Go Back   RC Groups > Aircraft - Sailplanes > Slope
Old Jul 21, 2004, 03:57 AM   #1
Insert custom witicism
Jeff Charlot's Avatar
Want some Alaskan Leg?
How about a LEG One Design racer?
I'll try to get this thing built before the winter, but I've kinda got a history.... Same deal as before, I don't much feel like talking to a wall, so by all means, pipe up and chime in. I'll be learning a few new things as we go, so if you have advice or an idea, spit it out and we'll see if it works.
Kind of a side note, I'm REAL impressed with the quality of the LEG kits, that's why I took closeups of the hardware. All the fiddly bits required to finish the plane are included, dihedral angle has already been pre-set before it gets to you, just a well thought out kit, lots of pre-fab.
Well enough of that, let's see what this thing looks like...
  • Name: shaping 001.jpg
  • Name: shaping 002.jpg
  • Name: shaping 021.jpg
Jeff Charlot is offline Find More Posts by Jeff Charlot   Reply With Quote
Old Jul 21, 2004, 04:05 AM   #2
I have no set pattern to how I build foamies, I generally build the part that sounds the "funnest". I wanted to see how this thing was going to look, so I started by knocking off the edges with a snap blade.
  • Name: shaping 003.jpg
  • Name: shaping 010.jpg
  • Name: shaping 012.jpg
Old Jul 21, 2004, 04:18 AM   #3
Photos are courtesy of Devon, one of many neighbor kids who think that planes are 'tight'. Yes, I can say that with a straight face.
After the edges are knocked down, I did the general shaping with 40-grit-3M-sticky-sided-automotive-sand paper that was slapped onto a chunk of foam. Thanks to TFLG for that tip......that was totally tight.
  • Name: shaping 015.jpg
  • Name: shaping 014.jpg
  • Name: shaping 018.jpg
  • Name: shaping 019.jpg
  • Name: shaping 020.jpg
Old Jul 21, 2004, 04:32 AM   #4
Well, the fuse stopped being fun, so we moved onto the wing. Started out by finding the wing pieces. Remember 'back in the day" when your spar joiner was a 6" piece of hardwood jammed in front of the spars? Man, that still cracks me up. The LEG "joiner" is almost three feet long, the dihedral is pre-set with the spars cut and glued for you. The main spars have the scarf joint pre-cut so even I can't screw this one up.....can I?
I used epoxy to glue the main spar together and then to glue the joiner to the main spar. I like epoxy because it's strong and fast and I can make a lot of progress quickly.
  • Name: shaping 022.jpg
  • Name: shaping 023.jpg
  • Name: shaping 027.jpg
  • Name: shaping 028.jpg
Old Jul 21, 2004, 04:39 AM   #5
Next I prepped the cores and the beds by scrubbing all of the goobers off with some scrap EPP.
Why did I include pictures of this? 'Cause Devon took like three hundred pictures of this step. Why the interest in this step? No telling.....kids are frickin wierd.
  • Name: shaping 029.jpg
  • Name: shaping 031.jpg
Old Jul 21, 2004, 04:50 AM   #6
Alright, we've got a spar channel cut out for one spar, but now we have two spars glued together. Here's what we do; lay the main spar down in the pre-cut slot with the joiner IN FRONT of the main spar. Then just trace around it with a pen.
Sorry for the crappy pix, but this works great. Extend your snap blade knife until it reaches the bottom of your spar slot.....that's how deep you want to cut for your joiner. After cutting down the line you just made, lay your knife flat in the spar slot and cut out the excess foam. Hopefully pictures speak a thousand words. Thanks to Jack for that tip, it works like a champ.
  • Name: shaping 039.jpg
  • Name: shaping 040.jpg
  • Name: shaping 042.jpg
  • Name: shaping 044.jpg
  • Name: shaping 046.jpg
Old Jul 21, 2004, 05:02 AM   #7
Looks like I kinda got into a groove here and didn't take many pictures. I put wax paper on the wing beds, drizzled lots of WBPU glue all over the spar, (and my floor) then laid the spar in the spar slot and made a sandwich with the wing beds and weighted the whole mess down. After that, Leah came out to the shop, made the kids go home and respectfully and subserviently requested that I watch a movie with her.
......okay.......she made me....
  • Name: shaping 047.jpg
  • Name: shaping 048.jpg
Old Jul 21, 2004, 05:11 AM   #8
While the credits were rolling, I blew Leah a quick kiss on my dash out to the shop and started in on the tail group. It's a pretty simple affair, 3/8" sheet balsa. I drew a centerline on the stab and the elevator, marked out where I would put my CA hinges and slotted both parts with a hinge cutting tool. (purchased on my recent trip to the PSS Mecca!)
  • Name: shaping 049.jpg
  • Name: shaping 050.jpg
  • Name: shaping 051.jpg
Old Jul 21, 2004, 05:16 AM   #9
Same deal here, I took some sandpaper and knocked the edges off of the stabs. Apparently I got into a groove and my pictures are a tad sporadic. Oh well, here's what I got. Make sure you have plenty of throw at this stage. You don't need massive ammounts, but be sure that after you cover the tail group, you'll still be able to move the elevator
  • Name: shaping 052.jpg
  • Name: shaping 053.jpg
  • Name: shaping 054.jpg
Old Jul 21, 2004, 07:59 AM   #10
Timmay!!!!!!.....:P
mothflyer's Avatar
hey jeff
looking great!!
i should get my one d when i go visit jack, i can't wait.
later
tim
mothflyer is offline Find More Posts by mothflyer   Reply With Quote
Old Jul 21, 2004, 04:17 PM   #11
Hey Tim, it's turning into a pretty quick build. Now if I can convince my boss to let me stay home and finish it.
Next I got going on the pre-cut trailing edge material. Marked which was which, drew a centerline and then cut a 'V' notch in the wood with an exacto. After that I hogged out the rest of the channel with my dremel.
  • Name: shaping 055.jpg
  • Name: shaping 057.jpg
  • Name: shaping 056.jpg
Old Jul 21, 2004, 04:25 PM   #12
After the channel was cut, I made sure that the torque rods would fit flush, marked where the throw would be needed and hogged out the appropriate area with my dremel again. Handy little tool. Looked good to me, so I mixed a little bit of epoxy, laid it in the channel and installed the torque rods with some tape to hold it secure.
I made double sure that I didn't get any glue in the torque tubes! Man, I've made that mistake more than once.
  • Name: shaping 059.jpg
  • Name: shaping 061.jpg
  • Name: shaping 062.jpg
Old Jul 21, 2004, 06:19 PM   #13
rational exuberance
Dunqun's Avatar
Send a message via ICQ to Dunqun Send a message via AIM to Dunqun
Hey Jeff, looking good! I have no substantive comment, I just didn't want you thinking you were talking to a wall.
Duncan
Dunqun is offline Find More Posts by Dunqun   Reply With Quote
Old Jul 21, 2004, 07:10 PM   #14
mmm... wings....
zagiace's Avatar
gotta love build threads...
Looks great!
zagiace is offline Find More Posts by zagiace   Reply With Quote
Old Jul 21, 2004, 07:15 PM   #15
Slope Racing Fanatic!
nwoods's Avatar
Loving it Jeff. If it turns out good, I'll send you my kit for the "Here's all the things I'd do differentely if I ever had to do it again" thread...
Nathan Woods
nwoods is offline Find More Posts by nwoods   Reply With Quote
Anyone do the viper conversion and want some cheap dumb FF fun? Boba_Fett Electric Plane Talk 3 Apr 14, 2009 11:25 PM
Want some LMH110 or Corona pics Tom Viper Electric Heli Talk 1 Dec 02, 2001 10:35 AM
anybody want some pics of the Corona? petn7 Electric Heli Talk 4 Oct 16, 2001 05:07 PM
I want some info on gliders. rdogg32 Electric Sailplanes 9 Jul 13, 2001 01:54 AM
Anyone in W. Wa. want some foamie stuff AMTJIM Foamies (Kits) 3 Jul 08, 2001 11:34 PM
Congratulations SimpleM!
