Old Jul 18, 2004, 07:17 PM
Snow Bird PA-FL is offline
Find More Posts by Snow Bird PA-FL
Snow Bird PA-FL's Avatar
Pgh PA and Dania Beach FL
Joined Jul 2001
Question
Camera Battery elimator circuit / Free on line Zener Diode selector...very neat?
Frist here is the site. http://www.vwlowen.demon.co.uk/java/zener.htm
I have two questions.
I pluged in 5 vdc for input I know when nic cad batteries are fully charged they put out more volts, so just 5 rather than 4.8.
I have 2 cell cam so that is 3 vdc.
I was just guessing on ma cam would draw... . am I close for a Aiptek 1.3.
The wattage of resistor..... if I remember right the wattage that calculator shows should be three times that because you wouldn't want it to get hot and burn up.
A little knowledge is dangerous...lol..
Snow Bird PA-FL is offline Find More Posts by Snow Bird PA-FL
Old Jul 18, 2004, 07:24 PM
Joined Jul 2001
Oops! I just noticed the diagram doesn't show you which is + or -...hummm
Old Jul 19, 2004, 12:28 AM
zagisrule! is offline
Find More Posts by zagisrule!
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
+ in is the top going into R, + out is the junction of R with the zener.
The bottom line is ground, or -
There are other simple ways to do it...for example you can cascade multiple diodes, forward-biased, to drop the voltage down. Most switching diodes run about a .7V drop, so placing 3 in series would drop 2.1V or so and bring your 5V down to 2.9. This is not regulated like the zener setup, but is simple as well and would work fine. The plus side is that you also don't have to have a big resistor and zener to dissipate the power safely because individual voltage drop is low and the dissipation is shared by the 3 devices. The parts for this will also come right off of the shelf at Radio Shack where you would have to order/wait on parts for the zener setup.
Another way is to simply power the Aiptek on USB power, which just involves soldering to the USB connector internally, but eliminates external components. This also eliminates the auto-shut off feature of the camera so it will stay on as long as it gets power. This is my personal reccomendation.
Yet another option would be a voltage divider...setup to yeild the voltages and currents you want.
Or an adjustable voltage regulator.
Lots of possibilities here, there are so many ways to tackle one problem with very basic electronics such as this stuff.
-Matt
This is how the diodes would be hooked up:
zagisrule! is offline Find More Posts by zagisrule!
Old Jul 19, 2004, 09:11 AM
Joined Jul 2001
Cool..... I like your design! Will give it a try.
Tom
Old Jul 19, 2004, 10:25 AM
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
Great, I am glad to have helped out.
Make sure the capacitor you use carries a 6.3V rating or higher.
-Matt
Buying a camera on-line SchiessCo Life, The Universe, and Politics 7 Mar 04, 2004 07:30 PM
Rayovac 9 volt Battery found on-line. PaulNJ Parkflyers 0 May 12, 2001 01:23 AM
