Old Sep 25, 2010, 10:49 PM
Ian Easton's Avatar
United Kingdom, Scotland, Fife
Joined May 1999
well, going over the plans again and taking some measurements it looks like I can answer my own question. It appears that the tail wheel section should be 3/8" wide and not 3/16" as stated on the plan.
Ian Easton is offline Find More Posts by Ian Easton
Old Mar 14, 2011, 07:19 PM
Ian Easton's Avatar
Joined May 1999
A bit more activity...
Old Mar 14, 2011, 07:21 PM
Ian Easton's Avatar
Joined May 1999
The two upper spars I cut down the middle with my little dremel table saw then glued in a strip of carbon fibre to stiffen them up.
Old Mar 14, 2011, 07:24 PM
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
Beuatiful Ian, keep em coming buddy!!!
Bill
williame3590 is online now Find More Posts by williame3590
Old Apr 05, 2011, 05:13 AM
Oxford, UK
Joined Mar 2009
Have followed this thread with great interest and just now am preparing for my own build. Three things got me going.
1. The excellent Falcon built by someone in Czechoslovakia, linked with SAM 122.
http://www.sam122.sk/nasemodely/falcon/index.htm
After reading the English translation, there are about 73 pictures at the page bottom showing stages of the build. I particularly like the idea of building small Hitec servo’s HS82MG into the tail section. – avoids mechanical linkages with servo’s in the cabin area.
2. Obtained a clean set of 3 plans from Colin Smith, ‘Phils Vintage Plans’, 8 Heaton Road, Ensbury Park, Bournemouth, Dorset, BH10 5HW, UK.
Phone 07747 722724. Cost: £9.50 includes p+p.
3. A partial kit of laser cut parts for KK Falcon from,
http://www.belairkits.com
(may not be listed on website). Phone 01362 668658 for details.
Cost, £70 including p+p. The parts were held in 13 sheets of balsa plus a bundle of ply parts. When I saw the precision and quantity of the parts (about 147) I realised the enormity of a Falcon build. A great tribute to you guys who have fashioned each part by hand. There are plenty of sticks and stuff still to order, but (forgive the pun) I have a flying start.
Another source of laser cut parts for the Falcon is found in Australia at http://www.sparclaser.com.au/
Two comments so far. The parts were cut true to the drawing dimensions, which were Imperial size. Some ply items were the nearest metric equivalent. For example, the box tongue specified, ¼ inch (6.35mm), is actually 6mm. Not a big problem.
One aspect of the wing construction not clear to me in studying the plans is how the dihedral braces fit in. Looking at the rib drawings there appears not to be slots for the braces to pass through. All I can figure is much of the wings is built up, then accommodating slots are cut in the ribs to fit the braces. Anyone confirm or correct me on this.
Thanks.
ol Timer is offline Find More Posts by ol Timer
Old Apr 05, 2011, 08:04 PM
Ian Easton's Avatar
Joined May 1999
I have almost one wing done now - it's akin to building the Forth rail bridge. I can't believe how much wood goes into this model. It is turning out beautiful though.
Ol-timer - no the ribs don't show a space for the dihedral braces, you'll have to cut the slots wider yourself.
I noticed on the Czech model that he didn't sheet the fuselage as per the plan - that would save quite a bit of weight and lumber.
Old Apr 06, 2011, 04:48 AM
Oxford, UK
Joined Mar 2009
Thanks Ian for the confirmation. A note on the plans would have helped here. I am just compiling my next shopping list and yes, a lot of wood. I plan to cover with Solartex and expect to be shocked at the acreage needed. Another deviation on the Czech model is the use of spruce (?) for main spars and longerons.
Ray
Old Apr 07, 2011, 02:07 PM
Tim Trick's Avatar
The Netherlands
Joined Apr 2004
Ian,
looks like you have been getting on very nicely this last month or so. The wings are certainly a lot of work - the large number of vertical shear webs were what finally did me in! Will you be using wing bolts or sticking to elastic bands?
In an case your model is doing you proud!
Ol Timer - I can also support using spruce for the spars, especially if you sandwich 3 mm spruce with hard balsa. The combination is nice and light yet far superior to pure balsa with regards strength and flexability.
Cheers
Tim
Tim Trick is offline Find More Posts by Tim Trick
Old Apr 15, 2011, 11:12 AM
Oxford, UK
Joined Mar 2009
Pictured below are the centre sections of the Falcon wings. Some tidying up is needed.
Had I realised the time consuming precision needed for me to assemble these sections I would NOT have followed this construction method. Instead I would have adopted the simpler method of joining wings with aluminium tubing and 6g (3/16 inch) rods, as shown in the Ben Buckle Majestic Major (wingspan 88 inches), which has flown for more than 14 years.
One mistake was to include the hard wood tenons on the tongue side instead of the box side.
Each section has an extra ply rib glued to the outer rib, strengthening support to the box and tongue and tenon items.
Not having the recommended silk or nylon or similar fabric to bind around the box, I bound it instead with linen thread then varnished it.
Old Apr 15, 2011, 12:26 PM
GEE,...it BEE model time
piperjoe's Avatar
Interlochen, MI
Joined Dec 2009
One thing for sure, ol Timer, you are going through a bit of extra work on this build but you will end up with a very nice Falcon model when finished if the the center section is any indication; looks great.
Soft landings,
Joe
piperjoe is online now Find More Posts by piperjoe
Old Apr 20, 2011, 10:18 PM
Ian Easton's Avatar
Joined May 1999
I've decided not to build "the box" too. I'll be using carbon fibre rod inside brass tubes.
Old Jun 07, 2011, 05:32 PM
Joined Jun 2011
Falcon flown again
Name: Bartons Point MFC 22-05-2011 001.jpg
Description: Falcon ready for flight on a very windy day
I have flown the Falcon again recently but still had trouble with the Merco 49 engine cutting out. However it did fly well but needed a lot of down-elevator trim on a very windy day ( 21-05-2011).
I need to check the Flexi-tank for faults
I noticed that Ian Easton has built a free-flight tail-plane for his model---is this right?
MJE
michael j etheri is offline Find More Posts by michael j etheri
Old Jul 18, 2011, 03:16 PM
Ian Easton's Avatar
Joined May 1999
I did build the tail for free flight as that was my intention at the time. However, I did build it with enough structure that I can cut the elevators loose and make it RC, which I finally decided I will do. I've spent too much time on this one to let it fly loose, though I would really like to see it free flight. Anyway, not much progress lately as I got involved in another project that I had stalled on for a really long time and have to get finished before getting back to my Falcon.
Old Sep 12, 2011, 08:31 AM
Joined Jun 2011
Bridge Crashes---A KK Falcon Stars
Falcon builders---check out this You Tube video for some rather amusing model flying!
MJE
Bridge crashes II (4 min 50 sec)
5 min - 24 Dec 2008 - Uploaded by inky000
A few rc plane crashesby inky00091350 views; Thumbnail 3:55. Add to. Severn Bridge MFC 2009 Showby
Old Sep 12, 2011, 02:48 PM
Ian Easton's Avatar
Joined May 1999
Wow, those guys must have more time (and money) than me to build models!
Makes you wonder about the life some engines have had that show up on fee-bay.
Repost: Keil Kraft Outlaw Plan required. Steve_Bennington Sport Planes 22 Jul 21, 2010 09:26 AM
Looking fo Keil Kraft plans Ian Easton Free Flight 12 Dec 30, 2009 01:57 PM
EP and R/C Keil Kraft Chief? Ragnar Electric Sailplanes 10 Oct 07, 2009 05:36 AM
Keil Kraft Senator Tony Oliver Free Flight 12 Nov 14, 2004 10:40 PM
