy having to use two release points
2) Aerodynamics. From what I read on the B2Streamlines site, the 1/4 scale version used the full-scale airfoils. This was successful for a slope model, but tended to cause trouble with tipstalling/spinning on the thermal field from all reports.
Thinking that there are better choices for the reduced reynold's numbers of a model, I started some research. I wanted to stay with a section that was close to the overall dimensions and thickness of the scale airfoil, lest the model look odd.
The first step was to nail down a size, and I arbitrarily chose 4m. I like big sailplanes, and 4m seems to be the point where they really start to shine, but don't overload a medium-sized tug.
So, root chord is 21", tip chord is 7", and wing area is around 2200sq". I'm guessing at 16 lbs to be pessimistic, since there's lots of area, but not much fuse or tail.
The Re# at thermal speeds is likely the limiting case, so I'm dealing with 360,000 at the root and 120,000 at the tip (25mph). To support that mass, the local Cl at the root is about 0.6625, and 0.3267 at the tip (my spreadsheet).
I looked at the full-size airfoil first, out of curiousity. Not a polar that inspires confidence. Strangely, the curve seems smoother at lower RE...but there have to be better choices. First, the graph:
Old Jul 21, 2004, 01:42 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
So, armed with just enough knowledge to be dangerous, I started looking for alternatives. The best choices I have so far are the MH60 and MH45.
After messing about a bit, I determined that the MH60 could be thickened a little without messing up the polar too much. A thicker section would be closer to the scale look, and would make the spar a lot stiffer as well:
Old Jul 21, 2004, 01:47 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
The tip polar at 120,000. I decided to stick with the stock thickness, since it gave a nice aerodynamic washout twist over the total wing:
Old Jul 21, 2004, 02:11 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
By playing with the transition point between the 12% MH60 to the MH45 (ie where the airfoil is halfway between the root MH60 and the tip MH45), I think I was able to take care of the tipstall issue. With the transition point at 0.25 span (closer to root), and just a hair of washout at that point, I get the following graph. Looks good to me, since the max cl location is nicely inboard.
The sum of aerodynamic and geometric washout has the following progression from root to tip, in increments of 19" (over the 2m panel):
0.0, 0.0, -0.3, -0.4, -0.9
This is accomplished with only 0.2 degrees of washout at the transition point. The root and tip airfoils are both set at the same angle of attack.
The only thing I'm still worried about is c/g and longitudinal stability. How to I calculate the former, and analyze the latter?
Regarding pitch stability, most flying wing designers talk about the "Cm" of the airfoil. Is this referenced to a particular angle or attack, or lift coefficient? The reason I ask is that it changes over the range of these parameters, so I don't know what I'm looking for regarding "needing" a postive Cm for a plank wing".
Any suggestions would be welcome - I feel a bit out of my league with this design.
The full size aircraft can be seen here, BTW:
http://www.continuo.com/marske/pioneer.htm
Nice scheme:
http://www.continuo.com/marske/pione...31,%202001.jpg
Old Jul 21, 2004, 02:17 PM
GeeW is offline
Find More Posts by GeeW
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
Bridles for tow releases are usually used to avoid having to make a 'hard point' (with its attendant structure, and added weight) some where else, like on the nose.
It is more weight efficient to do this.
Quite a few years ago I used to fly a full size Fauvel flying wing which used a bridle, and I always wondered what would happen if one side refused to play ball at the critical moment........one day of course it happened (but not to me!) and apparently apart from causing about 15 degrees of yaw and almost stopping the tug from climbing all was just about controllable. The tow pilot guessed what had happened and let the glider pilot have the other end of the rope aswell. All landed happily...but quite a few people stopped wanting to fly the Fauvel.
As a matter of interest (or not) the early L13 Blaniks had bridle release for winch launching.
Best of luck with your project.
GeeW
GeeW is offline Find More Posts by GeeW
Old Jul 21, 2004, 02:35 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
GeeW
That's very interesting, thanks very much! I was hoping that a bridle on aerotow wasn't something that was particular to the aerodynamics of flying wings.
Old Jul 21, 2004, 03:21 PM
MikeC is offline
Find More Posts by MikeC
MikeC's Avatar
United States, NM, Albuquerque
Joined Jan 2001
Contact B2 and talk to them about it. They are very helpful and giving with knowledge gained from their vast experience with flying wings.
Have you seen the latest mods to the full scale Pioneer 2 on the Marske site. Wow! it is very nice.
MikeC is offline Find More Posts by MikeC
Old Jul 21, 2004, 03:54 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Do the numbers on a blend fom root to tip E205 root 8.0% and E214 tip 7.0%
this is the section I use on my planks
steve wenban is offline Find More Posts by steve wenban
Old Jul 21, 2004, 04:04 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Already done, though I couldn't find an active email address for them. I posted to RCSE in the hopes that they were monitoring. Might also be my email server...I'll check that out later.
I did see the newest version (impressive), but I was looking for something simple The new version would be a much more complex project.
Old Jul 21, 2004, 04:05 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Okay, I'll check that out. What chord lengths are you used to dealing with?
Old Jul 21, 2004, 04:08 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
This graph shows why I'm confused about the "Cm of an airfoil". Where should I be looking?
Best as I can understand, I think that people mean the Cm for level flight. My spreadsheet is telling me that level flight @ 16lbs and root Cl of 0.6625 means that the root is at an angle of attack of 5.4 degrees (relative to the zero-lift angle). Do I look there for a positive Cm value? That would be -0.7 degrees (zero lift) + 5.4 degrees, or +4.7 degrees.
Help please
Old Jul 21, 2004, 05:51 PM
Joined Dec 2003
chord and span
chords I have used are vary greatly from 312mm to 500mm spans are also wide and varied from 500mm to 4.0 metres my homepage has photo's if your interested I have used numerous foils in my search for the right plank at our slope and have found what is to me anyway the right combo which is my evolution 50 and 60 as well as the Spade 52 and the Marley 60 but you will see some of mine and other guys stuff on the site
Old Jul 21, 2004, 06:02 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Interesting build.. As I recall Barnaby Wayfin (sorry about the bad spelling) was involved in that project. I also recall him being a big fan of testing air craft designs in the R/C world before building full scale. He also built the facet-mobile etc. An intersting guy.
I'd imagine you should be able to connect to those guys online and they would probably do all they can to lend you a hand. I think Barnaby writes for one of the Experiment Aviation Associations magazines..?
It is a good looking plane.
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Jul 21, 2004, 06:29 PM
TheAeronut is offline
Find More Posts by TheAeronut
12th Pursuit Squadron
TheAeronut's Avatar
Garland, Tx.
Joined Mar 2002
Go look at their website http://www.b2streamlines.com/ and send e-mail to them at bsquared@b2streamlines.com ... You might also be able to contact them over the Nurflugel mailing list http://groups.yahoo.com/group/nurflugel/ ... Best of luck with this one. I too like the Marske planforms, tailless with slight forward sweep.
J.P.
TheAeronut is offline Find More Posts by TheAeronut
Discussion Marske Pioneer II or III Sail-r Scale Sailplanes 5 Mar 15, 2007 05:05 PM
Scale Flying wings? Pioneer IID rcsoar4fun Scale Sailplanes 3 Nov 29, 2004 07:09 AM
